TrueWhiteBoy Posted August 22, 2010 Share Posted August 22, 2010 I've seen a bunch of threads discussing the clunk when it's accelerating, but what about when it's decelerating? It seems that when I'm slowing down when I get down to about 10 mph I hear a clunk in the rear. It only seems to occur when slowing down/stopping, but not when accelerating. Could it be the rear diff? Would it be something to worry about? If not, when should it become something to worry about? Link to comment Share on other sites More sharing options...
fishbone Posted August 24, 2010 Share Posted August 24, 2010 Could be the rear diff. I'd check the level of the fluid to make sure it's filled right. While you're at it, might as well change it if you haven't done it recently. I think the rear-end clunk is generally cured by using mount inserts. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 30, 2010 Share Posted August 30, 2010 are you hearing the "click" from the shifter? when you get to around 10mph the shifter lock flips and you can hear an audible click. Link to comment Share on other sites More sharing options...
cseagle08 Posted August 31, 2010 Share Posted August 31, 2010 sounds like just normal slack in the driveline, probably nothing to worry about. Link to comment Share on other sites More sharing options...
