25gtrbo Posted April 25, 2011 Share Posted April 25, 2011 http://www.bbc.co.uk/news/science-environment-13160950 Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 25, 2011 Share Posted April 25, 2011 IBAustinPowersReference [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
camber Posted April 25, 2011 Share Posted April 25, 2011 pew.. pew... pew pewwwww:lol: Link to comment Share on other sites More sharing options...
Envy Posted April 25, 2011 Share Posted April 25, 2011 I need a, Direct Injected, Laser Ignited, Star Wars Ti-Fighter. Link to comment Share on other sites More sharing options...
ehsnils Posted April 25, 2011 Share Posted April 25, 2011 And the injectors will change from being magnetically opened to being opened by a piezo crystal instead. This to improve the precision. Link to comment Share on other sites More sharing options...
Lardo420 Posted April 27, 2011 Share Posted April 27, 2011 that just blew my mind Link to comment Share on other sites More sharing options...
joelwatts Posted April 27, 2011 Share Posted April 27, 2011 hmm. it's an interesting thought. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
urfsin Posted April 27, 2011 Share Posted April 27, 2011 Why not? The Internal Combustion Engine is lagging bad in some technological ways. I think camshafts are the next thing to go.....with computer technology you could activate the valves based on an electronic signal rather than some chunk of metal spinning around. It would eliminate a fair amount of drag on the engine and increase HP / efficiency. Slide It Sideways Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted April 27, 2011 Share Posted April 27, 2011 Why not? The Internal Combustion Engine is lagging bad in some technological ways. I think camshafts are the next thing to go.....with computer technology you could activate the valves based on an electronic signal rather than some chunk of metal spinning around. It would eliminate a fair amount of drag on the engine and increase HP / efficiency. Already in the works. http://www.eetimes.com/electronics-news/4167805/Electronic-controls-to-replace-camshafts-in-diesel-engines Link to comment Share on other sites More sharing options...
urfsin Posted April 28, 2011 Share Posted April 28, 2011 Good, its about time! Slide It Sideways Link to comment Share on other sites More sharing options...
f1anatic Posted April 28, 2011 Share Posted April 28, 2011 Why not? The Internal Combustion Engine is lagging bad in some technological ways. I think camshafts are the next thing to go.....with computer technology you could activate the valves based on an electronic signal rather than some chunk of metal spinning around. It would eliminate a fair amount of drag on the engine and increase HP / efficiency. F1 engines have been using pneumatic valve control systems for some 20 years now. Read more here. Claims of much improved efficiency are a bit preposterous. Modern engines are already igniting and burning the entire fuel mixture. If anything it would allow more control over timing and give a little wiggle room with leaner mixtures. That being said, if spark plugs were the drawback in terms of modern engine efficiency, one would think every car maker would have copied Alfa Romeo / FIAT Twin Spark engines. As for me, I use Pulstar or Nology spark plugs and the Tornado Air Supercharger to improve my efficiency and burn more than 100% of the mixture. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 28, 2011 Share Posted April 28, 2011 As for me, I use Pulstar or Nology spark plugs and the Tornado Air Supercharger to improve my efficiency and burn more than 100% of the mixture. I've heard good things about this combination. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
f1anatic Posted April 28, 2011 Share Posted April 28, 2011 I've heard good things about this combination. RAO has it on his BMWette; we saw it last night at the meet that you did not attend. Your friends came over though. Link to comment Share on other sites More sharing options...
Code Posted April 28, 2011 Share Posted April 28, 2011 I burn 110% of my fuel mixture, but I'm always spinning out ..... "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
joelwatts Posted April 28, 2011 Share Posted April 28, 2011 Claims of much improved efficiency are a bit preposterous. Modern engines are already igniting and burning the entire fuel mixture. If anything it would allow more control over timing and give a little wiggle room with leaner mixtures. That being said, if spark plugs were the drawback in terms of modern engine efficiency, one would think every car maker would have copied Alfa Romeo / FIAT Twin Spark engines.QUOTE] Ford used a twin spark system on the 2.3l ranger for a while. chrysler uses it on the hemi and new generation 4.7l. and i'm sure others have done so as well. but i do believe that spark plug technology is "good enough" for the time being that the cost of any alternative methods are too high for bean counters to allow r&d from the factory. they usually let a university or outside company do that, then buy it from them. its easier that way. keeps the manufacturers from spending time developing something that may not be as cost effective. 20 years ago, this wasn't the case. but now (since no one has any money) they don't do alot of r&d in they way of completely new technology. well, for the most part. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
urfsin Posted April 28, 2011 Share Posted April 28, 2011 F1 engines have been using pneumatic valve control systems for some 20 years now. Read more here. Hmmm, I did not know that....you learn something new everyday! Slide It Sideways Link to comment Share on other sites More sharing options...
ehsnils Posted April 28, 2011 Share Posted April 28, 2011 Why not? The Internal Combustion Engine is lagging bad in some technological ways. I think camshafts are the next thing to go.....with computer technology you could activate the valves based on an electronic signal rather than some chunk of metal spinning around. It would eliminate a fair amount of drag on the engine and increase HP / efficiency. Camshafts are there because they are cheap and reliable. Of course - if the engine makers could they would build 2-stroke engines because they are even cheaper to build and you can get a lot of top power for the cost but they suck when it comes to drivability and fuel economy so... But don't forget that other valve technologies will also require power to operate, so maybe the camshafts aren't such bad idea after all. The variable timing camshafts are one solution and using a CVT gearbox another. And for those that thinks that CVT gearboxes sucks - it's because they are tuned for fuel economy, not power. Just look at the FW15C which got banned from ever racing in F1. However you can also look at what Ducati does - their desmodromic (desdemonic ) valve technology. They are doing really well, but they require a bit more maintenance than ordinary valve tech. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 28, 2011 Share Posted April 28, 2011 No one thinks CVT's suck. Just that they aren't as fun to drive. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
MasAyinde Posted May 20, 2011 Share Posted May 20, 2011 I think we've all seen the inside of a combustion chamber. Wouldn't it take just a few seconds of running rich to cover up and block the laser light? Link to comment Share on other sites More sharing options...
