Filtered Turbo Oil Supply Line Kit (w/ Instructions)
So the "filter" is just a screen with a baffle on the back, and a spring to keep the filter in place?
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
Hmm...
Any details on the filtering medium?
Can you get the kit without the filter (so I could use an FP -4AN inline filter)?
AN fittings do not require any kind of teflon taping. You use Teflon tape on pipe fittings only.
If you want to use SOMETHING, then a LITTLE oil-based lubricant can help prevent the threads from galling.
In an AN fitting, the threads don't do the sealing, the flared surface does.
why is that one^ much better??
It's rated for particulate filtration (3-micron). I don't know anything about the filter used in this kit.
Do you have any datasheets for this filter, Mike?
Edit: Looking at the IP&T website, it says it's a 10 micron filter.
I wish I had a better picture of the medium.
http://legacygt.com/forums/showthread.php/bolt-up-turbocharger-upgrade-119177.html?p=3611756&highlight=micron#post3611756
Filter Element: Designed and engineered for the aerospace industry, for rugged, high temperatures, and extreme filtration environments, made of pleated, 304 stainless steel, 10 micron (.000392") filtration level (same level as OEM engine oil filter), 1.000” Diameter. Totaling four square inches of effective filtration area, maximum flow of 6 gallons per minute simultaneously with no restriction. Filter elements are washable and reusable indefinitely, cleaned easily with air or soluble rinse.
Bodies: Machined on CNC from 6061 aluminum, clear bright anodize finish.
So what is this filter going to stop that the standard oil filter won't?
It's going to stop whatever the banjo filter stopped, but to a finer degree, and be easily user serviceable. At least that's my take on it.
Particulate from the heads traveling into the turbo. Turbo is last in line for oil. So oil passes through top end, then to turbo. Aftermarket turbo manufacturers have seen many bearing failures from contaminated oil.
Do you think this 10micron is fine, and the FP 3micron unnecessary?
FP is 10 Micron. Not 3 Micron. FP uses a sock style filter. http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=FP4ANFilter&Category_Code=Acc-OilLines
Dont believe every thing you read on a forum. There is tons of misinformation floating around.
Odd. I could have sworn I saw 3 micron before.
Good enough for me.
I'll need one of these, and a DW65, please!
  • 2 weeks later...
http://www.infamousperformance.net/images/store_version1/storelogo/LOGO.jpg
Everything we sell is on sale to legacygt.com members every day.
Use Promotion Code: lgt at checkout and receive 5% off your order.
No minimums or maximums. Packages on sale too.
Two ways to save. 5% off or
http://www.infamousperformance.net/promotion_banner/Shipping.JPG
It is a pre-air pump. but routing is basically the same. But, easier. Oil galley fitting is on top of the block, under the manifold. Under the turbo inlet tube on 07-09. So, it is a straight shot with a shorter line. No having to route behind the block.
