06LegacyRBP Posted February 9, 2011 Share Posted February 9, 2011 Any had expreince with replacing the whole door? How hard? I'm looking to replace becuase of damage to the outer shell...please any advice would help? If not a legacy door has anyone done it on other cars? I think most car doors are about the same way? Help! Thanks! Link to comment Share on other sites More sharing options...
rao Posted February 9, 2011 Share Posted February 9, 2011 It is not particularly difficult.Bahamas - 2007.pdf Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
06LegacyRBP Posted February 9, 2011 Author Share Posted February 9, 2011 wow thanks rao!!!! i think you just answered everything...your the man! Link to comment Share on other sites More sharing options...
06LegacyRBP Posted February 9, 2011 Author Share Posted February 9, 2011 Do u know if I get a complete door if its just plug and play...assuming everything is power etc?...unplug the main harness and go to go? Besides paint... Link to comment Share on other sites More sharing options...
rao Posted February 9, 2011 Share Posted February 9, 2011 Unless you send me the door to buy first it will be hard to tell Odds are that it will be plug and play, but make sure that you talk to whoever you buy it from to make sure that it is a complete as possible. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2011 Share Posted February 9, 2011 FWIW, the body shop just put a new rear door on my car, someone backed into it and put a small dent in the drivers door. The final cost was just under $2500. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
06LegacyRBP Posted February 9, 2011 Author Share Posted February 9, 2011 thanks rao..door is on its way lol jk..$2500 for a new door? sounds kinda outrageous! thats why i would rather do the labor and have them paint Link to comment Share on other sites More sharing options...
Max Capacity Posted February 9, 2011 Share Posted February 9, 2011 When you look at all that has to happen the way it's laid out on the bill to his insurance company it makes sense. Plus the labor rate was only $55 per hour. The new OEM door skin was $599. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
