PKs17 Posted August 25, 2011 Share Posted August 25, 2011 Im looking at the specs on subaru.com, and noticed that the GT weighs in at 3477lbs/manual trans. And the 3.6R weighs in at 3587lbs with Auto. Both are limited models. Whats the deal here, i was under the impression that with the heavier 6 cylinder motor, and heavier automatic the 3.6 would weigh at least 300lbs more. Thats the case with most cars going from a 4 cylinder to 6. Anyone have more insight into this? Maybe the 3.6 is a really light unit? Link to comment Share on other sites More sharing options...
apexjapan Posted August 25, 2011 Share Posted August 25, 2011 The 3.6 isn't that much heavier than the 4, especially if you consider that the GT will have turbocharger, intercooler and other extras. Most of that weight difference is probably from the A/T rather than the engine. Physically, the 6 is only a couple inches longer than the 4. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
rao Posted August 25, 2011 Share Posted August 25, 2011 Im looking at the specs on subaru.com, and noticed that the GT weighs in at 3477lbs/manual trans. And the 3.6R weighs in at 3587lbs with Auto. Both are limited models. Whats the deal here, i was under the impression that with the heavier 6 cylinder motor, and heavier automatic the 3.6 would weigh at least 300lbs more. Thats the case with most cars going from a 4 cylinder to 6. Anyone have more insight into this? Maybe the 3.6 is a really light unit? You are never going to actually buy a car, are you? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
PKs17 Posted August 26, 2011 Author Share Posted August 26, 2011 Still looking, Its hard to buy somthing when your having so much fun in a wrx. Link to comment Share on other sites More sharing options...
