gil_ong Posted May 9, 2011 Share Posted May 9, 2011 has anyone installed an oil catch can on their 4th gen? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 9, 2011 Share Posted May 9, 2011 There may be a few. I have a air/oil seperator. It's fine in the warm weather, but the moisture condensates in the filler cap in cold weather. I'm sure you've checked out the number of STi and WRX's that have catch can's. IMO not worth the effort unless you want max HP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gil_ong Posted May 9, 2011 Author Share Posted May 9, 2011 in the next few weeks, i'm gonna have my TMIC off and getting into a bunch of other stuff in preparation for a stage 2 tune. figured i might as well hook this think up while i'm at it. honestly, i have looked at the WRXs and STis. just really not sure how similar they are to the LGT. are all the 2.5 engines the same? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 9, 2011 Share Posted May 9, 2011 The shop that did my set up, looked at a Sti they had to see how everything went. So I guess they are real close. When I ordered my kit, I was the only Legacy guy in on the group buy over at NASIOC. There is a little difference but they figured it out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gil_ong Posted May 9, 2011 Author Share Posted May 9, 2011 thanks. i'll look into it. Link to comment Share on other sites More sharing options...
jagcars26 Posted May 9, 2011 Share Posted May 9, 2011 IMO not worth the effort unless you want max HP. Agreed,not worth your time or money. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 9, 2011 Share Posted May 9, 2011 but the moisture condensates in the filler cap in cold weather. ...which becomes warm weather once the car is running, right? I wouldn't bother with a catch-can. I would bother with an air/oil seperator. But the price seems pretty steep... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
planelazy Posted May 9, 2011 Share Posted May 9, 2011 It's only required when you're pushing a certain HP or on some tracks isn't it? In otherwords, it's not worth it on a DD Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 9, 2011 Share Posted May 9, 2011 It's not REALLY needed, no. But it IS useful if you have excessive blow-by. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rao Posted May 9, 2011 Share Posted May 9, 2011 So that means it is needed for all turbo Subarus?? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 9, 2011 Share Posted May 9, 2011 Probably! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
gotbeef Posted May 9, 2011 Share Posted May 9, 2011 it's definitely a good thing to have but it's also very difficult to do it correctly. i had a dual catch can setup on my 2008 wrx (same engine as lgt) and because of the space limitation i used hoses that were too small and the catch cans were easily overwhelmed by the engine. i also have heard many stories of AOS systems being overwhelmed especially in track situations. i have since removed my catch can setup and evaluating a better catch can setup or grimmspeed style AOS. as far as AOS systems go, there is a bit of concern about contaminated blow-by re-entering the engine but nobody has done enough research (used oil anaylsis, etc) to say that contamination is bad for the engine. my recommendation would be install catch cans if you know what your doing, if not stick with stock or go with AOS. Link to comment Share on other sites More sharing options...
FJuan Posted May 9, 2011 Share Posted May 9, 2011 To do a true catch can on our cars, it would require using 2 of them. 1 connected to the vent hoses coming from the valve covers and 1 connected to the PCV assembly. I only have 1 can connected right now to the valve cover vent hoses as I used to see a lot of blow by (oil) in my I/C and intake hose. When I used to take off the I/C, I could see a small puddle of oil sitting in the intake hose connected to the manifold. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted May 9, 2011 Share Posted May 9, 2011 Probably! Only if they're using the wrong oil. Link to comment Share on other sites More sharing options...
gil_ong Posted May 10, 2011 Author Share Posted May 10, 2011 yeah. i can't believe how much a AOS costs! Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 10, 2011 Share Posted May 10, 2011 <= PCV deleted. Crankcase line dump to saiku michi catch can. Port on manifold for pcv capped for now. Link to comment Share on other sites More sharing options...
gil_ong Posted May 13, 2011 Author Share Posted May 13, 2011 do i have blow by? turbo side of the TMIC. http://farm3.static.flickr.com/2235/5716653149_2705a9d4e6_z.jpg http://farm3.static.flickr.com/2620/5717221662_3a5b0d2f19_z.jpg Link to comment Share on other sites More sharing options...
FJuan Posted May 13, 2011 Share Posted May 13, 2011 Yes you do, mine looked exactly like that. Time to clamp the clips back down and JB Weld it or buy an aftermarket I/C. I went with the JB Weld and everything so far is holding strong. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
gil_ong Posted May 13, 2011 Author Share Posted May 13, 2011 i've got Seeeeya's "bullet-proof TMIC kit" that i'll install shortly. but that just keeps the stuff in the TMIC right? i'm thinking more along the lines of "gil's gonna need an oil catch can (or two)" to not screw things up any more. Link to comment Share on other sites More sharing options...
spec.B Dream Posted May 14, 2011 Share Posted May 14, 2011 If you go catch can, make sure to get one that fits. My parts guy talked me into an EQ Tuning catch can. It was huge and we couldn't find a suitable place to install it. I ended up selling it and going with a GrimmSpeed AOS and couldn't be happier. Link to comment Share on other sites More sharing options...
gil_ong Posted May 14, 2011 Author Share Posted May 14, 2011 i have a perrin. in the process of sourcing another one. Link to comment Share on other sites More sharing options...
Stock_Sucks Posted May 15, 2011 Share Posted May 15, 2011 just installed my grimspeed AOS.... pita to install, but def worth it to me. I go through 1-2 quarts of oil every 1000miles or so... I had a good amount of oil in the intake system and it made the end tank seals swell on my IC and then it just popped open one day.... now I have the AOS, AVO inlet hose in, and a used OEM TMIC going in when it arrives. Link to comment Share on other sites More sharing options...
