ama0787 Posted March 31, 2011 Share Posted March 31, 2011 Like the title says why is the compressor used when heating the car? I would have thought it shouldn't be on but with the Suby defogging always kicks the compressor on and it also uses the compressor lots when in auto mode and heating the car. Anyone with info on this please explain. TIA, Anrhony Link to comment Share on other sites More sharing options...
rao Posted March 31, 2011 Share Posted March 31, 2011 Every auto ac system works this way. They all have an ac switch or an "economy" switch to turn the compressor off. The AC dehumidifies the air and keeps the windows from fogging up. The AC compressor will be shut off when the temps get very cold so that the compressor isn't damaged. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
cypher0117 Posted March 31, 2011 Share Posted March 31, 2011 When in auto mode the A/C light comes on but that doens't mean the compressor is on. It's just an available option for the climate control to use if needed. As for defogging the windows the compressor dries out the air so you're not blowing moist/damp air on cold windows. Link to comment Share on other sites More sharing options...
pillboy Posted March 31, 2011 Share Posted March 31, 2011 It keeps your balls from sweating when you have your snow pants on. It is still ugly. Link to comment Share on other sites More sharing options...
frank_ster Posted March 31, 2011 Share Posted March 31, 2011 It keeps your balls from sweating when you have your snow pants on. ^ exactly ! and a/c realy doesn't take much power to harm fuel economy Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ama0787 Posted March 31, 2011 Author Share Posted March 31, 2011 When in auto mode the A/C light comes on but that doens't mean the compressor is on. It's just an available option for the climate control to use if needed. As for defogging the windows the compressor dries out the air so you're not blowing moist/damp air on cold windows. If the a/c light is on your compressor is also on unless it's broke. So the consensus is it removes the humidity to help defog the air and also make it more comfortable. Thanks for the replies. Link to comment Share on other sites More sharing options...
burnout8488 Posted April 1, 2011 Share Posted April 1, 2011 If the a/c light is on your compressor is also on unless it's broke. No. In Auto mode, the auto-climate will cycle it on/off as necessary, while the A/C light remains lit. Link to comment Share on other sites More sharing options...
cypher0117 Posted April 1, 2011 Share Posted April 1, 2011 This explains it well: http://legacygt.com/forums/showpost.php?p=99569&postcount=1 Link to comment Share on other sites More sharing options...
