frank_ster Posted May 31, 2010 Share Posted May 31, 2010 hey any body have any info on 3.0 swap into a 2.5 gt car ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Jordan Posted May 31, 2010 Share Posted May 31, 2010 Why would you want to do that? Link to comment Share on other sites More sharing options...
underground000 Posted May 31, 2010 Share Posted May 31, 2010 Why would you want to do that? everyone knows more cylinders, more liters means more powaa:eek: 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Drift Motion Posted May 31, 2010 Share Posted May 31, 2010 theres no replacement for displacement right? haha Link to comment Share on other sites More sharing options...
joeblow Posted June 1, 2010 Share Posted June 1, 2010 step 1: drive to dealershipstep 2: ask if they have any 3.0R's on the lotstep 3: test drive 3.0Rstep 4: trade 2.5GT for 3.0Rstep 5: enjoy It's cool; I'm with the band Link to comment Share on other sites More sharing options...
jagcars26 Posted June 1, 2010 Share Posted June 1, 2010 step 1: drive to dealership step 2: ask if they have any 3.0R's on the lot step 3: test drive 3.0R step 4: trade 2.5GT for 3.0R step 5: enjoy This /\ Or maybe swap in a big block Chevy motor,, Link to comment Share on other sites More sharing options...
LLBean Posted June 1, 2010 Share Posted June 1, 2010 I'm an old fart at 43 years of age. I have done motor swaps in my day, but with cars from the 70's, it is much easier.Luckily, Subaru made these relatively easy compared to most other manufactures. The tranny is compatible with both motors and the 6 is only .7" longer than the 4. (no need to modify the entire bay to cram it in) Of course I said "relatively" easy, which means you need to match up the electronics for the 6, which includes the ECU.Good luck. I am uncertain why you would like to swap the turbo 4 for the less-powerful 6 (same HP, less torque). Are you planning on modifying the stock 6? Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 1, 2010 Share Posted June 1, 2010 Maybe that huge Pontiac turbo he had in there finally took a toll on his motor? Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted June 1, 2010 Share Posted June 1, 2010 step 1: drive to dealership step 2: ask if they have any 3.0R's on the lot step 3: test drive 3.0R step 4: trade 2.5GT for 3.0R step 5: enjoy ^this. Unless you never plan on selling the car, in which case you will successfully half the resale by taking a desireable factory turbo car and swapping in a less powerful engine. On the search for a new DD... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 1, 2010 Share Posted June 1, 2010 If you can find a EZ36R for "cheap" (under $5K used) get that and the ECU and the harness however you will more than likely be finding EZ30Rs and EZ30D's the drvieline can handle the engine so that is no problem or need to change just make sure you get the ECU and harness and wiring in the ignition circuit and cluster indicators should be fairly simple once you get a pin out. You will also have to address the engine cradle and any clearance issue in the bay. Not impossible not as complicated as say a EJ257 swap into a EJ18 or better yet a EJ255 swap into a EJ253 that is just ridiculous Link to comment Share on other sites More sharing options...
frank_ster Posted June 1, 2010 Author Share Posted June 1, 2010 the idea would be 3.0 r or 3.6 r turbo set up .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
whitetiger Posted June 1, 2010 Share Posted June 1, 2010 Perrin did it a few years ago in an impreza. Link to comment Share on other sites More sharing options...
whitetiger Posted June 1, 2010 Share Posted June 1, 2010 here- http://www.perrinperformance.com/pages/show/32 Link to comment Share on other sites More sharing options...
lofthouse_gt Posted June 1, 2010 Share Posted June 1, 2010 That is an awesome build Perrin did, I heard a couple friends talk about that and then it was never brought up again, cool to see. Completely un-practical, but still very sweet. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted June 1, 2010 Share Posted June 1, 2010 Put the money it would take to do the swap into the 2.5 GT. You would have a much more reliable car that way and most likely make the same horsepower in the long run (there are more aftermarket parts out for the 2.5 than the 3.0). You will have a lighter car, it will be easier to work on and won't have the headaches of chasing all of the gremlins with the swap. If you seriously want the 3.0 than buy a 3.0 car and start from there.... much easier. Link to comment Share on other sites More sharing options...
John M Posted June 2, 2010 Share Posted June 2, 2010 The biggest thing I always wondered about the H6 swap is how do you get a 4cyl ECU to spark and spray 6 cylinders? Dividing the forces among 6 cylinders does help toward reliability at ridiculous power levels. Link to comment Share on other sites More sharing options...
legacyurabus Posted June 2, 2010 Share Posted June 2, 2010 go for a cosworth engine! Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 2, 2010 Share Posted June 2, 2010 I say go for it! Keep doing things people haven't done. frank_ster is not your average car modder. AFAIK, the only one put anything like this: http://legacygt.com/forums/showthread.php/my-answer-gt35-turbo-112481.html?t=112481 on a LGT. Link to comment Share on other sites More sharing options...
naimouasta Posted June 2, 2010 Share Posted June 2, 2010 i wouldn't mind a 3.0r + 6spd in the 2.5i. there is no 3.0r + 6spd in the US, so i'd imagine we need to run stand alone or something. Link to comment Share on other sites More sharing options...
tjbev21 Posted June 2, 2010 Share Posted June 2, 2010 here- http://www.perrinperformance.com/pages/show/32 did they paint the plastic IM? Link to comment Share on other sites More sharing options...
pachilla Posted June 2, 2010 Share Posted June 2, 2010 I have 3.0R + 5AT, and this car is far from fast....... Link to comment Share on other sites More sharing options...
frank_ster Posted June 2, 2010 Author Share Posted June 2, 2010 3.0 turbo silly ! jsut think what turbo does for the 2.5 i !!! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 2, 2010 Share Posted June 2, 2010 The biggest thing I always wondered about the H6 swap is how do you get a 4cyl ECU to spark and spray 6 cylinders? Dividing the forces among 6 cylinders does help toward reliability at ridiculous power levels. ' You use a EZ30R ECU.....duh Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 2, 2010 Share Posted June 2, 2010 3.0 turbo silly ! jsut think what turbo does for the 2.5 i !!! Well if they mad a turbo for the 2.5i guys it would be the best thing since sliced bread, but they don't IF you could follow Perrins build and use say a VF 46 and stock boost levels you would make good power. Your best source are the Aussie guys they have three or four EZ36R TT's !!!! Running and it is insane Link to comment Share on other sites More sharing options...
frank_ster Posted June 2, 2010 Author Share Posted June 2, 2010 i can make you guys 2.5 I turbo kits .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
