73datsun Posted May 3, 2011 Share Posted May 3, 2011 I installed Epic Engineering springs on my LGT this weekend. I retained my OEM struts. (don't ask, I'm still not sure why I wasted my time). The front OEMs were completely fine. The rears however took quite awhile to rebound. I was quite surprised as the car only has 58k miles, isn't thrashed on and nothing heavy is repeatedly kept in the trunk. Is this pretty standard? I also botched my saggy butt spacer install as I didn't order longer studs, wish Fred Beans had mentioned that when we talked on the phone. Oh well, I guess I'll put them in when I do the suspension. Again. edit: car is a 2006 LGT sedan Link to comment Share on other sites More sharing options...
bluesuby Posted May 3, 2011 Share Posted May 3, 2011 I changed out the struts at about 70,000 miles. They always felt too soft and could have been done earlier. Link to comment Share on other sites More sharing options...
cypher0117 Posted May 5, 2011 Share Posted May 5, 2011 I'm going to be putting konis into my car in the next month or so. About a month ago I installed Eibach springs (same as Epic springs) and I have noticed that the car feels way too underdamped. Did feel that way initially. It took about a week or so on the Eibach springs to have the struts feel inadequate. On stock springs the struts would probably last to 100k miles, on aftermarket springs they will be overworked and have their life shortened. I'm at 61k and my car oscillates almost 2.5 times (up down up down up) from medium to large bumps. I think my rears are worse than my fronts as they are starting to make noise after ~ 2000 miles with the Eibach springs on them. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 6, 2011 Share Posted May 6, 2011 Since we see a ton of Subies, and even more LGTs come through our shop, I'd say the average life span of stock struts with stock springs is about 70k miles. Once you put on lowering springs, then you are looking at a reduction of about 25% or so on them. The stock struts will also be under-dampened for lowered cars too. GR-2s are adequate for EPIC/Eibachs, anything lower than that you will want Konis or Bilsteins on the car. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
cypher0117 Posted May 6, 2011 Share Posted May 6, 2011 I thought GR-2s were barely siffer than stock? Link to comment Share on other sites More sharing options...
AZP Installs Posted May 6, 2011 Share Posted May 6, 2011 The GR2s are a bit stiffer than stock and will hold up to the Eibachs/Epics that's why I said "Adequate" as opposed to optimal. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
thestratomaster Posted May 6, 2011 Share Posted May 6, 2011 I was really hoping to get more life out of my struts (73k miles) but have noticed they've gotten very soft and bouncy recently might be time to upgrade! Link to comment Share on other sites More sharing options...
AZP Installs Posted May 6, 2011 Share Posted May 6, 2011 73k is about all you'll get on any car. It is considered a wear and tear item, it isn't covered under most extended warranties for this reason. -mike Link to comment Share on other sites More sharing options...
thestratomaster Posted May 6, 2011 Share Posted May 6, 2011 Yeah I know, I was holding out for 80k haha Link to comment Share on other sites More sharing options...
AZP Installs Posted May 6, 2011 Share Posted May 6, 2011 haaaaaa! Link to comment Share on other sites More sharing options...
thestratomaster Posted May 7, 2011 Share Posted May 7, 2011 what do you recommend as a moderately sporty setup? I'm probably gonna pick up some rallitek springs this summer. The roads around here suck, but I want to get something that's a little bit more performance oriented Link to comment Share on other sites More sharing options...
AZP Installs Posted May 7, 2011 Share Posted May 7, 2011 For a mid-range setup that isn't as pricey as the Konis, I would say the Tokicos. We've installed a few sets of them for customers and they like them. The Konis are really the cat's meow but I know it is sometimes out of people's budgets. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
mk6933 Posted May 7, 2011 Share Posted May 7, 2011 I thought Tokicos are more expensive then Konis Link to comment Share on other sites More sharing options...
soloz2 Posted May 7, 2011 Share Posted May 7, 2011 I've got 88k on the stock suspension. When I purchased the car with 82k the suspension still felt pretty good, but I must be rougher on it than the previous owner as it seems to be deteriorating fast. From my past experiences struts tend to last between 60-100k depending on the car and strut quality. I got 140k out of the struts on my Chrysler before I really had to replace them, and they were good up until about 120k. Looking back I should have replaced them around there... Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Catalyst Posted May 7, 2011 Share Posted May 7, 2011 ~140 on stock and it leans like a sailboat, lol. Getting em soon. "This is an adventure." Link to comment Share on other sites More sharing options...
