Kentbox Posted August 5, 2010 Share Posted August 5, 2010 Just a quick question. Is there anything I need to know about switching out my old worn swaybar mounts with brand new ones? Are there any torque specs, or do I need to replace the bolts? If so, what do I need to get? I've never done this fix before and I don't want to screw anything up. Thanks. Link to comment Share on other sites More sharing options...
amp27 Posted August 5, 2010 Share Posted August 5, 2010 i would guess its just as smiple as tighten as needed and replace as needed. its not like you cant drive your car without swaybars. Link to comment Share on other sites More sharing options...
JimmEh Posted August 5, 2010 Share Posted August 5, 2010 keep your face well clear from underneath, lots of dirt collects on top. ask my eyes how i know. Link to comment Share on other sites More sharing options...
amp27 Posted August 5, 2010 Share Posted August 5, 2010 yours eyes talk? can your mouth see? Link to comment Share on other sites More sharing options...
Reuben Posted August 5, 2010 Share Posted August 5, 2010 yours eyes talk? can your mouth see? This is relevant to my interests. Link to comment Share on other sites More sharing options...
JimmEh Posted August 5, 2010 Share Posted August 5, 2010 it can see better then my eyes when they're full of 15 year old dirt Link to comment Share on other sites More sharing options...
kaz98gt Posted August 5, 2010 Share Posted August 5, 2010 woah. So swaybar mounts...those are the same as endlinks right? Link to comment Share on other sites More sharing options...
amp27 Posted August 5, 2010 Share Posted August 5, 2010 no you fool. its the metal stand that comes down off the chassis. FOOLS Link to comment Share on other sites More sharing options...
kaz98gt Posted August 5, 2010 Share Posted August 5, 2010 my bad joe. still new to this... Link to comment Share on other sites More sharing options...
amp27 Posted August 6, 2010 Share Posted August 6, 2010 i forgive you to the fullest extent Link to comment Share on other sites More sharing options...
JimmEh Posted August 6, 2010 Share Posted August 6, 2010 http://img.photobucket.com/albums/v337/Jimm3h/car%20stuff/_MG_6083.jpg top middle is the mount, lower right is the endlink. Link to comment Share on other sites More sharing options...
amp27 Posted August 6, 2010 Share Posted August 6, 2010 thats looks sexy Link to comment Share on other sites More sharing options...
kaz98gt Posted August 6, 2010 Share Posted August 6, 2010 i forgive you to the fullest extent couldn't resist hahaha. Ok now I know exactly what is going on. As far as that bushing goes, does it just snap on? Link to comment Share on other sites More sharing options...
WESTcoast Posted August 6, 2010 Share Posted August 6, 2010 As far as that bushing goes, does it just snap on? any type of bushings or stuff like that needs to be pressed in with a machine press, but dont take it from me I bought all my stuff pre done lol Link to comment Share on other sites More sharing options...
Zues Marine Posted August 6, 2010 Share Posted August 6, 2010 any type of bushings or stuff like that needs to be pressed in with a machine press, no. just no. Link to comment Share on other sites More sharing options...
amp27 Posted August 7, 2010 Share Posted August 7, 2010 What Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 7, 2010 Share Posted August 7, 2010 You can buy those bushings and install them without a machine press. The bushings that need the press are trailing arm and/or control arm/rod bushings. Those sway bar bushings have a slit in them, meaning when they are non-constrained by the sway bar mount they are NOT a complete circle. They have that slot cut/molded into them so that you can remove the bracket, slide the old ones off via the slit in the bushing, slide the new ones on and bolt the bracket back on. You can actually see the slot I'm talking about in the pics. Link to comment Share on other sites More sharing options...
