SpecBGuy Posted May 25, 2010 Share Posted May 25, 2010 age: 28 car: 08specB mod: nothing big just handling stuff, lighting, minor engine, interior, and exterior. future mods: brakes and rims. location: where Korean BBQ with Soju drinkers are in So.Cal Link to comment Share on other sites More sharing options...
rockle3 Posted May 25, 2010 Share Posted May 25, 2010 Any reason for going back to stock? 1) didnt want to blow my motor 2) wanted a designated track/weekend car for super fun and not a hybrid dd/tracker Link to comment Share on other sites More sharing options...
frkkevin Posted May 25, 2010 Share Posted May 25, 2010 Age: 23 Car: 2005 Legacy GT 5EAT Mods: (there are more than the list but it is too much to remember. Location: DFW, Texas Engine/Power Cosworth Cams 278/274 Brian Crower Stainless Steel +1mm Size Valves Brian Crower Valve Springs/Retainers ARP Head Studs LA Iron Sleeves Pauter Forged Rods Wiseco 100mm Forged Pistons Garrett GT4088r Turbo Injector Dynamics 2200cc Injectors Grimmspeed TGV Deletes GReddy UE/L Header Ultimate Racing Up-pipe Tial 44mm Wastegate WBR FMIC AEM Water/Methanol Injection Kit Perrin Lightweight Crank Pulley Zero/Sports Radiator Plate Custom 3" Downpipe Custom 3" Exhaust Straight Pipes Transmission Hayden Trans Cooler IPT Custom High-Stall Converter IPT Built 5EAT: Fully modified and calibrated valve body to provide quick, positive shifts Additional High-Energy Input Clutches and IPT laser cut, surface treated 1008 steel plates are installed, yielding an over 33% increase in capacity Additional High-Energy High/Low/Reverse Clutches and IPT laser cut, surface treated 1008 steel plates are installed, yielding an over 40% increase in capacity Additional High-Energy Direct Clutches and IPT laser cut, surface treated 1008 steel plates are installed, yielding an over 40% increase in capacity Redesigned lube system to prevent geartrain failure and to increase lube flow Updated High/Low/Reverse Clutch Drum Installed Heavy Duty High/Low/Reverse Snap Ring Installed Modified pump to provide increased pressure and volume Heat treated splines to prevent stripping Upgraded Center Differential Clutch Pack Suspension Cusco 23mm Front Sway Bar Cusco 21mm Rear Sway Bar Cusco F/R Lower Arm Bar/Braces Cusco Front Tower Brace K-Sport Adjustable Coil-overs Brakes Brembos Calipers F/R DBA-XS 4000 Drill/Slotted Rotors HAWK HPS Pads F/R Exterior Headlight Retrofit Infinity FX35 projectors Clear Lens Cutoff Shield Mod Denso Ballasts Phillips 85122+ D2S Bulbs DDM 3k HID Kit for Fogs Tinted Tails RBS Grill L7 Badges F/R Carbon Fiber Front Lip R-Rev Carbon Fiber Fog Covers R-Rev Carbon Fiber Mirror Scalps Rota Tarmac II 18x8 Powder Coats Black 20% Tint all around Audio/Interior Alpine CDA-9887 Alpine PXA-H701 Alpine RUX-C701 DLS Ultimate Nobelium 6.2 Illusion Audio ND 8"s Resonant Engineering SE 12"s DLS Ultimate A3 DLS Ultimate A4 DLS Ultimate A6 Hooker Wireing/RCAs Prosport Premium Boost/Volt Gauges Zero/sports Shift Boot Legacy B4 Door Sills Suede Wrapped Panels (working on seats/headliner) Custom Fiberglass A-pillars for tweeters Custom Doorpods for 8"s Custom Kickpods for 6.5s" Trunk boxed off 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
T4L Posted May 25, 2010 Share Posted May 25, 2010 Age: 30 Car: 06 Brilliant silver metallic Legacy 2.5i SE Auto (wife's car) Mods: Goodyear Eagle GT tires if that counts as a mod Miles: Around 45K Car: 96 Ruby Mica/silver Outback 2.2 5MT (mine) Mods: Painted wheels (rustolium hammered black) Truck bedliner below the doors and bottom section of front bumper subaru cd player and closing dash compartment from an 04 legacy Miles: 160,500 Location: Western PA. About an hour north of Pittsburgh. Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 26, 2010 Share Posted May 26, 2010 I'm surprised at how many of us are under 35 and even more, how many are in their early to mid 20's. Link to comment Share on other sites More sharing options...
tobey457 Posted May 26, 2010 Share Posted May 26, 2010 <--- older than most at 35 2008 Satin White LGT Limited 5mt Mods: ISC coilovers SPT 1.5 Catback Tint Kartboy shifter / bushings Sirius Coming soon: Dash rattle fix 18" wheels Dynomat / speakers Painted OEM grill Done Link to comment Share on other sites More sharing options...
lofthouse_gt Posted May 26, 2010 Share Posted May 26, 2010 AGE: 22 05 GT LTD Wagon Manual Mods: Stage 2 OTS COBB tune, Perrin Up and Down Pipe, AVO cat back, Kartboy STS, ACT lightweight wrx flywheel, ACT Clutch, R-REV CF everything (soon to be the only one with his custom CF hood as seen in the Group Buy), Kyowa Kr210 17" wheels, DBA slotted rotors, Hawk HPS pads. Coming Soon: EBCS, VF52, E85, injectors, and some Tunage! Location: Boulder, Co Link to comment Share on other sites More sharing options...
Laverne Posted May 26, 2010 Share Posted May 26, 2010 33 05 ABP LGT 5eat Wagon Mods GMS catback not installed Invidia DP(catless) Gutted upper Dropin filter Tune Culpeper VA Link to comment Share on other sites More sharing options...
spooby54 Posted May 26, 2010 Share Posted May 26, 2010 age:25 car: 05 LGT mod: DIY Grille, tinted tails, haugzaust location: Colorado Springs, CO Link to comment Share on other sites More sharing options...
Squiden Posted May 26, 2010 Share Posted May 26, 2010 Age: 33 Car: 09 Spec B Mods: - BNR 18G Turbo - TI 1000cc injectors - 255 Walbro Fuel Pump - 3-port BCS - AVO TMIC - Cobb Catted DP - Cobb F&R Sways - RalliTek springs - Brembo F&R Brake install - OZ Ultras wheels - Custom STI-honeycomb grill - HID Retro with RX330 lens - Cleared corners - iTouch screen hack to Nav screen - Redline goods leather shift boot, e-brake, and padded arm rest - STI STS Location: Castle Rock, CO Link to comment Share on other sites More sharing options...
glenmoormax Posted May 26, 2010 Share Posted May 26, 2010 age: 25 car: 08 LGT mods:gutted stock DP, tune. location:801 (SLC, UT) Link to comment Share on other sites More sharing options...
Vi3tguysoflyy91 Posted May 26, 2010 Share Posted May 26, 2010 age:19 car:Legacy GT sedan mod: ebay grille, invidia dp, borla catback exhaust, infamous1 stage 2 tune, rota tarmac 3's, cobb springs, blacked out headlights, IPT valvebody mod, Cobb intake, avo top mount, HKS ssqv recirc. location: San Jose Link to comment Share on other sites More sharing options...
Forced air Posted May 26, 2010 Share Posted May 26, 2010 age:48 car: 05 ABLGT mods: Invidia u/p and d/p, Greddy evo II catback, walbro 255, dw740, vf46, xo2 fmic, spt intake w/ aem dry flow air filt, accessport, stage II clutch(unknown name) megan coilovers, some canadian cross drilled rotors, maxim ahead wheels oem size, hid's. no other bling. location: Oxford, Ct. Link to comment Share on other sites More sharing options...
Toneranger Posted May 26, 2010 Share Posted May 26, 2010 Age: 42 Car: 09 Legacy 2.5i wagon w/touring package Mods: nothing mechanical - Rally Armor mud flaps, Venture Shield clear bra, Formula One ceramic tint, etc and some TLC ;-) Location: Bolton, ON, Canada __________________________________ Steve C. 2009 Legacy 2.5i Wagon Touring Package Satin White Pearl Link to comment Share on other sites More sharing options...
coldradio1 Posted May 26, 2010 Share Posted May 26, 2010 Age: 23 Car: 05 BSM Legacy GT Limited 5MT 53K miles Mods: DIY blacked out grill, Cobb radiator cooling plate, Hawk HPS pads, Perrin cans, BC coilovers, 18x8.5" Work Emotion 11R in bronze. Location: Murfreesboro, TN Link to comment Share on other sites More sharing options...
sleeper8406 Posted May 26, 2010 Share Posted May 26, 2010 Age: 26 Car: 05 APB Legacy GT 5MT 81K miles Mods: DIY Grill, Tinted tails, Ravspec PU lip, Freshly painted stock wheels, Cobb DP, Cobb SF intake and box, Cobb DP, Grimmspeed UP, GFB 50/50 bov, Toyo proxie 4's, Racing Brake rotors, Hawk HPS pads, Bilstein Struts (spec B conversion), Swift springs, Perrin F&R 22mm sways, Perrin F&R endlinks, Perrin front shift bushings, Kartboy Shifter, Casopolis delrin shift knob, Infamous1 stage 2 tune...soon BNR 18G Location: Orwigsburg, PA Link to comment Share on other sites More sharing options...
Scooby Fan Posted May 26, 2010 Share Posted May 26, 2010 Okay.....guess I am the oldest so far.... 65 years young 2006 LGT sedan...silver OZ Racing wheels...Crono HT 18x8 Pirelli P Zero Nero 225-40-18 OEM rims and Nokian WR G2's for winter Whiteline rear sway bar AVO catback and intake....SWEET sounds:) Debadged DRL delete and all independent light wiring....fogs etc Garmin GPS mounted in dash Stage 1 tune OEM rear spoiler.....I like it...no comments needed:) West Coast Canada:cool::cool: http://i23.photobucket.com/albums/b375/RM-RS/OZ-6.jpg No wonder I got "Grilled" at the border last time I drove down to the States...the border guard seemed a little disbelieving that I was the owner of the Legacy GT....seems I am way too old to own one in the US:confused: Link to comment Share on other sites More sharing options...
Rick Posted May 26, 2010 Share Posted May 26, 2010 Age 32 Car: 2006 LGT OBP Engine mods: Perrin cans Invidia DP Catless XO2 TBE FP68HTA Inovative WB AVO CAI XO2 FMIC Grimspeed EBS Walbro FP DW850's Killer-B oil pickup Tuned by Infamous1 Transmission mods: Full IPT built tranny Currently swapping to a 5mt with ACT HDSS, lightwieght flywheel, Group-N mount, Kartboy STS + bushings. Suspension mods: Swift springs Rota's 17x8.5's(bought them used not sure which ones) Hawk HPS+ pads Exterior: Cleared headlights Volt Hids JDM spats (I only like them with the rears installed.) Silverstar Fog Covers (They're mad JDM Yo!) Home Depot front lip Ravspec front lip (Haven't installed yet.) Ravspec grill Link to comment Share on other sites More sharing options...
07DGMSpecB Posted May 26, 2010 Share Posted May 26, 2010 Age: 27 in two weeks Car: 2007 DGM Spec B...just picked it up last week Mods: Had the car for a day and then installed some waiting parts...Invidia catted downpipe, Gimmick Motorsports catback, Tein H-techs, Cobb AP Stage 2 Link to comment Share on other sites More sharing options...
BrooklynBoy Posted May 26, 2010 Share Posted May 26, 2010 Age : 55 Car : 07 spec B. (DGM) stage2 Infamous tuned:) Mods : SPT intake CNT Downpipe Hotchkis ( Cobb ) sways ( fr&r ) SPT Ver.2 exhaust R-Rev CF grille R-Rev CF S-type spoiler STI badges on all 4 sides of the car (center caps too). If ya don't like stickers---dont look at 'em (There's enough STI goodness in every spec B ! ) Location : North Bronx , NY Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
boymk123 Posted May 26, 2010 Author Share Posted May 26, 2010 ok, so far the average is 31 youngest is 17 oldest is 65 (the car wont tell his age ) Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted May 26, 2010 Share Posted May 26, 2010 Age: 24 Car: 05 OBP LGT Unlimited 5-Speed Mods: Cobb Accessport, K&N Drop-in Filter, Perrin AFTAMAF Hose, Perrin TMIC, GFB BOV, ERZ DP, Agency Power 3" Titanium Exhaust, BC Coilovers, 08 Radio Swap, Momo Shift Knob, WRX Pedals, Autospeed Dead Pedal, RBS Eyelids, AVO Grille, V-Limited Style Front Lip, Shaved Rear Emblems Location: Raleigh, NC On the search for a new DD... Link to comment Share on other sites More sharing options...
DavidPHumes Posted May 26, 2010 Share Posted May 26, 2010 Age: 20 Car: 2005 Legacy GT Limited 5MT Limited Mod: Megan downpipe, CXLighting catback, KSport Kontrol Pro coilovers, 6000k DDM HIDs, 30% tint, Bullwinkle Stage 2 tune, blacked out grill and headlights. Location: Duluth, MN, USA http://i90.photobucket.com/albums/k265/David343/HDR.jpg Link to comment Share on other sites More sharing options...
ehsnils Posted May 26, 2010 Share Posted May 26, 2010 ok, so far the average is 31 youngest is 17 oldest is 65 (the car wont tell his age ) And Bosco hasn't checked in yet! Link to comment Share on other sites More sharing options...
CCSubaru Posted May 26, 2010 Share Posted May 26, 2010 Age: 17 Car: 2008 Legacy 2.5i Limited Mods: Debadged, Blacked Out Grill/Fog Housing, 8K HID Lows, 3K HID Fogs w/Lamin-X Yellow Film, Replaced All Accesory Interior/Exterior Lights With LED's (All Red Except License Plate), Tinted Orange Corners, AVO High Flow Panel Filter, 10" Aline Type R + Alpine 500W Mono Amplifier In Ported Box.. Suspension Is On Deck For This Summer.. Location: Cape Cod, MA Link to comment Share on other sites More sharing options...
