GTCanada Posted June 5, 2005 Share Posted June 5, 2005 I saw a recommendation for this in a thread (can't remember which one) and picked up a tube. It worked beautifully on some minor paint blemishes. Tom Link to comment Share on other sites More sharing options...
jarrod Posted June 5, 2005 Share Posted June 5, 2005 where did you purchase it at? Link to comment Share on other sites More sharing options...
Aczwild Posted June 5, 2005 Share Posted June 5, 2005 How minor are you talking, the back wing and hood of my GT looks like a cat without its claws clipped walked all over it. I have been looking for something to fix all of the scratches. JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
jarrod Posted June 5, 2005 Share Posted June 5, 2005 he probably means like minor swirls etc? Link to comment Share on other sites More sharing options...
GTCanada Posted June 5, 2005 Author Share Posted June 5, 2005 It should be available off the shelf almost anywhere that carries the Meguiars line. It is quite common. I think it was less than $10 so it does not cost much to see if it works for you. I used it on some scratches on the lower door panels that appeared to be from small rocks grazing the paint. Tom Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 5, 2005 Share Posted June 5, 2005 It does work well. I had a scratch where someone leaned with their purse and it cleaned it up very well. You can still see where it was in direct sunlight, but I'm happy with the imporvement. Link to comment Share on other sites More sharing options...
OCDetails Posted June 5, 2005 Share Posted June 5, 2005 Just so everybody is clear, this product is NOT for minor swirls. It is for scratches. That's why its called "ScratchX" and not "SwirlX". This is one of the most abrasive products that Meguiar's makes and not something for minor surface swirld. They make other stuff specifically for swirls. ScratchX is meant for individual scratches that you get or for removing paint swapping from door dings. Its not for swirls. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
jt51 Posted June 13, 2005 Share Posted June 13, 2005 I have a long scratch I can not feel with my finger nail, I have tried Scratch X and it did no good on removing it, any suggestions? Link to comment Share on other sites More sharing options...
OCDetails Posted June 13, 2005 Share Posted June 13, 2005 If scratchX didn't remove it then the next step is to have it polished out by machine. If you don't have one that will work then you can take it to a detail shop and get their opinion on if its something that can be polished out or if it needs to be touched up. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
IAHAWK Posted June 13, 2005 Share Posted June 13, 2005 Just so everybody is clear, this product is NOT for minor swirls. It is for scratches. That's why its called "ScratchX" and not "SwirlX". This is one of the most abrasive products that Meguiar's makes and not something for minor surface swirld. They make other stuff specifically for swirls. ScratchX is meant for individual scratches that you get or for removing paint swapping from door dings. Its not for swirls. I disagree. I use Scratch X on my dark blue motorcycle to take out minor surface "swirl" or what I think of more as abrasion scratches. I have tried it on larger scratches and it does not work. Great stuff..I would recommend it to all! Link to comment Share on other sites More sharing options...
SC GT Posted June 13, 2005 Share Posted June 13, 2005 So after using ScratchX, do you recommend following up with a polish then a sealant? Link to comment Share on other sites More sharing options...
OCDetails Posted June 14, 2005 Share Posted June 14, 2005 ScratchX is a polish. I have spoken to people at Meguiar's and they assure me that ScratchX is not meant to be used on the entire car. Bath towels were not meant to dry entire cars either, but people do that. If you decide to use ScratchX on your entire car then just be prepared for the results. I've seen the haze this product can create and it just puts you in a cycle of hand polishing that never ends. You'd do better with a normal polish for your swirls and a Porter Cable 7424. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
SVXWRX Posted June 14, 2005 Share Posted June 14, 2005 try 3M Imperial Hand Glaze for scratches (vigorously) - great stuff. use it on the whole car before waxing, and it will look like a mirror. Link to comment Share on other sites More sharing options...
