I Donated broknindarkagain Posted August 9, 2011 I Donated Share Posted August 9, 2011 any EJ heads will bolt onto any EJ block. The thing you have to worry about is high speed valve interference when you run a thin headgasket. I believe this was covered in the turbo faq....n00b! lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted August 9, 2011 Share Posted August 9, 2011 O shut it John its been a while since I've read the turbo faq Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 9, 2011 I Donated Share Posted August 9, 2011 O shut it John its been a while since I've read the turbo faq Sent from my DROID X2 using Tapatalk my name is bob -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted August 9, 2011 Share Posted August 9, 2011 fine bob.... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 9, 2011 I Donated Share Posted August 9, 2011 you cant swap vin tags Yes you can. Its just not legal. But it is possible to illegaly do -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Reuben Posted August 9, 2011 Share Posted August 9, 2011 Yeah, but i dear say it'd bea easier to swap tags, and make it look factory, than swap everything onto an outback chassis. It's techncially safer to swap tags too, you're doing less firewall chopping that way And regards to swapping heads and blocks, yes, any EJ head will bolt to an EJ block. But you can't use bigger heads on smaller blocks, like 2.5 heads on a 2L block - Because the cyl bore is smaller than the combustion chamber. Other than that though, most will work. In some cases, you'll need new pistons too, as some combinations of block mixed with heads can lead to valves hitting pistons. I.e. early and late EJ20G's, can swap heads, but gotta swap pistons with them, late heads and early pistons will clash. Using 2L STi/GTB heads on a 2.2 block is fine, but new pistons are implied, you'd need some that are lower compression anyway. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 9, 2011 I Donated Share Posted August 9, 2011 You can run thicker head gaskets to compensate for that. The EJ20R comes stock with 1.6 gaskets to avoid high speed valve interference. New pistons are not "needed". There is a cheaper work around that works just as good -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted August 10, 2011 Share Posted August 10, 2011 well since where on that subject who thinks Any 2.2 built and turbo'd with a 04 STI head would be epic win?? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 10, 2011 I Donated Share Posted August 10, 2011 A EJ257 with wrx heads would be better. Super compression! lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted August 10, 2011 Share Posted August 10, 2011 hmmmmm... But i like the 22 Link to comment Share on other sites More sharing options...
Jab83 Posted August 10, 2011 Share Posted August 10, 2011 but I see.. i dont even know what ej257 is from. lol.!@_@ Link to comment Share on other sites More sharing options...
Reuben Posted August 10, 2011 Share Posted August 10, 2011 EJ257 is the 2.5L STi engine. Compression is for N/A drivers. My ideal CR is 8:1. I like lag, I like high boost. There's something so unbelievably good about that whack in the back at 4000rpm, and holding it to 8000rpm My next build is going to be with STi EJ20K heads, and a 22 block. I'm not going anywhere near anything with "25" in the tag. We do things differently in NZ, that's all. I don't doubt a 25 is fun, but it aint my bag. Link to comment Share on other sites More sharing options...
Jab83 Posted August 10, 2011 Share Posted August 10, 2011 thats my plan is a 22 build Link to comment Share on other sites More sharing options...
babybaluga32 Posted August 10, 2011 Share Posted August 10, 2011 Brokningdark.. I always thought your car seemed light years cooler than just to be at a wii dinky 15psi..... and a td04 :o! I met a guy with 22 with forged internals at 15 psi ..It was a black 98 outback sport.. http://www.excalibur-publishing.co.uk/streetcleaning.htm I want this...! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 10, 2011 I Donated Share Posted August 10, 2011 babybaluga, My car has had a few different turbos on it. It had a GT3076R on it at 13psi, but it was a little too much turbo for the engine. I have it tuned now on the TD04 at 15psi because of the headgaskets. I can push the TD04 to about 18psi and that gets me closer to 300 at the wheels....I'll probably put a 16g at 15psi or so after i fix my blown up engine lol WHAT THE HELL is that link? lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Reuben Posted August 10, 2011 Share Posted August 10, 2011 I'm running a VF39 on mine at 18psi. It's a good combo (late spool, but doesn't taper off, perfect in my book). The block can take more, easy, but my fueling can not (still factory STi ECU on the yellows). 18psi is plenty I think anyway. Link to comment Share on other sites More sharing options...
Jab83 Posted August 10, 2011 Share Posted August 10, 2011 mmmmmm. that sounds like a really fun car that can probably keep up with almost anything. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted August 10, 2011 Share Posted August 10, 2011 Reuben's Wag is just plain sick! Gotta love the sound of that set up. Link to comment Share on other sites More sharing options...
Reuben Posted August 11, 2011 Share Posted August 11, 2011 I love it to pieces, more need not be said. I have a standing open offer btw gents, for anyone on holiday down this way, it is my DUTY to take you guys for a blat, and show you some of that kiwi hospitality. http://i197.photobucket.com/albums/aa208/Pilot_Reuben/GTB/IMG_1370-1.jpg Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 11, 2011 I Donated Share Posted August 11, 2011 I want to open it up on the road in that pic! You have some of the best driving roads in the world over there. I'm jelous -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 11, 2011 Share Posted August 11, 2011 thats so true.. plus the corners are slighty banked everywhere. BNR18g on 93oct Link to comment Share on other sites More sharing options...
TbirdMan Posted August 11, 2011 Share Posted August 11, 2011 I live around some great driving roads too, I am about 20min from the Blue Ridge Parkway and a couple hours from Tail of the Dragon, 318 turns in 11mi. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 11, 2011 I Donated Share Posted August 11, 2011 I live around some great driving roads too, I am about 20min from the Blue Ridge Parkway and a couple hours from Tail of the Dragon, 318 turns in 11mi. I still have to visit the dragon. I'm at Blood Mountain (Suches, GA) all the time though. Fun roads -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted August 11, 2011 Share Posted August 11, 2011 The dragon is in east tn right? Or am I thinking of a diff road. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
Reuben Posted August 12, 2011 Share Posted August 12, 2011 Yeah you guys do have nice roads stateside. The difference is here, we have the camber to go with, and we don't have a million people trying to do the only good ones around on the weekends Link to comment Share on other sites More sharing options...
