deneb Posted May 24, 2005 Share Posted May 24, 2005 My LGT had a rough weekend! 1) I scraped the passenger side front wheel against the curb when parallel parking, anyone know a fix for a scraped wheel? I'm thinking some sort of file/sandpaper to sand the alloy smooth, and then perhaps some sort of touch up for the finish? 2) My son stepped in gum, now it's all over the pass side front floor mat. Anyone know how to get gum out of a floormat? On the good side, I washed the car yesterday, and performed step 1 (cleaner) and step 2 (polish) of the three step Meguire's routine, the polish seems to REALLY like Garnet red, it really deepens that color. Can't wait to wax it today! Thanks all for your help! Link to comment Share on other sites More sharing options...
c-lo Posted May 24, 2005 Share Posted May 24, 2005 sorry to hear about the wheel. As for the gum.....old trick we used to do when I worked in the hotel industry was to take canned air, turn it upside down and pull the trigger. it should freeze the hell out of the gum. It should break off in pieces. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted May 24, 2005 Share Posted May 24, 2005 Freezing the gum is usually the best. Second try is to use some peanut butter on the gum. I am going to take my dremel with a buff pad & some compound to smooth out my rim scrape. Then just clear over it. Jesse Link to comment Share on other sites More sharing options...
OCDetails Posted May 24, 2005 Share Posted May 24, 2005 Freezing and peanut butter are the two best suggestions for the gum. One of those two will work. This is how you fix the wheel yourself. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
D-2.5-GT Posted May 24, 2005 Share Posted May 24, 2005 i'd be careful with the PB, the oil could stain it all over. Generally this is a good solution, but only on certain surfaces. Link to comment Share on other sites More sharing options...
Aczwild Posted May 24, 2005 Share Posted May 24, 2005 Ice cubes work well too to freeze it JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
deneb Posted May 25, 2005 Author Share Posted May 25, 2005 Thanks all for the replies!!! I appreciate the help. Link to comment Share on other sites More sharing options...
