rlineberg Posted August 19, 2011 Share Posted August 19, 2011 I am getting ready to order my parts to do my timing belt. I am getting the gates kit from Fredbeans that comes with waterpump, idlers, tensioner, and belt. I am also going to replaced my right side valve cover gasket while I am in there because it has been leaking on my exhaust for a while now. (nothing like smoke rising from your hood scoop first thing in the morning) My question is about sealing the gaskets for the waterpump, thermostat, and valve cover gasket. Should I be using some sort of silicone or FUJI-BOND with the gaskets? I am pretty sure I don't, but I want to be prepared for the job. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 19, 2011 Share Posted August 19, 2011 dry is the way it is designed to be used. a thin thin application of silicone to the w/p will help the gasket stick. or some spray gasket sealant Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 19, 2011 Share Posted August 19, 2011 Might want to get yourself a copy of the vacation pics if you don't already have one: http://www.bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=210 Glad to see my old turbo is still chugging along for you. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2011 Share Posted August 19, 2011 No sealant is needed just install the way they come. I haven't done VC gaskets. The general rule with them is, if there are any sharp corners, put a small dab of silicone sealant in that area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2011 Share Posted August 19, 2011 Might want to get yourself a copy of the vacation pics if you don't already have one: http://www.bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=210 Glad to see my old turbo is still chugging along for you. Did you notice that at the top of each page in that link it say's 2004 ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 19, 2011 Share Posted August 19, 2011 Did you notice that at the top of each page in that link it say's 2004 ? Yeah, looks like that link is hosed up right now. I already have mine downloaded, so I didn't try re-downloading, just assumed they work. Here's another link which seems to be working.....at least for now. http://people.csail.mit.edu/ilh/vacation/ There's also 2008 and 2009 vacation pics there too. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 19, 2011 Share Posted August 19, 2011 I am getting ready to order my parts to do my timing belt. I am getting the gates kit from Fredbeans that comes with waterpump, idlers, tensioner, and belt. I am also going to replaced my right side valve cover gasket while I am in there because it has been leaking on my exhaust for a while now. (nothing like smoke rising from your hood scoop first thing in the morning) My question is about sealing the gaskets for the waterpump, thermostat, and valve cover gasket. Should I be using some sort of silicone or FUJI-BOND with the gaskets? I am pretty sure I don't, but I want to be prepared for the job. Here is our take on them after doing a ton of TB/WPs and this is what we do for our customers when we do a Timing Belt setup. Gates Timing Belt Kit w/WP OEM Water Pump Gasket OEM Thermostat w/OEM Gasket Also shoot us an e-mail or call and we can probably match any prices you see for the kits online. -mike sales@azpinstalls.com 908.284.2971 Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2011 Share Posted August 19, 2011 Yeah, looks like that link is hosed up right now. I already have mine downloaded, so I didn't try re-downloading, just assumed they work. Here's another link which seems to be working.....at least for now. http://people.csail.mit.edu/ilh/vacation/ There's also 2008 and 2009 vacation pics there too. I pm'ed him that link. It's been working for years. Also you may want to be careful posting that. Some of the MOD's or Fourm owners don't like that being put out there. OP +1 for buying from AZPinstalls, they help out a lot here everyday for free. Support them when you can. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 19, 2011 Share Posted August 19, 2011 Some of the MOD's or Fourm owners don't like that being put out there. I just copied it and pasted it from the other thread (its already in at least two earlier threads that I know of). Should we just link to the other threads or tell them to search for vacation pix? Link to comment Share on other sites More sharing options...
rlineberg Posted August 19, 2011 Author Share Posted August 19, 2011 Thanks for the input guys, and especially the vacation pics. Does the gates timing kit come with a new water pump gasket? Link to comment Share on other sites More sharing options...
AZP Installs Posted August 19, 2011 Share Posted August 19, 2011 The Gates kit does include a gasket but it's one of those paper style ones and we have not felt comfortable in using them. That's why we include the OEM ones when we do the installs or sell the kits. -mike Link to comment Share on other sites More sharing options...
