rs6er Posted April 21, 2010 Share Posted April 21, 2010 My floor jack has a piece that fits in it so I don't crush the sheet metal at the jack points. Where can I put the stands so they don't crush it? Link to comment Share on other sites More sharing options...
whitetiger Posted April 21, 2010 Share Posted April 21, 2010 the pinch weld is pretty strong. should be ok there. Link to comment Share on other sites More sharing options...
rao Posted April 21, 2010 Share Posted April 21, 2010 Subaru thinks it can handle it. There are notches around about a 2" part of the pinch weld on both sides near the front and rear wheels that are designed to support the car on either a lift or jack stands.Jacking Points.pdf Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rs6er Posted April 21, 2010 Author Share Posted April 21, 2010 whitetiger- Any reason not to reuse the copper gaskets on the 2 rear diff bolts (6 speed). The stealer wants $7/each for them. Link to comment Share on other sites More sharing options...
mustangendsley Posted April 21, 2010 Share Posted April 21, 2010 Our jack points in the legacy are crap. I was really thinking about putting rally jacks in and use the triangle suports for jacking a car up. Link to comment Share on other sites More sharing options...
rao Posted April 21, 2010 Share Posted April 21, 2010 Well the whole car is crap so that is not a bad idea. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
JoeFromPA Posted April 21, 2010 Share Posted April 21, 2010 Can I use a regular jack-pad to jack up on those seams without crushing them? Always avoided it for fear of bending the metal. Link to comment Share on other sites More sharing options...
rao Posted April 21, 2010 Share Posted April 21, 2010 They are the FACTORY JACKING POINTS, I believe that a safe inference is that they can be used for jacking the car You can't use the whole seam but if anyone actually ever LOOKED at an actual car, they would see that the areas shown in the FACTORY SERVICE MANUAL are reinforced - one could assume that they are reinforced for use as jacking points, which means that they can be used to jack the car Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
legacyCT Posted April 21, 2010 Share Posted April 21, 2010 They are the FACTORY JACKING POINTS, I believe that a safe inference is that they can be used for jacking the car You can't use the whole seam but if anyone actually ever LOOKED at an actual car, they would see that the areas shown in the FACTORY SERVICE MANUAL are reinforced - one could assume that they are reinforced for use as jacking points, which means that they can be used to jack the car Dont forget to add some Spec B oil to the jack for extra protection! Link to comment Share on other sites More sharing options...
rao Posted April 21, 2010 Share Posted April 21, 2010 Obviously, and some synthetic grease to lube up the jack point so it does not get damaged. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
IanB Posted April 21, 2010 Share Posted April 21, 2010 Since there's a thread started, where do you guys jack the car from when you want the front up on jackstands? I have a real hard time seeing where the saddle is under the car to use the brace between the engine and tranny, the belly pan is in the way, and the car is almost too low for my jack to fit under there, maybe I just need more practice? If you jack from the side, then the jack is where you would put the jackstand, so that doesn't work real well. Link to comment Share on other sites More sharing options...
whitetiger Posted April 21, 2010 Share Posted April 21, 2010 i still jack ont he pinch weld, but leave room to pu tthe stand next to the jack. Link to comment Share on other sites More sharing options...
whitetiger Posted April 21, 2010 Share Posted April 21, 2010 whitetiger- Any reason not to reuse the copper gaskets on the 2 rear diff bolts (6 speed). The stealer wants $7/each for them. if you can crush them some more to make a good seal, then i dont see why you can re-use them. i reuse the oil plug crush ring a few times before i replace it. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted April 21, 2010 Share Posted April 21, 2010 i reuse the oil plug crush ring a few times before i replace it. you do?! I've heard bad things about re-using crush washers [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
whitetiger Posted April 21, 2010 Share Posted April 21, 2010 oh so thats why my car blew up 3 times already. Link to comment Share on other sites More sharing options...
JoeFromPA Posted April 21, 2010 Share Posted April 21, 2010 They are the FACTORY JACKING POINTS, I believe that a safe inference is that they can be used for jacking the car Jeebus Rao, I INFER that you didn't read my question. I didn't ask if I could jack from them. I asked if i needed a special jack pad designed to embrace the seam weld, as shown in the pictures in the PDF you attached, or if I could just jack up on them with a normal perfectly flat jack pad without crimping the metal. Link to comment Share on other sites More sharing options...
rao Posted April 22, 2010 Share Posted April 22, 2010 You would use a standard jack pad to jack up a car Is there no end to the cruelty Put your jack under the magic spot and jack the car up. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
JoeFromPA Posted April 22, 2010 Share Posted April 22, 2010 Ok, but if it bends I will set a quart of synthetic oil on fire over an image of you. Link to comment Share on other sites More sharing options...
pillboy Posted April 22, 2010 Share Posted April 22, 2010 I never thought the "magic spot" was in reference to a jacking point... It is still ugly. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted April 22, 2010 Share Posted April 22, 2010 There is stuff you can get if you do not want to scratch the metal (corrosion issues, although the dealership probably already has when they did PDI). http://images.harborfreight.com/cpi/photos/95900-95999/95952.gif These are my next jack stands: http://www.northerntool.com/images/product/images/146640_lg.jpg There are others you can get. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
mustangendsley Posted April 22, 2010 Share Posted April 22, 2010 i like the 3 leged ones. which one is that? Link to comment Share on other sites More sharing options...
Claw Posted April 22, 2010 Share Posted April 22, 2010 Looking at the label on the leg, my guess - ESCO stands. http://www.asedeals.com/flat-top-jack-stands.html Link to comment Share on other sites More sharing options...
mattg Posted April 22, 2010 Share Posted April 22, 2010 It only takes a moment to identify the jack points on the rocker pinch weld. Link to comment Share on other sites More sharing options...
pattypat Posted April 23, 2010 Share Posted April 23, 2010 Frame rails work good. And I Jack the front up right behind the oil pan. Link to comment Share on other sites More sharing options...
leftcoast74 Posted February 6, 2012 Share Posted February 6, 2012 Bump for those Esco flat top stands Link to comment Share on other sites More sharing options...
