drewk2 Posted October 24, 2011 Share Posted October 24, 2011 My problem was that the trunk release cable was stretched out too far ie having too much slack in it, which was a manufacturing defect. I see no reason why it should not be covered if you are having similar symptoms. From what I know, the only time a dealer will replace anything for free is if the car is still under warranty, or a part is covered under some type of recall program. My dealer is a 60 mile round trip, so I don't want to waste my time if they aren't going to fix it for free. I'll probably call them first to see what they say. Anyone else here get their trunk release fixed for free by the dealer, even if your car was not under warranty? Link to comment Share on other sites More sharing options...
Horarik Posted January 3, 2012 Share Posted January 3, 2012 Sorry back from the dead: I found that with my trunk if I pull the latch from inside the vehicle the trunk will unlatch and i can open it fine if I DO NOT shut my door. It seems the shock from shutting any of my doors will cause the trunk to re-latch itself. Does this sound it would be fixed by getting the cable replaced?? Link to comment Share on other sites More sharing options...
Shotokan1509 Posted January 3, 2012 Share Posted January 3, 2012 Sorry back from the dead: I found that with my trunk if I pull the latch from inside the vehicle the trunk will unlatch and i can open it fine if I DO NOT shut my door. It seems the shock from shutting any of my doors will cause the trunk to re-latch itself. Does this sound it would be fixed by getting the cable replaced?? I have the trunk issues, and I agree with you there is a much better chance of it opening with inside latch if I do not close the driver door. Link to comment Share on other sites More sharing options...
Lardo420 Posted January 3, 2012 Share Posted January 3, 2012 Sorry back from the dead: I found that with my trunk if I pull the latch from inside the vehicle the trunk will unlatch and i can open it fine if I DO NOT shut my door. It seems the shock from shutting any of my doors will cause the trunk to re-latch itself. Does this sound it would be fixed by getting the cable replaced?? sounds like a latch problem. try spraying some PB Blaster in there and see if it helps. If that doesnt work, Id say its your cable not pulling the latch open enuf Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted January 6, 2012 Mega Users Share Posted January 6, 2012 Yep, I bought my 05 new on late jun 04, 142,000 miles, there is no warranty. how difficult was this to do, and do you really need to rip up the whole interior? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Max Capacity Posted January 6, 2012 Share Posted January 6, 2012 how difficult was this to do, and do you really need to rip up the whole interior? How difficult is what to do ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TheDon427 Posted January 6, 2012 Share Posted January 6, 2012 My '08 Spec.B is a bitch to open sometimes where I have to use force to break the seal and open the trunk. The latch and key fob both work, but the trunk doesn't pop open. I'm going to call the dealer today. I bought the car with 7,600 miles on it and it's been happening since then so I don't think the cable should be worn out in such a short period of time. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted January 6, 2012 Mega Users Share Posted January 6, 2012 Sounds like what my 05 wagon was doing. I ended up buying the whole $62 mechinism and only using the white plastic acturator. It's held on by 2 brass color screws. Works fine now. I should have updated this back in May. Seems to be a normal problem the parts manager knew what I needed. sorry a little out of it today:). The trunk release mechanism replacement. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Ohitsspencer Posted January 6, 2012 Share Posted January 6, 2012 I didn't realize this was so common, because I have this as well. The only way I can pop my trunk is with the key fob and the car turned off. Also, the key has to be out of the ignition completely. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 6, 2012 Share Posted January 6, 2012 sorry a little out of it today:). The trunk release mechanism replacement. Pretty easy. In the wagon there is a small panel that pops off, a couple of screws and a connector and it's replaced. The truck on the Spec takes a man to break the seal, but it alway's opens. I should rub a little silicone grease on the seal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
drewk2 Posted January 7, 2012 Share Posted January 7, 2012 This problem seems so common, that I am surprised that a recall to fix this has not been issued. Link to comment Share on other sites More sharing options...
drewk2 Posted March 22, 2012 Share Posted March 22, 2012 go to dealer, trunk cable will be replaced for free Has ANYONE who owns a Legacy that is out of the warranty period gotten the Subaru dealer to replace the trunk release cable for free? Link to comment Share on other sites More sharing options...
jmfspecb Posted December 27, 2012 Share Posted December 27, 2012 So is the fix to this problem replacing the cable or the latch actuator mechanism? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 27, 2012 I Donated Share Posted December 27, 2012 This is happening on my Spec.B too. How many of the people with this problem have spoilers? My theory has been that the spoiler is too heavy and it holds the trunk lid down when you try to pop it. Link to comment Share on other sites More sharing options...
underground000 Posted December 27, 2012 Share Posted December 27, 2012 Since this thread was bumped:lol: Was having the problem when cold. Took off my spoiler and the trunk releases and flies open now when I barely lift it:lol: seemed like my was the torsion bars wearing out. Never tried the cable replace/tension and wouldn't you know that the dealer couldn't replicate the problem:rolleyes: 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 27, 2012 I Donated Share Posted December 27, 2012 Since this thread was bumped:lol: Was having the problem when cold. Took off my spoiler and the trunk releases and flies open now when I barely lift it:lol: seemed like my was the torsion bars wearing out. Never tried the cable replace/tension and wouldn't you know that the dealer couldn't replicate the problem:rolleyes: Did you replace the torsion bars? If so, got any part numbers? Link to comment Share on other sites More sharing options...
jmfspecb Posted December 28, 2012 Share Posted December 28, 2012 @ thefultonhow - my Spec came with the factory spoiler - dang it. I added some sound dampening material to the trunk lid as well, so that probably doesn't help it. I took the car to the dealer (to install an ACT clutch) and the good folks at Don Beyer Subaru (I don't work there) did some research and came up with the following part numbers for "accessory torsion bars" : e721sag020 and e721sag030. I'll probably get that stuff ordered and installed at some point in the next couple of weeks. But, if someone else gets the stuff installed, I'd like to know if works. Link to comment Share on other sites More sharing options...
jmfspecb Posted December 28, 2012 Share Posted December 28, 2012 And man do I need to update my avatar... Link to comment Share on other sites More sharing options...
planelazy Posted December 28, 2012 Share Posted December 28, 2012 I've been told that there is a stiffer torsion bars specifically for the trunks with a spoiler. Mine are worn out too, I'll buy new ones eventually.. or install those strut things Link to comment Share on other sites More sharing options...
underground000 Posted December 28, 2012 Share Posted December 28, 2012 Did you replace the torsion bars? If so, got any part numbers? nope, wanted to go spoilerless and did just that I've been told that there is a stiffer torsion bars specifically for the trunks with a spoiler. Mine are worn out too, I'll buy new ones eventually.. or install those strut things thats what i heard and my car came factory w/ spoiler.... i did add sound dampening to the trunk lid but for 4 years the trunk operated fine even in cold conditions ~30 degrees w/ dampening material 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Stewy612 Posted October 24, 2014 Share Posted October 24, 2014 For everyone who took their cars to the dealer to get this fixed, was there any push back from the dealership? I will take mine in however i know the local shop isn't necessarily the best suby dealer in the US haha -Brett Link to comment Share on other sites More sharing options...
MikeyMikes Posted October 30, 2014 Share Posted October 30, 2014 So my remote trunk release on the key fob doesn't work at all. I have tried pushing it many times over a period of time and moving my finger around when I do it but nothing happens. The key fob still locks and unlocks the doors just fine and beeps too. There is no beeping when I try to use the key fob for the trunk. It appears lifeless. Does anyone know how to fix this? I've been looking around and I couldn't find a real answer. I don't think it would be the batteries because the doors still unlock and lock, right? Any suggestions would be great. Link to comment Share on other sites More sharing options...
Dubz Posted October 30, 2014 Share Posted October 30, 2014 Where your trunk latch and filler lock is is a really bad spot for dirt to get trApped in it. Pop off the cover and slide off the latch plastic covers and vaccuum it out underneath. Also wd40 the springs and the latches pull back better Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted October 30, 2014 I Donated Share Posted October 30, 2014 So my remote trunk release on the key fob doesn't work at all. I have tried pushing it many times over a period of time and moving my finger around when I do it but nothing happens. The key fob still locks and unlocks the doors just fine and beeps too. There is no beeping when I try to use the key fob for the trunk. It appears lifeless. Does anyone know how to fix this? I've been looking around and I couldn't find a real answer. I don't think it would be the batteries because the doors still unlock and lock, right? Any suggestions would be great. Are you holding it down for 5-6 seconds? Have you tried multiple key fobs? Link to comment Share on other sites More sharing options...
MikeyMikes Posted October 30, 2014 Share Posted October 30, 2014 Are you holding it down for 5-6 seconds? Have you tried multiple key fobs? I finally got it to work after holding it down for about 5 seconds. Thanks, I just bought a 05 Legacy GT. Link to comment Share on other sites More sharing options...
