LzyKid4Life Posted May 16, 2005 Share Posted May 16, 2005 how did you get that lil gap on the bottom of the grill not to be there?, I remember some one else doing this and because they cut the middle piece out it made the outer part of the grill bend, so there was a little gap. sorry if im not to clear.... Link to comment Share on other sites More sharing options...
RoundBoy Posted May 16, 2005 Share Posted May 16, 2005 you WIN for homemade grille. I assume that larger mesh would still follow yuor same instructions ? i would buy one from you Link to comment Share on other sites More sharing options...
firedawgs Posted May 16, 2005 Author Share Posted May 16, 2005 how did you get that lil gap on the bottom of the grill not to be there?, I remember some one else doing this and because they cut the middle piece out it made the outer part of the grill bend, so there was a little gap. sorry if im not to clear.... The gap is only there if you buy the Euro or JDM grill. I used the stock grill and made my own JDM grill. Thanks Round boy: I would help you make one if you were in the area. Updated my vBGarage: Link to comment Share on other sites More sharing options...
Kaptan Posted May 16, 2005 Share Posted May 16, 2005 The gap is only there if you buy the Euro or JDM grill. I used the stock grill and made my own JDM grill. Thanks Round boy: I would help you make one if you were in the area. This is the thread that we are referring regarding the gap in the bottom center - http://legacygt.com/forums/showthread.php?t=5513&highlight=grill What did you do different to eliminate that gap? Link to comment Share on other sites More sharing options...
otoc Posted May 16, 2005 Share Posted May 16, 2005 Nice job firedawgs. The best home modded grill I've seen. Link to comment Share on other sites More sharing options...
firedawgs Posted May 16, 2005 Author Share Posted May 16, 2005 I am thinking more and more on painting the mess black. That would be the finishing touches. The gap you see on 05USdmGTGuy on that thread is simply he forgot to tuck the bottom into the bumper There are 2 peices on the bottom of the grill that slide into a lip on the bumper. That is the hardest part of the whole thing; trying to get the grill to line up with the grill and lining up the top four clips at the same time. Other than that there is 2 pop-off clips and two screws holding the grill in place. Updated my vBGarage: Link to comment Share on other sites More sharing options...
OCDetails Posted May 16, 2005 Share Posted May 16, 2005 if you paint it black make sure you do it right. That would look like ass real quick if the paint starts chipping. Its a great looking grille as it is, but being black would probably look better. I would just hate to see it start chipping because then it would really look nasty. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
firedawgs Posted May 16, 2005 Author Share Posted May 16, 2005 but how much would it cost to paint the grill?? I could not tell you how much it would cost to paint. My car was in the shop for a hit and run accident anyways. I had them paint the grill while it was in there. My best guess would be under $75. To bad SOA does not make a paint spray for our cars. Updated my vBGarage: Link to comment Share on other sites More sharing options...
firedawgs Posted May 16, 2005 Author Share Posted May 16, 2005 Your right. A good primer and a few coats of black should do the trick. if you paint it black make sure you do it right. That would look like ass real quick if the paint starts chipping. Its a great looking grille as it is, but being black would probably look better. I would just hate to see it start chipping because then it would really look nasty. Updated my vBGarage: Link to comment Share on other sites More sharing options...
OCDetails Posted May 16, 2005 Share Posted May 16, 2005 www.paintscratch.com can match your paint and send it in a spray can. They have the 05 colors for the Legacy loaded in now. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
firedawgs Posted May 17, 2005 Author Share Posted May 17, 2005 There you go. Good find OC. That would make life much easier for anyone interested in doing this mod. Updated my vBGarage: Link to comment Share on other sites More sharing options...
RoundBoy Posted May 17, 2005 Share Posted May 17, 2005 Questions: 1) After you removed the middle plastic pieces.. what did you use to fill in the gaps 2) How did you attach the mesh to the frame ? Link to comment Share on other sites More sharing options...
firedawgs Posted May 17, 2005 Author Share Posted May 17, 2005 1) I am not sure what you mean by gaps? What gaps are you talking about? 2) I used quick set epoxy to hold the mesh to the plastic. Updated my vBGarage: Link to comment Share on other sites More sharing options...
Kaptan Posted May 17, 2005 Share Posted May 17, 2005 1) I am not sure what you mean by gaps? What gaps are you talking about? This is a pic of another member who did the same thing you did, but with a gap in the bottom center - below the subaru badge. http://legacygt.com/forums/attachment.php?attachmentid=3334 Link to comment Share on other sites More sharing options...
RoundBoy Posted May 18, 2005 Share Posted May 18, 2005 i actually meant when you removed all the center plastic pieces .. was the sides of the grille solid or did it have holes where the center bars were ? Link to comment Share on other sites More sharing options...
firedawgs Posted May 18, 2005 Author Share Posted May 18, 2005 i actually meant when you removed all the center plastic pieces .. was the sides of the grille solid or did it have holes where the center bars were ? When I am back home on Friday I will take more pictures for you all. Updated my vBGarage: Link to comment Share on other sites More sharing options...
firedawgs Posted May 18, 2005 Author Share Posted May 18, 2005 This is a pic of another member who did the same thing you did, but with a gap in the bottom center - below the subaru badge. http://legacygt.com/forums/attachment.php?attachmentid=3334 OK, I see what you are talking about now. The most exterior portion of the gap (towards the front) is where I based my line to the sides. So, basically from the front gap to the side gaps I cut out. I'll post more pictures. Updated my vBGarage: Link to comment Share on other sites More sharing options...
carcand Posted May 20, 2005 Share Posted May 20, 2005 The grill insert looks like gutter guard. Not that that's bad i did that to mine for about 5$ at the hardware store and it looks great! Link to comment Share on other sites More sharing options...
PGT Posted May 20, 2005 Share Posted May 20, 2005 It is actually a piece of gutter guard at any Home Depot or Lowes. Just make sure it is stainless steel. Yes, I think my $12 grill is just as good as the $328 JDM grill. Link to comment Share on other sites More sharing options...
carcand Posted May 20, 2005 Share Posted May 20, 2005 amen. Link to comment Share on other sites More sharing options...
firedawgs Posted May 20, 2005 Author Share Posted May 20, 2005 OH man, you found my secret. Updated my vBGarage: Link to comment Share on other sites More sharing options...
carcand Posted May 20, 2005 Share Posted May 20, 2005 what can i say, i'm nice like that. Link to comment Share on other sites More sharing options...
firedawgs Posted May 23, 2005 Author Share Posted May 23, 2005 SO I bought the stuff to paint the grill black. AS soon as we can get some good weather here in MA I will do it up and post up some new pictures. Updated my vBGarage: Link to comment Share on other sites More sharing options...
f1anatic Posted May 26, 2005 Share Posted May 26, 2005 Sure http://www2.uic.edu/~bcatal1/etcetera/DSCF0037%20%28Small%29.JPG Ask around but I have gotten only positive reviews. Link to comment Share on other sites More sharing options...
Gohmer1 Posted May 26, 2005 Share Posted May 26, 2005 I do not like that one bit. Paint the chrome black asap!!! Chrome does not compliment the car at all. Link to comment Share on other sites More sharing options...
