MDKSDMF Posted October 7, 2010 Share Posted October 7, 2010 spoke with andrew @ ajwperformance.comand he gave me a killer deal on this TMIC! im very excited to see what its capable of. im currently running the stock VF40 w/ stage 2. anybody else running this TMIC and have any tricks or information regarding install and or performance gains with this unit? thanks - jim http://i1046.photobucket.com/albums/b468/Fearless_French/coatedTMIC.jpg Link to comment Share on other sites More sharing options...
Irimis Posted October 7, 2010 Share Posted October 7, 2010 http://legacygt.com/forums/showpost.php?p=3044146&postcount=93 http://legacygt.com/forums/showthread.php/import-performance-research-top-mount-intercooler-tmic-group-buy-142064p13.html You will most likely have a small rub on your clutch master. Read above threads for ways to resolve it. Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 7, 2010 Author Share Posted October 7, 2010 thank you sir Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 7, 2010 Author Share Posted October 7, 2010 and some people including andrew himself claim that the TMIC bolts directly in like stock with no problems.... Link to comment Share on other sites More sharing options...
Balrock Posted October 7, 2010 Share Posted October 7, 2010 That looks like a Perrin clone if ever there was one. Link to comment Share on other sites More sharing options...
Irimis Posted October 8, 2010 Share Posted October 8, 2010 Its insanely close. For me, if I turned the cap on the clutch master it would not rub, but then its not locked in place. So I mean 99% solid and for the price you really cant beat it. Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 8, 2010 Author Share Posted October 8, 2010 Its insanely close. For me, if I turned the cap on the clutch master it would not rub, but then its not locked in place. So I mean 99% solid and for the price you really cant beat it. so urs fit but was a tight squeeze? i can live with that lol. im reading of people shimming up that side so it clears the clutch cylinder Link to comment Share on other sites More sharing options...
Irimis Posted October 8, 2010 Share Posted October 8, 2010 I put 3 washers between the mounting bracket and the TMIC and it was fine. I drove around like that for a couple weeks, no peddle noise at all. I was worried about the stock bolt barely reaching so I was looking for a longer one, when I could not find one I just did the threaded bolt with some nuts. So if you can find a longer bolt that fits in to the bracket use washers, if you can't do the threaded bolt, its really easy. http://legacygt.com/forums/showpost.php?p=3044146&postcount=93 Look at the cap, the little 'tab' is pointing directly at the TMIC if that tab was not there I would not of had any rub. Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 8, 2010 Author Share Posted October 8, 2010 cool i ordered the TMIC yesterday and want to get the nuts and washers ahead of time so i can install right away. my blood boils when i go to put a part in and need extra stuff that i dont have on hand Link to comment Share on other sites More sharing options...
rtbrjason Posted October 8, 2010 Share Posted October 8, 2010 I put 3 washers between the mounting bracket and the TMIC and it was fine. I drove around like that for a couple weeks, no peddle noise at all. I was worried about the stock bolt barely reaching so I was looking for a longer one, when I could not find one I just did the threaded bolt with some nuts. So if you can find a longer bolt that fits in to the bracket use washers, if you can't do the threaded bolt, its really easy. http://legacygt.com/forums/showpost.php?p=3044146&postcount=93 Look at the cap, the little 'tab' is pointing directly at the TMIC if that tab was not there I would not of had any rub. Aside from the threaded dowel I used to raise mine, I was also able to turn the clutch cap sightly without loosening it to get the tab further out of the way. Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 8, 2010 Author Share Posted October 8, 2010 ^ does the TMIC look like it sits slanted now that u raised it with the dowel? its a good idea tho. Link to comment Share on other sites More sharing options...
rtbrjason Posted October 8, 2010 Share Posted October 8, 2010 Not at all. Got the engine cover back on as well with no trimming. It's not attached with plastic clips, but it locks itself in around the intercooler. The hood holds it from moving at all and even when popping the hood you still need to pry the cover off. Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 8, 2010 Author Share Posted October 8, 2010 loks good man. what did u use again? a long nut a bolt combo with washers? Link to comment Share on other sites More sharing options...
rtbrjason Posted October 8, 2010 Share Posted October 8, 2010 I used a 3" long threaded dowel and 2 nuts to act as adjusters to move the tmic up/down. Link to comment Share on other sites More sharing options...
AJW Performance Posted October 8, 2010 Share Posted October 8, 2010 Thanks again MDKSDMF, appreciate the business. Since it's a lot bigger than stock it will be a much tighter squeeze than stock for sure, I have not had to do any shaving/ modifications with my installs using these IPR's here at the shop, BUT I have no installed on a Spec B before, not sure if it is Spec B owners who are needing to modify? It is basically identical to Perrin, just a few hundred bucks less, so it's a win win Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 10, 2010 Author Share Posted October 10, 2010 yes I can't wait. I suspect it's a spec. B related issues but who knows. Mine shud arrive tuesday and I'll let you know how it goes. I have already pushed the product and the shop to friends and people @ the track (epping nh) on friday and will ccontinue to do so. Cheers to a very necssary aftermarket part at a killer price. Thanyou. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 10, 2010 Share Posted October 10, 2010 It doesn't FIT like a Perrin, does it? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 10, 2010 Author Share Posted October 10, 2010 i dont know yet i havent received the TMIC yet Link to comment Share on other sites More sharing options...
rtbrjason Posted October 10, 2010 Share Posted October 10, 2010 It doesn't FIT like a Perrin, does it? People have the same issue with the Perrin. Some people have no issues though and it doesn't seem to be related to Spec B or LGT. Perrin's site now mentions that you may need to slightly clock the turbo to get proper fitment. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 10, 2010 Share Posted October 10, 2010 That's a bunch of crap. Still, I might get one of these to prevent issues at stage2 boost. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
MDKSDMF Posted October 11, 2010 Author Share Posted October 11, 2010 yeah...clocking the turbo? Link to comment Share on other sites More sharing options...
thebigevilfoot Posted October 11, 2010 Share Posted October 11, 2010 Thanks again MDKSDMF, appreciate the business. Since it's a lot bigger than stock it will be a much tighter squeeze than stock for sure, I have not had to do any shaving/ modifications with my installs using these IPR's here at the shop, BUT I have no installed on a Spec B before, not sure if it is Spec B owners who are needing to modify? It is basically identical to Perrin, just a few hundred bucks less, so it's a win win Any idea how the fitment is on the 09-11 WRX? Under the hood the Legacy GT and WRX looks almost the same, so I was wondering if this TMIC will work the new WRX. Link to comment Share on other sites More sharing options...
goneskiian Posted October 12, 2010 Share Posted October 12, 2010 Any idea how the fitment is on the 09-11 WRX? Under the hood the Legacy GT and WRX looks almost the same, so I was wondering if this TMIC will work the new WRX. Correct me if I'm wrong, but I believe this IC was actually designed for the new WRX and is only offered here because it also "just so happens" to fit the Legacy. That's why there aren't any tabs for the engine cover to attach to. Cheers! Link to comment Share on other sites More sharing options...
AJW Performance Posted October 12, 2010 Share Posted October 12, 2010 Any idea how the fitment is on the 09-11 WRX? Under the hood the Legacy GT and WRX looks almost the same, so I was wondering if this TMIC will work the new WRX. Yep works fine with your car Link to comment Share on other sites More sharing options...
AJW Performance Posted October 12, 2010 Share Posted October 12, 2010 Correct me if I'm wrong, but I believe this IC was actually designed for the new WRX and is only offered here because it also "just so happens" to fit the Legacy. That's why there aren't any taps for the engine cover to attach to. Cheers! This is probably the case yes Link to comment Share on other sites More sharing options...
