PieceOfChum Posted December 1, 2011 Share Posted December 1, 2011 I wanted to know if a 2004 Dodge Neon SRT-4 wheels will work with a 2008 Legacy 2.5i SE model. The tire size is the same I am googling it now but was hoping somebody migh have actually used this setup and would know and could comment on how well it worked. Thanks Link to comment Share on other sites More sharing options...
MasAyinde Posted December 1, 2011 Share Posted December 1, 2011 ...you do know how wheel dimensions and bolt patterns work, right? Link to comment Share on other sites More sharing options...
PieceOfChum Posted December 1, 2011 Author Share Posted December 1, 2011 No I am new to this whole second set of tires for the Winter thing. Trying to figure it all out now. Link to comment Share on other sites More sharing options...
MasAyinde Posted December 1, 2011 Share Posted December 1, 2011 are you new to cars also? I'm just trying to get an idea of the knowledge base here Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 1, 2011 Share Posted December 1, 2011 Be careful. Using SRT-4 wheels will make your car FWD. Not ideal for snow use. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
JesseH Posted December 1, 2011 Share Posted December 1, 2011 I hear SRT4 wheels also render the rear power windows useless. Link to comment Share on other sites More sharing options...
PieceOfChum Posted December 1, 2011 Author Share Posted December 1, 2011 Ha ha okay I don't think the wheels have anything to do with the drivetrain being AWD versus FWD. Second JesseH I don't have a rear power window and if it became useless because of my tires then I would a whole different level of help. I understand tire sizes fine I know the bolt patterns need to match and outside of that I am not sure if I should be concerned with anything else. Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 1, 2011 Share Posted December 1, 2011 You were warned. Just thinking about it made your rear power windows stop working! Soon, you'll be buying massive quantities of hair gel and baseball caps with extra stiff bills. Once the sunglasses hit, there will be no going back. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
MasAyinde Posted December 1, 2011 Share Posted December 1, 2011 Srt4 wheels will never fit on a Legacy http://i.imgur.com/ppK8J.jpg Link to comment Share on other sites More sharing options...
PieceOfChum Posted December 1, 2011 Author Share Posted December 1, 2011 Okay thanks Link to comment Share on other sites More sharing options...
dudeondacouch Posted December 1, 2011 Share Posted December 1, 2011 SRT-4 wheels absolutely fit, but you have to turn them around backwards because the offset is different. Link to comment Share on other sites More sharing options...
boymk123 Posted December 1, 2011 Share Posted December 1, 2011 I heard 2 front wheels are double the size of the rear one, on a SRT.. so BAC was right, you will get FWD!!! Link to comment Share on other sites More sharing options...
PieceOfChum Posted December 1, 2011 Author Share Posted December 1, 2011 Everything I am seeing suggests that the SRT4 rims and tires were the same size front and back. Also I am not sure what you mean by turn them around backwards. I believe the offset for the SRT4 rims is 45mm and the offset for the Legacy 17 inch rims is 55mm so I am not sure that a 10mm offset is going to make a big difference as I am pretty sure the tolerance for an offset is 10mm. Link to comment Share on other sites More sharing options...
scoobydoobie Posted December 1, 2011 Share Posted December 1, 2011 SRT 4 bolt pattern is actually 5x100 also. Link to comment Share on other sites More sharing options...
contractkiller Posted December 1, 2011 Share Posted December 1, 2011 even though they will render your car FWD, it will up the HP to 1000 FWHP... what did u mean when you said. it felt like i was driving a civic? did u mean the car felt like it was more dependable and it was getting better mpg's? Link to comment Share on other sites More sharing options...
planelazy Posted December 1, 2011 Share Posted December 1, 2011 You can make them fit by drilling new bolt holes with a dremel Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 1, 2011 Share Posted December 1, 2011 You can make them fit by drilling new bolt holes with a dremel Plasma cutter, too. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
joelwatts Posted December 1, 2011 Share Posted December 1, 2011 jaysus. these guys are harsh. i don't know if i would try it w/ a 10mm off set difference. often times thats more than the actual space between the brakes and the wheel. seems a bit too close to the calipers. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 1, 2011 Share Posted December 1, 2011 jaysus. these guys are harsh. i don't know if i would try it w/ a 10mm off set difference. often times thats more than the actual space between the brakes and the wheel. seems a bit too close to the calipers. Lower offset is closer to the fender, not the caliper. Noob. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2011 Share Posted December 1, 2011 ROLF, this is pretty funny. Between this thread the the other noobie asking about which oil to use....I've had a great day. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JesseH Posted December 1, 2011 Share Posted December 1, 2011 Lower offset is closer to the fender, not the caliper. Noob. GTFO out of here with that. Lower offset wheels are closer to the road, not the fender or the caliper. The road is all that matters. Link to comment Share on other sites More sharing options...
wpmarky Posted December 1, 2011 Share Posted December 1, 2011 If the bolt pattern of the wheels you are looking at is 5x100, and the offset isn't smaller than +45, it should fit. Link to comment Share on other sites More sharing options...
joelwatts Posted December 2, 2011 Share Posted December 2, 2011 Lower offset is closer to the fender, not the caliper. Noob. Thought I was keeping with the theme. My bad. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
turbo_dan Posted December 2, 2011 Share Posted December 2, 2011 The wheels are only 17X6's, the largest tire you can safely mount on them is a 215/50/17. Link to comment Share on other sites More sharing options...
frank_ster Posted December 2, 2011 Share Posted December 2, 2011 Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
