cjl0792 Posted November 6, 2010 Share Posted November 6, 2010 05 legacty gt. stage 2. traveling about 70-75 put peadal about 3/4 throttle loud pop then no fifth gear. the rest are fine. but no fifth. along with this came a whine. has any one encountered this, and if so rough idea of what parts i will be replacing? Link to comment Share on other sites More sharing options...
KurtP Posted November 8, 2010 Share Posted November 8, 2010 Ive heard of 5th gear going inexplicably on modified legacies, although there has never been a real reason why that I have found. You will likely be replacing the trans, or at a minimum the 5th gear sprocket. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted November 9, 2010 Share Posted November 9, 2010 If you're lucky enough to just have to replace the 5th gear set, it's surprisingly cheap. Dealer just replaced mine trying to fix an issue and the list was only about 170 bucks Link to comment Share on other sites More sharing options...
whitetiger Posted November 9, 2010 Share Posted November 9, 2010 exactly the same thing happend to me. dont drive it, even though it seems fine. get it fixed asap. my 5th gear split in 2 pieces and fell in to the case. Link to comment Share on other sites More sharing options...
dr_sharp Posted November 9, 2010 Share Posted November 9, 2010 Yikes... 5MT failure is relatively common? lol Link to comment Share on other sites More sharing options...
AZZMAN Posted January 17, 2011 Share Posted January 17, 2011 This happened on my way home from work on Friday, traveling about 70 mph 3/4 gas move it to 5th gear and then I hear a pop sound and no fifth gear... The gate feels empty, nothing to grab... All the other gears seem to be fine or "there" except the shifter got stuck in second once... A trip to the dealer tomorrow... Link to comment Share on other sites More sharing options...
f1anatic Posted January 17, 2011 Share Posted January 17, 2011 This happened on my way home from work on Friday, traveling about 70 mph 3/4 gas move it to 5th gear and then I hear a pop sound and no fifth gear... The gate feels empty, nothing to grab... All the other gears seem to be fine or "there" except the shifter got stuck in second once... A trip to the dealer tomorrow... Your car and Strizzy's have been in shops more often than on the road. It is either your driving style or you both have had bad bad luck. _________ Typically if you lose 5th gear is cause your clutch is done. I am not saying that is not possible to break the gear in itself but losing 5th gear especially during acceleration (3/4 throttle as someone said) is the first sign of a pending clutch replacement job. If the 5th gear does not engage, you may also have lost the synchros. The individual gear and the synchros may be cheap, relatively speaking, BUT to drop the tranny, split it and put it back you are looking at 7-800 dollars just in labor. Link to comment Share on other sites More sharing options...
bsax14 Posted January 17, 2011 Share Posted January 17, 2011 exact same thing happened to me! now i have a 6 spd! Link to comment Share on other sites More sharing options...
AZZMAN Posted January 17, 2011 Share Posted January 17, 2011 At 71k now... It's been in the "shop" once to go stage 2 at about 10k, then brakes at about 60k. I don't call a new windshield, a bunch of tires, and many light bulbs and oil changes every 4 to 5k in the shop alot but others might... Everything else is orgional clutch, turbo, and suspension. I love this car, I'm going to shoot for 150k plus but with the new drive that will be in three years I had the same thing happen on my 04 XT but it was covered under warranty... Even if it cost 2k to fix it sure beats a car payment. I'll post an update and pics of the busted parts. Link to comment Share on other sites More sharing options...
