LegacyKid5 Posted November 15, 2011 Share Posted November 15, 2011 Turns out my front end links are on their way out and will need replacing in the near future. My question is what end links would you guys recommend, my dad recommended to just replace them with OEM Subaru parts, but I was curious what else is out there and might be a better option. I've read great things about the kartboy end links, pro's and cons with them? They are replacements for a 2005 legacy GT wagon. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted November 16, 2011 Author Share Posted November 16, 2011 also, how much of a difference will I notice between the kartboys and stock given the fact that they will be paired with a stock sway bar? Link to comment Share on other sites More sharing options...
ChefRacer Posted November 16, 2011 Share Posted November 16, 2011 Do you plan on upgrading the swaybars? The kart boy end links are pretty pricey considering you really wont get any benefit out of them with a stock sway bar, but if you are planning on upgrading later, then upgrading the end links now is a might as well. If you are staying stock, save your money and get some oem or generic end links. I just upgraded my sways to the hotchkis set $250 for both is a great deal, and I still have stock end links. I'm just waiting for em to break so I can justify the ridiculous amounts of money they extort for upgraded end links, or I might just try to fabricate my own end links and save $280 on a couple simple metal brackets. Link to comment Share on other sites More sharing options...
iggybdawg Posted November 16, 2011 Share Posted November 16, 2011 One of my front endlinks just broke, and I bought a rallitek set. So far so good. Link to comment Share on other sites More sharing options...
CapnJack Posted November 17, 2011 Share Posted November 17, 2011 +1 on the Rallitek set. I have them on my car as well. They are an OEM style but built much better. Price is also VERY good on them. Link to comment Share on other sites More sharing options...
tito_b0y Posted November 17, 2011 Share Posted November 17, 2011 If you plan to upgrade the sways, +1 on the Kartboys. Otherwise, Rallitek's with the stock setup may suit you just fine. I have KBs all around with 22mm sway bars and they made a subtle but noticeable difference in handling. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
LegacyKid5 Posted November 17, 2011 Author Share Posted November 17, 2011 Have you been pretty satisfied with the 22mm and KB's all around, good fitment, handling, and no weird noises? Link to comment Share on other sites More sharing options...
tito_b0y Posted November 18, 2011 Share Posted November 18, 2011 Definitely, yes, definitely, and nope. I ran my RSB with stock endlinks for awhile before I upgraded to the KBs. Subtle, but noticeable difference in handling. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
LegacyKid5 Posted November 18, 2011 Author Share Posted November 18, 2011 Thanks for the input guys, I think with where I'm at I will probably just go with the Rallitek, they seem like a great product with an extremely affordable price. The install looks pretty easy, I was just curious if there is a certain torque they need to be tightened down to? Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted November 18, 2011 Share Posted November 18, 2011 32.5 lbs Link to comment Share on other sites More sharing options...
m sprank Posted November 20, 2011 Share Posted November 20, 2011 Kartboy front are rear links are about $200. Far superior to OEM. But if not upgrading anything else... Link to comment Share on other sites More sharing options...
Thunder240 Posted November 27, 2011 Share Posted November 27, 2011 I'm also looking at end link upgrades. On Rallitek's website, their vehicle application guide doesn't show fitments for any 5th gen Legacies. Has anyone tried them on a 5th gen, and did they fit correctly? If not, are there any less expensive alternatives to KB that are worth looking at? I'll be using them with RCE front and rear sways. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2011 Share Posted November 27, 2011 I bought these from my Tuner. Currently $126.00 http://www.tuningalliance.com/productDetails.php?id=13989&car_id=701 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted November 28, 2011 Share Posted November 28, 2011 Perrins would be my last choice. Incorrect use of a heim joint. We tested them. 6 months later they were so worn out (street use only) that they were causing false knock. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2011 Share Posted November 28, 2011 I installed mine back in early June of 2010, at 127,000 miles, I got 147,000 miles on the car now. Mine don't have a hiem joint, mine are solid. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted November 29, 2011 Share Posted November 29, 2011 The product you linked are Perrin links with spherical bearings (heim joints). Same ones we tested and trashed with a cross country drive. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2011 Share Posted November 29, 2011 Sorry, when I clink on the link I get a solid looking end link, no threads or nuts on the picture. To me, a Heim joint is like what's on a traction bar, it adjustable. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jamal Posted November 29, 2011 Share Posted November 29, 2011 he's talking about the spherical bearing part. And all the links with bearings in them tend to fare pretty poorly on a street car. Whiteline has switched over to a heavy duty adjustable version of the oem endlinks which seem to work pretty well. I've had my kartboys for about five years now and don't get a sound out of them. Link to comment Share on other sites More sharing options...
m sprank Posted November 29, 2011 Share Posted November 29, 2011 Yes, all spherical bearing designs (basically and encapsulated heim) are a very poor choice for the street. Even on the track they need replacing a few times a season. Mis-appplication of the joint. Link to comment Share on other sites More sharing options...
