planelazy Posted January 26, 2011 Share Posted January 26, 2011 I noticed on my BL LGT that my left (driver side) exhaust was hanging a bit lower than the other side... thought it was just mine.. but now, 1000 miles away, I pulled out of a gas station in Baltimore.. and another BL LGT had the exact same thing.. Is this common? What's the fix, replace the mounts/bracket? Link to comment Share on other sites More sharing options...
RedDawg Posted January 26, 2011 Share Posted January 26, 2011 same reason as: http://answers.yahoo.com/question/index?qid=20080514135241AAYMr7G Link to comment Share on other sites More sharing options...
goneskiian Posted January 26, 2011 Share Posted January 26, 2011 same reason as: http://answers.yahoo.com/question/index?qid=20080514135241AAYMr7G :lol: :lol: Well played sir! Link to comment Share on other sites More sharing options...
dr_sharp Posted January 27, 2011 Share Posted January 27, 2011 +1 :lol: To OP: Very common. lol Link to comment Share on other sites More sharing options...
notthesnail Posted January 27, 2011 Share Posted January 27, 2011 Pull the exhaust on the low side out of the hanger(s) and move it up to the middle hole (which is really just a gap between upper and lower holes). Or use poly hangers on that side. They don't stretch as much. Link to comment Share on other sites More sharing options...
Flat4 Posted January 27, 2011 Share Posted January 27, 2011 If you decide to move it to the middle hole, that hole will eventually be as saggy as the others. Link to comment Share on other sites More sharing options...
planelazy Posted January 31, 2011 Author Share Posted January 31, 2011 same reason as: http://answers.yahoo.com/question/index?qid=20080514135241AAYMr7G :lol: Either you had already searched for that or that was what Google had returned for an object hanging lower than the other Pull the exhaust on the low side out of the hanger(s) and move it up to the middle hole (which is really just a gap between upper and lower holes). Or use poly hangers on that side. They don't stretch as much. Well the exhaust is going to be replaced anyways, but I hadn't looked at it close enough to determine if the hanger bar was bent or if the poly hanger was broken or stretched. Link to comment Share on other sites More sharing options...
quick4dr Posted February 4, 2011 Share Posted February 4, 2011 battling this issue myself, my drivers muffler is way lower than my right, and its worsened by my 3in to 2.5in reducer at my catback/ dp flange Link to comment Share on other sites More sharing options...
LOVEMYSUBE Posted February 7, 2011 Share Posted February 7, 2011 I used hose clamps to even them out. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted February 22, 2011 Share Posted February 22, 2011 my passanger side magnaflow tip is lower and inward more than my driver's side. Will the metal hose clamp trick fix this problem? Link to comment Share on other sites More sharing options...
Windy Road Posted February 22, 2011 Share Posted February 22, 2011 my passanger side magnaflow tip is lower and inward more than my driver's side. Will the metal hose clamp trick fix this problem? If its off by a little bit it might, if its like my gms crap then no. Then you need to heat it up and bend it 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted February 23, 2011 Share Posted February 23, 2011 It's not bad Windy. I think I am going to bring some clamps when I come down for the headlights and DRL and do it also. lol Link to comment Share on other sites More sharing options...
Windy Road Posted February 23, 2011 Share Posted February 23, 2011 Sounds good Keith, 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
snow05gtRI Posted February 24, 2011 Share Posted February 24, 2011 hoseclamp should fix it... or get stronger bushings from rallitek. my driver's side was hanging considerably lower and put on new bushings and it looks stock. Link to comment Share on other sites More sharing options...
