Endlinks rusted out
doctorbrody
I was under the car yesterday and saw that one of my AVO 90mm adjustable rear endlinks had come apart. The threads connecting the top and bottom had rusted out and would not screw back together and hold. I JB Welded it back together, clamped it overnight, and it's holding fine for now.
Obviously this is not a permanent solution. I don't want new adjustable endlinks if they'll just rust out next winter, and the stock ones bent with my 20mm RSB so I'm not going back to stock.
Does anyone know if the 70mm solid endlinks will work with a stock height OBXT? Or if there is a 90mm solid option out there?
I had had problems with the rallitek ones, on the stock height. They are much shorter then the stock ones.
Rallitek recently released an updated version of their rear endlinks that fixed the problems people were having with them. This is the part number i received from them: RTK-HD-ELR
  • 4 months later...
