GTTuner Posted July 8, 2010 Share Posted July 8, 2010 Ok. I suck at life. I have 600 miles on the new motor and the Spec clutch. Last night I did a hard launch (the clutch hooks up great!) and on the 1-2 shift my flip/flop's got jammed under the clutch pedal for a second and I clashed the shift. I re-engagend 2nd and took off. Now, 1st gear seems tight to engage, kind of stiffer than normal. No grinding or difficulty in any other gears. My 1-2 shifts are still like butter, as well as all other gears, just putting into 1st. No difference if the car is running or not. This AM it felt better, but still stiffer than normal. Anyone here ever bent a shift fork or rod? I have done many 1-2 shifts over the past with much more force and fury and never had any problem. I'm hoping something in the linkage (maybe the pitch stopper needs adjustment?) but I'm not very hopeful. I think I'm going inside this tranny now. WTF!!!! Input appreciated . Oh, and on top of this, some moron at work Tuesday deceided to move the plow truck at work (it's 101 degrees out and the freaking plow truck gets moved, WTF!!!!) and I back my RR quarter panel into it and did voodoo damage. Link to comment Share on other sites More sharing options...
rao Posted July 8, 2010 Share Posted July 8, 2010 There is no pitch stopper adjustment Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dschultz Posted July 8, 2010 Share Posted July 8, 2010 Any chance you have a bit of clutch drag that is making it hard to engage 1st? I went through a new clutch due to insufficient travel in the fork (not releasing completely). It was hitting the housing of the tranny where it pokes through. You can easily check it. Try pushing the fork toward the slave cylinder. If it moves, compressing the pin into the slave a bit and pushing the fluid up in the reservoir then all is good. Otherwise you need to make an adjustment. Link to comment Share on other sites More sharing options...
GTTuner Posted July 8, 2010 Author Share Posted July 8, 2010 No, it was fine before and it is the same with the engine off. In the diagnostic flow chart in the SM it does mention to adjust the pitch stopper but no procedure is listed. Link to comment Share on other sites More sharing options...
dschultz Posted July 8, 2010 Share Posted July 8, 2010 You install the pitch stopper when re-installing the engine. I don't recall any special instructions for it either, just tighten bolts to spec torque. Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 8, 2010 Share Posted July 8, 2010 Don't drive in flip flops. Start there. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
GTTuner Posted July 8, 2010 Author Share Posted July 8, 2010 You install the pitch stopper when re-installing the engine. I don't recall any special instructions for it either, just tighten bolts to spec torque. I just had the motor out so maybe it moved? Yeah, Ha ha, no more flip flops . Link to comment Share on other sites More sharing options...
GTTuner Posted July 8, 2010 Author Share Posted July 8, 2010 So nobody here has had shift fork/rod issues? Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 8, 2010 Share Posted July 8, 2010 It won't fix itself overnight. So if you said it felt better in the morning, then it's probably your paranoia more than anything mechanically wrong. If it makes you feel better, change the trans fluid with something good (motul/redline is what I always recommend). [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
GTTuner Posted July 9, 2010 Author Share Posted July 9, 2010 It won't fix itself overnight. So if you said it felt better in the morning, then it's probably your paranoia more than anything mechanically wrong. If it makes you feel better, change the trans fluid with something good (motul/redline is what I always recommend). It's paranoia. I drove it yesterday and it's fine. This is what happens when you don't drive your car for 8 months. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted July 9, 2010 Share Posted July 9, 2010 Good to hear. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2010 Share Posted July 9, 2010 So nobody here has had shift fork/rod issues? Yep. On my second tranny rebuild, they said they found a piece of one of the shift forks in the tail shaft housing. They replaced the main case on that rebuild. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted July 9, 2010 Author Share Posted July 9, 2010 Yep. On my second tranny rebuild, they said they found a piece of one of the shift forks in the tail shaft housing. They replaced the main case on that rebuild. OHH Great, now u say something. Naah, I'm just not used to how notchy the shifter was in this car. I got spooked clashing 2nd gear. Link to comment Share on other sites More sharing options...
SubaruFanatic Posted July 11, 2010 Share Posted July 11, 2010 i did the same thing... i'm pretty sure you and I bent a fork. its def harder to get in and out of 1st gear than it use to be and there is no throw stop on these shifteres so it would be easy to bend a fork. only way to fix it is to replace it I can still drive mine thought. Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 11, 2010 Share Posted July 11, 2010 It's pretty tough to bend a fork. Usually they break (like Max Capacity said his did). Still, the only fix is replacement of the fork. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
torinalth Posted July 12, 2010 Share Posted July 12, 2010 something that I had to do when I changed my clutch, the push rod on the clutch pedal can be adjusted. you may need to adjust it longer or shorter to correct the clutch length. this is MUCH more probable then bending a fork Link to comment Share on other sites More sharing options...
