m sprank Posted July 27, 2010 Author Share Posted July 27, 2010 Passenger side needs two plates if you want to leave the solenoid instead of dismantling it like me. KSTech now sells the third plate separately. I removed everything and cut apart the solenoid, so I used two plates. Both on the engine. Been two years since I have used an AP. Sorry, not sure anymore. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted July 27, 2010 Share Posted July 27, 2010 I'm tempted to do this since most recently I've had a 410 code after startup, twice now... Sorry but I'm not replacing that POS pump. I'll just remove the whole thing instead. Nice to know about the atmospheric sensor though! Link to comment Share on other sites More sharing options...
m sprank Posted July 27, 2010 Author Share Posted July 27, 2010 My pump is for sale if you want to buy it cheap. Get that code gone for ya. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted July 27, 2010 Share Posted July 27, 2010 I could also just shut off the 410 code so I never see it again... LOL Link to comment Share on other sites More sharing options...
m sprank Posted July 27, 2010 Author Share Posted July 27, 2010 that you could. Link to comment Share on other sites More sharing options...
brawline Posted October 20, 2010 Share Posted October 20, 2010 (edited) if i do the air pump delete would i have any issues when it comes time for emissions? I would have it tuned for the removal of it but would it cause any issues when i went for the emissions test. ________ LAMBORGHINI ESTOQUE HISTORY Edited May 2, 2011 by brawline Link to comment Share on other sites More sharing options...
DukeTrout Posted October 20, 2010 Share Posted October 20, 2010 The pump is only in play during startup and certain other fuel-rich times. If your emissions testing is like ours, it's done once the car is already warmed up, and the air pump shouldn't affect anything. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
B-BGTLimited Posted October 25, 2010 Share Posted October 25, 2010 Most emissions tests on OBDII cars are done by the ECM readiness anyways and no tailpipe sniffing is done. So I guess if you have no codes and your car passes all the OBDII tests, aka all disabled codes were done properly, then you should pass. My Beretta has 95% of the test systems disabled so all 4 systems show as ready after you just turn the key on, the car doesn't even have to run. LOL I wish I could just find the table in the ROM that makes the air pump run and disable it that way... Its so damn noisy on start-up, and I really don't feel like ripping it apart quite yet. Link to comment Share on other sites More sharing options...
dr_sharp Posted January 1, 2011 Share Posted January 1, 2011 How much does it weigh? Do you still have it laying around to toss on a scale? lol Link to comment Share on other sites More sharing options...
m sprank Posted January 16, 2011 Author Share Posted January 16, 2011 Total a little over 7 lbs. 1whp , LOL. Link to comment Share on other sites More sharing options...
dr_sharp Posted January 16, 2011 Share Posted January 16, 2011 That sucks, I was hoping for 20+. Ohwell, every bit helps! lol Link to comment Share on other sites More sharing options...
m sprank Posted January 17, 2011 Author Share Posted January 17, 2011 It does make it a lot easier to work around the motor without the darn pump and solenoids in the way. Link to comment Share on other sites More sharing options...
brooklyngenius Posted January 28, 2011 Share Posted January 28, 2011 damn it I need to just switch to open source already. useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
Chad W Posted April 4, 2011 Share Posted April 4, 2011 So to be clear, if you use the extra block off from KS tech, you don't get an error codes from your ecu? Link to comment Share on other sites More sharing options...
m sprank Posted April 9, 2011 Author Share Posted April 9, 2011 All you need to leave is the atmospheric pressure sensor. The extra plate from KST allows this, but keeps more than I wanted to. Link to comment Share on other sites More sharing options...
Spec.B_8 Posted August 10, 2011 Share Posted August 10, 2011 I was going to remove it, but other than aesthetics... after reading your write up on it... what possible benefits do you gain other than blocking cel's? Is there any real advantage to removing this? In the words of my friend, an experienced Subaru mechanic, "It's a pain.... in the a$$ to change the spark plugs with that in the way!":lol: So +1 for easier to work on and +1 for the weight loss! I think I’m gonna tackle mine when I get closer to the 60K service which is still a long way away! Has anyone who’s done this actually had to pass emissions yet?? I looking for a real delete and emissions pass! My friend also said some emissions places will look for the Pump and if it’s gone you will not pass… Of course this would be someone who had to know it was there in the first place and this is specific to Colorado. Link to comment Share on other sites More sharing options...
m sprank Posted August 10, 2011 Author Share Posted August 10, 2011 Dont have any advice specific to Colorado, sorry. I have a spare set of block off plates though, lol. A manufacturer sent me a set for some reason. Just showed up one day. Maybe they read the thread. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 10, 2011 Share Posted August 10, 2011 Its very easy to just drop the pump back in with that one side vent still there... And obviously the solenoid will be gone... but I doubt they would look that far. I'm curious how well it will pass emissions though with romraider disabling codes. I know I have to do it a certain way on my GM for the tests to still pass even though the components are missing. Link to comment Share on other sites More sharing options...
m sprank Posted August 11, 2011 Author Share Posted August 11, 2011 When there are Franklins involved, there is always a way. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 12, 2011 Share Posted August 12, 2011 When there are Franklins involved, there is always a way. I've never had to open my wallet to pass an emissions test and I'd like to keep it that way. Link to comment Share on other sites More sharing options...
m sprank Posted August 14, 2011 Author Share Posted August 14, 2011 Move to Cali. Wallet will open fast. But I understand. The cars are actually "clean". But do not pass "visual" as the parts manufacturers never paid the extortion fee to the state. Oh, I mean the CARB compliance testing procedure. Link to comment Share on other sites More sharing options...
Soda Popinski Posted August 21, 2011 Share Posted August 21, 2011 http://www.rallysportdirect.com/Cosworth-Air-Pump-Delete-Plates-Subaru-Turbo-Models-inc-2002-2011-WRX-STI Found these on RSD... http://www.rallysportdirect.com/catalog_photos/products/cosworth/cos1_20004539_1_lg.jpg I think i'm going to attempt this delete soon. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 22, 2011 Share Posted August 22, 2011 http://www.kstech.biz/servlet/the-10/air-pump-delete-block/Detail Way cheaper... I also bought the gaskets on this site as well. Still haven't had the chance to do it yet. Link to comment Share on other sites More sharing options...
Soda Popinski Posted August 22, 2011 Share Posted August 22, 2011 http://i139.photobucket.com/albums/q291/mechie3/airpump.jpg holy crap. how much does all that weigh? Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 22, 2011 Share Posted August 22, 2011 (edited) Most of it is all plastic, but in the first post he said he took out about 10lbs of crap taking up engine bay space. Edited August 22, 2011 by B-BGTLimited Link to comment Share on other sites More sharing options...
