m sprank Posted August 22, 2011 Author Share Posted August 22, 2011 I use KS tech. Not as pretty, but you cant see the plates. I have a prettier set a manufacturer sent me, LOL. Maybe some day I will swap them. The pump itself is plastic. The tubing from the pump to solenoids is plastic. Everything else is metal. It really is annoying. Try to change plugs... have to remove the damn air pump tubing anyway. Link to comment Share on other sites More sharing options...
Zero1 Posted August 22, 2011 Share Posted August 22, 2011 Taking the whole assembly off clears up a ton of usable space around the intake manifold and generally makes little things so much easier to work on. Thanks again for the tips and help Mike Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 25, 2011 Share Posted August 25, 2011 will be doing this in a week or so. thank you. Link to comment Share on other sites More sharing options...
Soda Popinski Posted August 25, 2011 Share Posted August 25, 2011 time wise, how long is it taking people to do this? Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 26, 2011 Share Posted August 26, 2011 I'm waiting to do mine when I do my headers and up pipe... I think getting to the right side tube and solenoid will be MUCH easier with the turbo out. I think either that way, or removing the whole intake plenum is the way to go, and I don't need to pull that quite yet... I probably should to do the gaskets though since they gave me issues when it was cold out. Link to comment Share on other sites More sharing options...
m sprank Posted August 26, 2011 Author Share Posted August 26, 2011 Much easier with the turbo out for sure. Never tried with it in. Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 26, 2011 Share Posted August 26, 2011 well my engine will be out and torn apart at the same time. Link to comment Share on other sites More sharing options...
Zero1 Posted August 27, 2011 Share Posted August 27, 2011 I took the whole intake manifold, turbo, TGV's, throttle body, intercooler, etc. all off as I was doing a lot of upgrades at once. Having everything out of the way makes it a lot easier to get to all the parts. I can't say for sure how long it took but I did like Mike and cut the atmospheric pressure sensor out of the solenoid and only needed to use the Cosworth delete plates. Taking that air pump out allowed me to use my AVO FMIC and also use the 05-07 oil fill neck which was necessary for the AVO unit. Link to comment Share on other sites More sharing options...
m sprank Posted August 27, 2011 Author Share Posted August 27, 2011 Glad it helped someone else. Link to comment Share on other sites More sharing options...
Soda Popinski Posted August 27, 2011 Share Posted August 27, 2011 is it easy for your average end user to use a COBB AccessPORT to remove the CEL's? if so, how is it done, via laptop? Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 27, 2011 Share Posted August 27, 2011 I'll be using ECUflash to remove my air pump codes. Actually I already pulled my map and disabled them. will reflash when I remove it. You can use Romraider ECU editor to disable them too. Link to comment Share on other sites More sharing options...
Zero1 Posted August 28, 2011 Share Posted August 28, 2011 As long as you know which codes need to be removed it shouldn't matter how you tune it. I have an AP and had Calvin at Cobb Plano tune my car just fine. As far as ease of use, it all boils down to whether you want to do it yourself or not. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted September 1, 2011 Share Posted September 1, 2011 I'll probably do this when I go to replace my intake gasket set. Had some starting issues in the winter and everyone points to the intake gaskets as being the culprit... It also probably wouldn't hurt to give my top end and TVG's a good cleaning. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 13, 2011 Share Posted September 13, 2011 So the disassembly began today, and I "modded" the right air valve, and this is where she will rest: http://i104.photobucket.com/albums/m194/star91281/2011-09-13_16-29-01_179.jpg http://i104.photobucket.com/albums/m194/star91281/2011-09-13_16-29-07_889.jpg Now there is enough room for my block tap-in to clear for oil supply to the new turbo, and the atmosperic pressure sensor is still there. Link to comment Share on other sites More sharing options...
m sprank Posted September 14, 2011 Author Share Posted September 14, 2011 Saves a ton of room, huh? Nice job. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 14, 2011 Share Posted September 14, 2011 oh yeah, and it was kinda fun cutting up the valve. thanks. Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted September 16, 2011 Share Posted September 16, 2011 I live in Wisconsin and didn't have this air pump on my car. I'm replacing the motor and the new one has the pump. If I take the pump off and get the gaskets and plates do you suppose I'd get any cels? That being said, where should I get the plates? Do I need 2 or 3? Link to comment Share on other sites More sharing options...
m sprank Posted September 17, 2011 Author Share Posted September 17, 2011 Your wiring harness wont even have the connections for the pump system. You would need to swap motors, wiring harness and ECM to use the pump system, Lol. Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted September 17, 2011 Share Posted September 17, 2011 ^ Thought so. Just wanted piece of mind I guess. Thanks Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted September 18, 2011 Share Posted September 18, 2011 oh yea- that leaves- Where's the best spot to get the gaskets and plates? Link to comment Share on other sites More sharing options...
m sprank Posted September 18, 2011 Author Share Posted September 18, 2011 KStech seems to have them. Thats where I got mine. Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 18, 2011 Share Posted September 18, 2011 That's where I got mine too. Cheap Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted September 18, 2011 Share Posted September 18, 2011 thanks guys Link to comment Share on other sites More sharing options...
m sprank Posted September 19, 2011 Author Share Posted September 19, 2011 Good luck with the swap. Hope she comes back healthier than ever. Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted September 19, 2011 Share Posted September 19, 2011 Good luck with the swap. Hope she comes back healthier than ever. Me too- It's been out for a couple months now. I miss my car big time. Link to comment Share on other sites More sharing options...
