Canyonero Posted May 17, 2010 Share Posted May 17, 2010 OK so I just picked up my wrx wagon suspension for wagon. as i was doing so my friend also handed over his stock td04 turbo and up pipe and down pipe. So the question is can i use this stuff to turbo charge my outback? I am currently sourcing a top mount I/C, manifold, etc.... has anyone done this before? i am only expecting to boost about 6 lbs. pros/cons? Other alternatives? Link to comment Share on other sites More sharing options...
kaz98gt Posted May 18, 2010 Share Posted May 18, 2010 I wouldn't even go with 6psi, it might be too much for the stock 2.5 to take. if you want to run a noticeable amount of boost, you need to build the motor up to handle more pressure. there's another thread floating around about turboing a stock 2.5, and it's full of stuff that you could do/not do, and any tips for where to go from here. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted May 18, 2010 Share Posted May 18, 2010 Your head gaskets probably wouldn't be alive long enough to cry. Link to comment Share on other sites More sharing options...
Canyonero Posted May 18, 2010 Author Share Posted May 18, 2010 damn ok. thanks turbo go backs to the owner. =( Link to comment Share on other sites More sharing options...
something different Posted May 27, 2010 Share Posted May 27, 2010 just get an ej255 or 257 engine with the ecu from a 04 xt or sti, but then your trans is gonna be unhappy. Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 Problem with "just" getting those motors is the fact they are not very cheap. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 so true^Â expensive experiments arent fun Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 I will be turboin' my EJ22 to see what I can make out of it with 6 pounds. Yes I will be running a piggyback system. Curious to see what this can do. I have heard of it out doing 2.0L WRX's (stock of course). Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 you'll definitely notice 6psi, some boost is better than no boost Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 I really love the low end torque down little dirt/gravel roads. Can't wait to get boosted. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 ive noticed alot of lag in the 0-3k rpm range, but at like 3100rpm i take off like crazy.. its like i have vtec yo! it only happens sometimes, other times im all sortsa torqey Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 Exactly! But you're not turbo'd are you? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 nope... Â ive decided she will stay n/a for the rest of her life Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 thats most likely a lie Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 Yeah what kind of WHP would you guess the EJ22 Would even make? With 6 pounds of course. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 27, 2010 Share Posted May 27, 2010 youll moe than likely break the 200+ range Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 That's what I like to hear. I am hoping to find a way to run it on E85. Bigger injectors/Pump and fuel rails? Link to comment Share on other sites More sharing options...
bmwpride Posted May 27, 2010 Share Posted May 27, 2010 im boosting my 2.5 and im going to be risky and see 8psi........ Ill see what the does Link to comment Share on other sites More sharing options...
Baddog Posted May 27, 2010 Share Posted May 27, 2010 Make sure your headgaskets are replaced. Link to comment Share on other sites More sharing options...
Bassnectar Posted May 27, 2010 Share Posted May 27, 2010 you know E85 will murder your mileage even though its beter for the environment its probably gonna be more expensive than running premium Link to comment Share on other sites More sharing options...
Baddog Posted May 28, 2010 Share Posted May 28, 2010 It's more for the fact of the lower combustion chamber temps and me running the stock EJ22 on a turbo soon. Trying to keep the motor alive and away from pre-detonation Link to comment Share on other sites More sharing options...
