soares Posted February 1, 2011 Share Posted February 1, 2011 Sad to say but i wrecked my 05 STi in bad weather.. I have a s**T ton of parts from the STi still in the garage, so i wanted to know if aftermarket 05 STi wheels would fit my 07 2.5i legacy? Link to comment Share on other sites More sharing options...
Underdog Posted February 1, 2011 Share Posted February 1, 2011 '05 STi is 5x114.3 bolt pattern. Legacy is 5x100. So... no. The Crimson Dynamo Link to comment Share on other sites More sharing options...
W1CKED Posted February 1, 2011 Share Posted February 1, 2011 IIRC an '05 STi has a bolt pattern of 5x114.3. Your LGT had a bolt pattern of 5x100. Unless you've got dual drilled wheels, they won't work. Link to comment Share on other sites More sharing options...
Osei Posted February 1, 2011 Share Posted February 1, 2011 Not to be PITA but why didn't the OP just try them? They were in his garage! In addition the wheel forum sticky had the answer to his question. O. Link to comment Share on other sites More sharing options...
madcatz Posted February 1, 2011 Share Posted February 1, 2011 to make a long story short....NO they will not bolt right up as stated above on the wheel stud pattern. now, if you were to say get a 5x100 to 5x114.3 spacer you can put them on, but its a lil more work that its worth. anything is possible, but practical....not so much -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
PeterJMC Posted February 1, 2011 Share Posted February 1, 2011 No, '05 STi wheels will not fit on your 2.5i Legacy. Bolt pattern for the '05 STi wheels would be 5x114.3 and the bolt pattern that your 2.5i uses is 5x100. You could buy an adapter and make it work, but I would recommend against doing it. http://forums.nasioc.com/forums/showthread.php?t=813492 Link to comment Share on other sites More sharing options...
