mustangendsley Posted December 9, 2011 Share Posted December 9, 2011 What kit did you get? I was just told that my LCA bushings have deep cracks in them and need to be replaced. $300 or so for a shop to do it. I figure I can do it myself if I have the right tools. I should have looked into it more though. Just replaced the suspension myself and lowered my car and got an alignment...so paying for another alignment will be fun. That is what it is called "3 in 1 service kit" at harbor fright for ~ 69$. it is a hand press for any bushings to remove and instal. Link to comment Share on other sites More sharing options...
mustangendsley Posted December 9, 2011 Share Posted December 9, 2011 Any reason you went with the AVO LCA's instead of WL all the way around? AVO rear bushing is cheeper than whiteline. Front whiteline is cheeper than AVO. They do the same thing, so i saved money. Link to comment Share on other sites More sharing options...
Rhitter Posted December 9, 2011 Share Posted December 9, 2011 That is what it is called "3 in 1 service kit" at harbor fright for ~ 69$. it is a hand press for any bushings to remove and instal. Cool found it thank you. I also found the four wheel drive ball joint kit for the same price that looks about the same with a few more options. Let me know how the installation goes. I want to make sure I have everything I need before I tackle it. My OBXT build Link to comment Share on other sites More sharing options...
mustangendsley Posted December 9, 2011 Share Posted December 9, 2011 will do. Im going to get it done this weekend. I just instaled the Koyo radiator and samco hoses last night. Link to comment Share on other sites More sharing options...
Ox LGT Posted December 10, 2011 Share Posted December 10, 2011 Cant wait to put some of these on. Link to comment Share on other sites More sharing options...
bmx045 Posted December 11, 2011 Share Posted December 11, 2011 does anyone have a video of what torn lca bushings SOUND like? I have a clunk gremlin drivers side front but my lca looks fine.... Link to comment Share on other sites More sharing options...
mustangendsley Posted December 12, 2011 Share Posted December 12, 2011 got them on and took a little while. the front LCA bushing was a pain to press out. Dont use the 3 in 1 kit like i bought and i will return. Just go and have them pressed out. Alignment tomorrow and i will let you all know what i think. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted December 12, 2011 Author Share Posted December 12, 2011 does anyone have a video of what torn lca bushings SOUND like? I have a clunk gremlin drivers side front but my lca looks fine.... Hey, I have found my sway bar bushings made more of a clunk than the LCA's. So you might want to check those as well. I have had these on the car for 8 mos and 10k miles or so and they squeak a bit when wet going over speed bumps, but otherwise are still great. Link to comment Share on other sites More sharing options...
mattg Posted December 12, 2011 Share Posted December 12, 2011 I don't think torn LCA's make noise. Mine have been torn for 40k miles and they don't make any noise. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted December 12, 2011 Author Share Posted December 12, 2011 I don't think torn LCA's make noise. Mine have been torn for 40k miles and they don't make any noise. I would imagine that would depend on how demolished they are and if there's metal contact. mine were silent killers of tires and handling. The clunk was from the sway bar bushings. My 3000gt clunked from the subframe bushings, my jag clunked from the shock mounts, firebird from transmission mount.... So pretty much any old destroyed rubber mount I imagine can clunk under the right circumstance. Link to comment Share on other sites More sharing options...
mustangendsley Posted December 12, 2011 Share Posted December 12, 2011 Alignment done and what a difference, much faster turn in with a little added road noise, but that is okay. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted December 12, 2011 Share Posted December 12, 2011 Unless of course you drive an Outback and the caster pushes the tire into the fender lining I could only imagine if i didnt get the +0 bushing. My tires already rub turning both ways on my outback. And on agressive hard right turns my wheels tucks and burnt a hole through my wheel well. Putting a hole in my vaccum line for my boost gauge and a hole in my power wire for my amp. And im not even that low Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 12, 2011 Share Posted December 12, 2011 Hmm, I never really thought about that. I'm going to lift the car up a little bit before I install the bushings, so hopefully it won't be too bad. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
OutbackXT05 Posted December 12, 2011 Share Posted December 12, 2011 does anyone have a video of what torn lca bushings SOUND like? I have a clunk gremlin drivers side front but my lca looks fine.... My front bushing were torn when i bought my car and 20k miles later no noises. The car does wander ever so slightly though while cruising on the freeway but have never really noticed it at 100mph plus for some odd reason, but that may be because ive never felt unsafe at those speeds. Even in my 1990 civic wagon lol. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted December 22, 2011 Author Share Posted December 22, 2011 Im sorry, but in the first pic I really think that is pressed in wrong. My instructions say to have the offset towards the center of the car. There is no offset. I got the zero offset bushings. Your eyes deceive you. Link to comment Share on other sites More sharing options...
mustangendsley Posted December 22, 2011 Share Posted December 22, 2011 ya i see it now it is a straight cut. Link to comment Share on other sites More sharing options...
Rhitter Posted December 24, 2011 Share Posted December 24, 2011 Anyone have negative feedback on these? I found another OB owner who said they were a little too harsh for a daily driver and I was wondering what others opinions were. My OBXT build Link to comment Share on other sites More sharing options...
ericem Posted December 25, 2011 Share Posted December 25, 2011 Anyone get avo rear LCA bushings and not do the front bushing on the LCA? Id imagine maybe if you do only the one the ride might still be decently smooth. I want to get these, but honestly i like the smoothness of it stock. Mine are indeed separated and cracked. Also can stock 08 + sti bushings be used? Or are they the same? Link to comment Share on other sites More sharing options...
mustangendsley Posted December 25, 2011 Share Posted December 25, 2011 The LCA is off so you might as well do the front bushing. The rear LCA bushing makes it the harsness feel, not the front bushing. But the car turns so much better. Link to comment Share on other sites More sharing options...
planelazy Posted December 25, 2011 Share Posted December 25, 2011 does anyone have a video of what torn lca bushings SOUND like? I have a clunk gremlin drivers side front but my lca looks fine.... I have the same clunk.. usually there when I hit a bump or enter a driveway. I think it's my bushings, but I haven't had time to look at it... so if you do get new bushings and it fixes your problem, let me know, I'll assume that's my problem too. Link to comment Share on other sites More sharing options...
quick4dr Posted December 25, 2011 Share Posted December 25, 2011 loving my new bushings installed at AZP, did the alignment at work with one of my techs help. Whiteline control arm bushings and inner bushings. fantastic difference in the ride. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted December 28, 2011 Author Share Posted December 28, 2011 Anyone get avo rear LCA bushings and not do the front bushing on the LCA? Id imagine maybe if you do only the one the ride might still be decently smooth. I want to get these, but honestly i like the smoothness of it stock. Mine are indeed separated and cracked. Also can stock 08 + sti bushings be used? Or are they the same? The 08 and up sti bushings are a different size. They are not as tall and are wider. Link to comment Share on other sites More sharing options...
Rhitter Posted February 27, 2012 Share Posted February 27, 2012 Just had these installed. Very minor increase in NVH. I was expecting more of an improvement in steering feel (probably still a little mushy due to crappy tires though). Overall, I think they are nice. The car reacts a little quicker to improvements. A little less lag when swerving around potholes etc. My OBXT build Link to comment Share on other sites More sharing options...
tito_b0y Posted February 27, 2012 Share Posted February 27, 2012 Just had these installed. Very minor increase in NVH. I was expecting more of an improvement in steering feel (probably still a little mushy due to crappy and taller tires though). Overall, I think they are nice. The car reacts a little quicker to improvements. A little less lag when swerving around potholes etc. Fixed. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
Bettlebob Posted February 28, 2012 Share Posted February 28, 2012 Looking at replacing these also, but I was wondering after I replace both of these do I have to get an alignment? I am looking at the +0.00 offset for the Lower Control Arm Bushing if that makes a difference regarding getting the car realigned. Thanks Link to comment Share on other sites More sharing options...
