Th3Franz Posted May 15, 2005 Share Posted May 15, 2005 PLEASE post in this thread if you've burned out a light of four: http://legacygt.com/forums/showthread.php?t=12570 Ahhh it's an endless cycle! -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
chinchy Posted September 12, 2005 Share Posted September 12, 2005 I put in the European version of the Silverstars, and they both blew out within a week of each other (but only after several months). I'm back on the stock pair right now, and so far so good. I'm also up to 29,000 mi. Link to comment Share on other sites More sharing options...
executor485 Posted October 11, 2005 Share Posted October 11, 2005 Passenger headlight burnt out at less than 2k miles. Dealer replaced it no charge, but still... less than 2k... theres something wrong about that. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
scoobydo2 Posted October 13, 2005 Share Posted October 13, 2005 Two driver, two passenger bulbs. My dealer is very aware of this being an issue. He mentioned possible alternator problem. Link to comment Share on other sites More sharing options...
sub671 Posted October 14, 2005 Share Posted October 14, 2005 just wondering if the condition is common to vehicles with DRL(daytime running lights) enabled. i disabled DRL the day after i picked up my car and at 11k miles have had no issues yet. my brother on the other hand retained his DRL and has already had 1 of his head lamps burn out at 10k. Link to comment Share on other sites More sharing options...
ebpda9 Posted December 19, 2005 Share Posted December 19, 2005 weird, my left front hid sometimes refuses to come on when i turn the engine on. sometimes i need to turn the headlights on 3-4 times for it to make it work. also i changed the igniter and the balast between left and right and still the same problem. i think there might be a short or some voltage spike of some sort. Link to comment Share on other sites More sharing options...
swiftyrt66 Posted January 2, 2006 Share Posted January 2, 2006 My passenger headlight has gone out for the third time (17k miles now, 2005 LGT Limited Wagon). First time I had the dealer replace it (free), second time while at Jiffy Lube ($20). Time to head back to the dealer... I usually use the auto-on setting. Link to comment Share on other sites More sharing options...
franklin Posted January 2, 2006 Share Posted January 2, 2006 This is my third time replacing my headlight bulbs ( 2x drivers, 1x passenger side). Should I bring my car into the dealer to check if there anything wrong? Or is this normal? Has anyone else had to change that many times? Any recommedenation on bulb brands? Thanks Seems normal for our cars. Something is wrong with this design. Link to comment Share on other sites More sharing options...
Gohmer1 Posted February 9, 2006 Share Posted February 9, 2006 15,000 miles. Just had one blow tonight. Maybe I'll go grab one real quick for my 200 mile drive tonight, and then submit it to the dealership so they can pay. Link to comment Share on other sites More sharing options...
tsyGT Posted February 10, 2006 Share Posted February 10, 2006 I went in to the dealer today to get my passenger bulb replaced. They replaced both of my bulbs with the 'new' ones that will hopefully last longer. They said Subaru increased the power of the headlights without improving the bulbs. I guess we'll see. . . tom Link to comment Share on other sites More sharing options...
mcohen4 Posted September 3, 2006 Share Posted September 3, 2006 changed twice within first 25k miles Link to comment Share on other sites More sharing options...
lester_strud Posted September 5, 2006 Share Posted September 5, 2006 Drivers Bulb just blown at 24,000 km. Car is due for its Service tomorrow. Hopefully they will replace free Link to comment Share on other sites More sharing options...
mmarton Posted November 6, 2006 Share Posted November 6, 2006 Not sure when, but I had the driver's side lamp burn out somewhere past 20K miles (I'm near 22,500 now). I'm going to the dealer (Subaru of Gwinnett, GA) this Saturday for replacement, covered under warranty. I mentioned some of the information read on this thread. They shipped back a whole supply of defective bulbs and will replace both lamps with the newer version. I hope this works. I disabled the DRL not long after buying the car. I had an '83 Honda Prelude that was great, but the older style sealed beam halogens would burn out ever 20K miles. Never figured it out. Link to comment Share on other sites More sharing options...
Prime Power Posted March 2, 2007 Share Posted March 2, 2007 Don't know if you guys are aware of this, but my theory is it blows because it is never seeing the right voltage. DRL gets approx. 10v while lows get 14v. Never getting 12v like they were intended. Link to comment Share on other sites More sharing options...
awdG35killer Posted March 5, 2007 Share Posted March 5, 2007 mine burned out around 15k miles but a dealer replaced them under warranty. im at 45k now and they are still fine Link to comment Share on other sites More sharing options...
johnAWD Posted March 5, 2007 Share Posted March 5, 2007 I've had my car just about a year, and a couple days after I got it the OEM bulbs were replaced with sylvania silverstars. Still glowing strong. 17k miles. Link to comment Share on other sites More sharing options...
GTS Jeff Posted March 22, 2007 Share Posted March 22, 2007 My Subaru has also had the same problem, although I'm starting to think that it's just because Subaru's electrical system isn't designed to proper spec. According to a few posts, the low beams see 14V! That's quite a bit more than what they're designed for. It would also explain why even the stock bulbs are so damned bright. Another thing I've noticed is that my stereo head unit gets 14.5V consistently! What the duck! Link to comment Share on other sites More sharing options...
Prime Power Posted March 22, 2007 Share Posted March 22, 2007 Odd. Link to comment Share on other sites More sharing options...
gallax Posted March 23, 2007 Share Posted March 23, 2007 14V is ok. Automotive parts can run anyway between 11v (when running on an empty battery and no charger) to 16v... So this is not the reason. On the other hand, I have 16k (in 9 months) on my OB and no light bulb changed so far (and yes, I have also 14.5v when the engine is running). Maybe is because I keep the headlights on all the time... Link to comment Share on other sites More sharing options...
mega Posted July 17, 2007 Share Posted July 17, 2007 Hello-- I'm not sure if this thread is still active, but, I will be replacing headlight #5 tomorrow in my 2005 Legacy Wagon. The first time they went, my dealer in MD (Heritage, I Love You) replaced them under warranty. Then I moved to Massachusetts where, the next time them burnt out, Dec 2006, that my car's mileage put they headlight out of warranty--even though I have bought the extended warranty for 80k miles. Now, July 2007, the driver's side is out again. Steve Lewis agreed to replace it, but only with an argument. Has there been any resolution to this issue? Or am I beating a dead thread? Thanks, Meg Link to comment Share on other sites More sharing options...
bille Posted November 1, 2007 Share Posted November 1, 2007 Maybe a dead thread, but I too am getting a little tired of the cost and hassle of these repeated bulb changes. Gave up on the dealer after year 1, tried the Silver Stars too, but still they blow, usually on start-up, and mostly passenger side bulbs. I use DRL as I am located in Canada, and the funny thing is the dealer always asks me if I use my parking brake (?) when I complain about the bulb failures. Now I know that the DRL is activated by releasing the parking brake, but what difference would how the DRL comes on matter? For the record, I always engage my parking brake. Any ideas about the parking brake business, and what do they know that we don't? Link to comment Share on other sites More sharing options...
Joebklyn Posted September 11, 2008 Share Posted September 11, 2008 Could be a voltage spike check the framus for continuity. Link to comment Share on other sites More sharing options...
jivingt Posted December 6, 2008 Share Posted December 6, 2008 Our 97GT blew bulbs and Subaru said nothing was wrong, then two years and many bulbs later they issued a recall on the alternator saying that it could cause voltage spikes and one effect could be limiting the life of bulbs. New alternator and our 2x130/90s and 2x130s never blow now. Hope there is not a similar - yet unknown - issue with the 05s. My '05 burns out a pair a year. I'll mention the alternator when I take it in for the 60K service... I'd been riding around "pop-eyed" for a few days, and then leaving work in the dark yesterday, I started the car and the one good one went out. I had to drive home with my brights on. Link to comment Share on other sites More sharing options...
eVoMotion Posted December 6, 2008 Share Posted December 6, 2008 I lost my first bulb at 45K - lucky on this car. My 97GT lost many, many bulbs...before the recall. Headed out to install my HID and HIRs this morning...after the frost melts. Link to comment Share on other sites More sharing options...
franklin Posted December 6, 2008 Share Posted December 6, 2008 This is very odd. Subaru headlights normally last the life of the car. Link to comment Share on other sites More sharing options...
