m sprank Posted October 30, 2011 Share Posted October 30, 2011 (edited) The all new Filtered Turbo Oil Supply Lines V2 Taking orders now. $250 delivered. IP&T Filtered Turbo Oil Supply Line Kit V2 For those interested in a full ACVS replacement kit, I have those too. Specific for 05-06 and 07-09. $300 delivered. http://www.infamousperformance.net/media/02/a20791e1335138046bcc6_s.jpg IP&T Filtered Turbo Oil Supply Line V2 and ACVS Replacement Line Kit 05-06 IP&T Filtered Turbo Oil Supply Line V2 and ACVS Replacement Line Kit 07-09 Instructions attached. Edited January 24, 2015 by m sprank Link to comment Share on other sites More sharing options...
m sprank Posted October 30, 2011 Author Share Posted October 30, 2011 Pix of the prototype Bracket used is not the production piece. It is something I made quickly to hold filter until bracket was ready. Used an Xo2 FMIC (original WRX modified for LGT) to show how even with a poor fitting FMIC the kit is serviceable and usable. http://legacygt.com/forums/attachment.php?attachmentid=106435&stc=1&thumb=1&d=1319111897 http://legacygt.com/forums/attachment.php?attachmentid=106436&stc=1&thumb=1&d=1319111897 http://legacygt.com/forums/attachment.php?attachmentid=106437&stc=1&thumb=1&d=1319111897 http://legacygt.com/forums/attachment.php?attachmentid=106438&stc=1&thumb=1&d=1319111897 http://legacygt.com/forums/attachment.php?attachmentid=106439&stc=1&thumb=1&d=1319111897 http://legacygt.com/forums/attachment.php?attachmentid=106440&stc=1&thumb=1&d=1319111897 Link to comment Share on other sites More sharing options...
FiftyTwoEighty Posted November 5, 2011 Share Posted November 5, 2011 That fills the gap in the market quite nicely. How many washers did you need to use to get the line to clear at the banjo fitting at the turbo? I'm using two for my FP line as long as the connector is perfectly parallel to the turbo housing. It would be nice if someone came up with a banjo fitting that would clear the housing without stacking washers. Just my two cents and I don't need to tell you what that is worth. Link to comment Share on other sites More sharing options...
Infamous1 Posted November 5, 2011 Share Posted November 5, 2011 How many washers did you need to use to get the line to clear at the banjo fitting at the turbo? I'm using two for my FP line as long as the connector is perfectly parallel to the turbo housing. It would be nice if someone came up with a banjo fitting that would clear the housing without stacking washers. Just my two cents and I don't need to tell you what that is worth. It sounds like you need this kit, I will let Mike explain though Link to comment Share on other sites More sharing options...
m sprank Posted November 5, 2011 Author Share Posted November 5, 2011 Single washer at the turbo. No stacking. I had a long necked banjo fitting made so that the AN connection is not hitting the turbo housing. I tried to "correct" all the "issues" reported with the FP line. Then take it a few steps farther. Link to comment Share on other sites More sharing options...
01rs25 Posted November 6, 2011 Share Posted November 6, 2011 Installed this today, everything went as planned with the exception of the oil filter bracket. I ended up having to use some electrical tape as the bracket wouldn't tighten enough to keep it from moving. Overall a great product! I'm very happy with my purchase! Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
m sprank Posted November 6, 2011 Author Share Posted November 6, 2011 What would not hold? We have installed several of these at the shop now. No issues. Brackets grab filter tight prior to "bottoming out". All "should" be identical as they were cut on a water jet. If something is "off" I will replace it. Link to comment Share on other sites More sharing options...
goneskiian Posted November 7, 2011 Share Posted November 7, 2011 I got mine on Saturday. Thanks Mike! Looking forward to getting this and my 16G installed. Should I be putting some kind of sealer on the threads between banjo's and lines and filter and lines? Yes, I'm very new to this. Also, what would you use to clamp off the coolant lines. I'll be installing the turbo without changing oil and coolant. Thanks! Link to comment Share on other sites More sharing options...
m sprank Posted November 8, 2011 Author Share Posted November 8, 2011 No sealant should be necessary. I use clamps designed for cutting off flow thru hoses. You can get a cheap set (couple bucks) at harbor freight. Link to comment Share on other sites More sharing options...
aj2four0 Posted November 11, 2011 Share Posted November 11, 2011 Any chance you have pics of the full avcs replacement? I'm beating my head against a wall figuring out exactly what I should do here.. a few pics would be worth a thousand words I'm hoping. Link to comment Share on other sites More sharing options...
m sprank Posted November 12, 2011 Author Share Posted November 12, 2011 Sorry. It mimics the OEM line, except I left slack up front to come into the ACVS straight (front of motor to back). I have two cars at the shop with the manifolds off and oil lines going on. I will snap a pic tomorrow and post up for everyone. Link to comment Share on other sites More sharing options...
m sprank Posted November 12, 2011 Author Share Posted November 12, 2011 Pix of the pre-air pump ACVS line routing. Sorry about rear of motor, crappy cell phone pix. http://legacygt.com/forums/attachment.php?attachmentid=107786&stc=1&thumb=1&d=1321135610 http://legacygt.com/forums/attachment.php?attachmentid=107787&stc=1&thumb=1&d=1321135610 http://legacygt.com/forums/attachment.php?attachmentid=107788&stc=1&thumb=1&d=1321135610 http://legacygt.com/forums/attachment.php?attachmentid=107789&stc=1&thumb=1&d=1321135610 http://legacygt.com/forums/attachment.php?attachmentid=107790&stc=1&thumb=1&d=1321135610 Link to comment Share on other sites More sharing options...
FiftyTwoEighty Posted November 12, 2011 Share Posted November 12, 2011 Single washer at the turbo. No stacking. I had a long necked banjo fitting made so that the AN connection is not hitting the turbo housing. I tried to "correct" all the "issues" reported with the FP line. Then take it a few steps farther. Consider me to be corrected. Does the filter element allow for adequate flow? Link to comment Share on other sites More sharing options...
m sprank Posted November 13, 2011 Author Share Posted November 13, 2011 Tested at 6 gallons per minute. Link to comment Share on other sites More sharing options...
iNVAR Posted November 14, 2011 Share Posted November 14, 2011 I want one of these for when I replace the turbo, but not ready to buy just yet... Can you just do me a favor and give me (and the forum) a heads up in this thread if you are going to stop producing them so I can grab it? Link to comment Share on other sites More sharing options...
m sprank Posted November 14, 2011 Author Share Posted November 14, 2011 I think we have enough inventory currently for a long, long time. Link to comment Share on other sites More sharing options...
m sprank Posted November 24, 2011 Author Share Posted November 24, 2011 Happy Thanksgiving! Link to comment Share on other sites More sharing options...
m sprank Posted January 8, 2012 Author Share Posted January 8, 2012 bump for great prices. Link to comment Share on other sites More sharing options...
No DRFT Posted January 28, 2012 Share Posted January 28, 2012 Just purchased this. will have some photos of the quality when i get it! I have no control over drippie. Link to comment Share on other sites More sharing options...
chutrain Posted January 29, 2012 Share Posted January 29, 2012 You will love the quality. Well put together kit. Link to comment Share on other sites More sharing options...
m sprank Posted January 30, 2012 Author Share Posted January 30, 2012 Yay. the "Thanks" button is back! Link to comment Share on other sites More sharing options...
No DRFT Posted February 4, 2012 Share Posted February 4, 2012 Received the parts in. Overall the kit looks solid. Now if we can get the hose color to be black instead of silver, that would be great because it'll match the engine bay And not to nit pick, could you guys package the items in an organized manner? I know the business is still a one man ban, but the packaging can be much improve upon. I took some pics of the kit. Thanks again. http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3626-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3629-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3635-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3639-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3638-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3632-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3644-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3647-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3671-4-1.jpg http://img.photobucket.com/albums/v257/4A-FE/2005%20Subaru%20Legacy%20GT/IMG_3667-4-1.jpg I have no control over drippie. Link to comment Share on other sites More sharing options...
m sprank Posted February 4, 2012 Author Share Posted February 4, 2012 No black available. No colors available. That specific silicone "fyre" jacket is that color and that color only. Sorry. Even the FP kit comes in a plastic bag. Just like ours. Except we give you a sticker in the bag. Sorry, I do my best. Link to comment Share on other sites More sharing options...
chutrain Posted February 4, 2012 Share Posted February 4, 2012 Product speaks for itself. No need for fancy packaging with costs passed down to the customer. Link to comment Share on other sites More sharing options...
No DRFT Posted February 4, 2012 Share Posted February 4, 2012 Right, I know the packaging doesn't have to be over the top. Just a bit more organized and labeled that's all. And this is coming from someone who works in logistics, so I see packages everyday Just food for thought. I have no control over drippie. Link to comment Share on other sites More sharing options...
