frank_ster Posted April 24, 2013 Share Posted April 24, 2013 nothing i can realy see.. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted April 25, 2013 Share Posted April 25, 2013 All good, sorry I didn't answer your question before, I'm from New Zealand. loving the 3.0R. What's the gt like to drive? it's got monsterous amounts of torque aye? does it come in early or do you have to spool the turbo up? Link to comment Share on other sites More sharing options...
frank_ster Posted April 25, 2013 Share Posted April 25, 2013 the 2.5 gt is good. it has the same hp as the 3.0 but has a much larger range of power. lag is some what bad on the auto versions when you first get moving. i really hated it so i put a turbo v6 engine in mine. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
rob-2 Posted April 25, 2013 Share Posted April 25, 2013 All good, sorry I didn't answer your question before, I'm from New Zealand. loving the 3.0R. What's the gt like to drive? it's got monsterous amounts of torque aye? does it come in early or do you have to spool the turbo up? Stock there isn't much before 3K. Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted April 27, 2013 Share Posted April 27, 2013 oh shit, a turbo v6? Do you mean the ez30 flat 6 with a turbo? Got any photos? my old car was a Honda accord Euro-R which had 220 Nm at 6400rpm but the 3.0R has more torque than that at 1000rpm. It's so nice to drive *drool* Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 27, 2013 Share Posted April 27, 2013 oh shit, a turbo v6? Do you mean the ez30 flat 6 with a turbo? Got any photos? my old car was a Honda accord Euro-R which had 220 Nm at 6400rpm but the 3.0R has more torque than that at 1000rpm. It's so nice to drive *drool* Hope, thread here> http://legacygt.com/forums/showthread.php/my-subaru-beat-buick-heart-140053.html Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 22, 2018 Share Posted August 22, 2018 I do t know if it’s new or I never noticed but if I set the CC to say 70 mph and try to accelerate with the cruise control lever it will turn off my set speed and I can’t turn it on if I try 80 and try to accelerate. Anything lower than 70 I can Link to comment Share on other sites More sharing options...
relative4 Posted August 22, 2018 Share Posted August 22, 2018 Weird, I also have an '05 5MT and the CC doesn't puss out till 90 or 95, I forget which. Driver pusses out at 135 or 140, I forget which. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 23, 2018 Share Posted August 23, 2018 Odd this morning I was able to get it to go past 80 but it’s iffy more times then not it will turn off the CC each time i try to accelerate.. Link to comment Share on other sites More sharing options...
relative4 Posted August 23, 2018 Share Posted August 23, 2018 Maybe a wheel speed sensor getting weak. Check for pending codes? Link to comment Share on other sites More sharing options...
dbur Posted October 5, 2018 Share Posted October 5, 2018 With speed limits at 80 here in some states, cruising at 90 becomes 'reasonable'. My 03 Outback H6 won't set cruise above 90, but the speedo reads 4 mph fast so 90 is actually only 86. I'd be happy with 90 so if I can get my speedo set to correct speed I'm OK with the cruise limit. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 5, 2018 Share Posted October 5, 2018 With speed limits at 80 here in some states, cruising at 90 becomes 'reasonable'. My 03 Outback H6 won't set cruise above 90, but the speedo reads 4 mph fast so 90 is actually only 86. I'd be happy with 90 so if I can get my speedo set to correct speed I'm OK with the cruise limit. Don't complain to much about seeing 90 but really only going 86mph. That can save you from a more expensive speeding ticket. The cop will clock you going 86 instead of 90. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
