CCType-S Posted March 22, 2010 Share Posted March 22, 2010 06 with 47,000 miles. stg2 since 2 years ago. Link to comment Share on other sites More sharing options...
finse Posted March 22, 2010 Share Posted March 22, 2010 My turbo is running fine, but will be performing some preventative maintenance... I am planning on replacing it with a 68HTA is a 4-6 weeks. Link to comment Share on other sites More sharing options...
CwhillVT Posted March 22, 2010 Share Posted March 22, 2010 05 with 84k (got it w/ 30k), Been stage 1 then 2 and now OS 2 since buying it and no problems with the turbo or engine. Link to comment Share on other sites More sharing options...
HDTurbo Posted March 23, 2010 Share Posted March 23, 2010 '05 LGT wagon, new turbo since 89K(wrrty.cvd!), AP Stg1 since 89.1K, dino-syn blend since 91.5k. Waiting on ERZ CDP GB; then an UP for Stg Dos...still pulls strong, but need a rock thru the windshield (for replacement) to augment visibility...ABS reinforces h'wy close-contact resulting in front-end silico-delamination of paint and w'shield pitting... sorry for das ramblingz... Link to comment Share on other sites More sharing options...
JoeFromPA Posted March 23, 2010 Share Posted March 23, 2010 Man, when you read threads like this sometimes you realize just how much you drive... 08 LGT, 40.5k miles, engine and trans running just fine. Oil changed every 3500 miles or so with whatever synthetic I have on hand. Problems with the car have been limited to: 1 burnt out brake light bulb Corrosion on all four wheels growing out from the center cap (Subaru is looking into this) TOB whine sometimes (came up around 20k, got really bad sometimes, and now seems to happen less often in the last 2-3k). Link to comment Share on other sites More sharing options...
boymk123 Posted March 23, 2010 Share Posted March 23, 2010 Man, when you read threads like this sometimes you realize just how much you drive... 08 LGT, 40.5k miles, engine and trans running just fine. Oil changed every 3500 miles or so with whatever synthetic I have on hand. Problems with the car have been limited to: 1 burnt out brake light bulb Corrosion on all four wheels growing out from the center cap (Subaru is looking into this) TOB whine sometimes (came up around 20k, got really bad sometimes, and now seems to happen less often in the last 2-3k). Mine 08 has 76k miles Edit: I replaced both front struts due to potholes.. Link to comment Share on other sites More sharing options...
boosted subaru Posted March 23, 2010 Share Posted March 23, 2010 83k on my 05 and running strong! Link to comment Share on other sites More sharing options...
Max Capacity Posted March 23, 2010 Share Posted March 23, 2010 Some of you guy's really need to get out and drive your car more. 05GT Wagon 123,000 miles been at stage 1 93 Octane since Dec 04 at about 8000 miles. I use whatever dino oil is on sale at Walmart and Fram filters. Change oil between 3000 and somewhere just over 5000 miles depending on the outsied air temp. If it's to cold I'll go longer. I also drive more highway miles in the winter time. Car see's redline (7300) a few times a week if not more. Still have the banjo filter that Subaru put in there at the factory. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mustangendsley Posted March 23, 2010 Share Posted March 23, 2010 05 gt 77K and no problems. valvoline synthetic oil every 3K, stage 1 16 pouns of boost and I track my car 1 time a month. Link to comment Share on other sites More sharing options...
JohnnyT Posted March 23, 2010 Share Posted March 23, 2010 '06 GT w/ 75K. Bone stock. Turbo running fine....smooth as silk. Change oil every 3k miles or sooner (depending if I'm going on a trip or not) with Castrol GTX 5W30 and NAPA Gold filter. Link to comment Share on other sites More sharing options...
fishbone Posted March 23, 2010 Share Posted March 23, 2010 Almost 80K, car has been modded since 45K miles. Turbo is fine, banjo bolt repalced at around 50K miles and it was absolutely spotless. Link to comment Share on other sites More sharing options...
OmniEnder Posted March 23, 2010 Share Posted March 23, 2010 Well I'm at 118k miles on my 05'. I drive the thing like I stole it most of the time because the dealer gave me a 36k warranty on it when I bought it at 108K... Change the oil every 3k, recently checked the banjo to see how it was and it had been removed already. I'm hoping that I can blow this thing before the warrany runs out but it is looking like if you take care of business these things are tough to break... Note: the turbo was replaced at 47k meaning that there is only 71k on it.. still damn good! Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted March 24, 2010 Share Posted March 24, 2010 78K on my '05 GT 5EAT, bought at 48K and no problems to report. Original turbo as far as I know. Changed Banjo bolt filter at 71K (about) and it was spotless. Since I've owned it oil changes every 3500-4000 with a variety of synthetics. Most commonly and currently GC 0W-30. Tranny drain and fill every 10-15K. Sees red-line once or twice a week maybe, mostly boring daily driving around town. Link to comment Share on other sites More sharing options...
pillboy Posted March 24, 2010 Share Posted March 24, 2010 2005 with 33,000 miles. Stock. However with all my time on this forum I don't trust my turbo any father than I can throw a 55 gallon drum of Mobil-1. It is still ugly. Link to comment Share on other sites More sharing options...
BigBad Posted March 24, 2010 Share Posted March 24, 2010 68K and still running strong with no turbo issues Link to comment Share on other sites More sharing options...
Max Capacity Posted March 25, 2010 Share Posted March 25, 2010 2005 with 33,000 miles. Stock. However with all my time on this forum I don't trust my turbo any father than I can throw a 55 gallon drum of Mobil-1. May be you should stop wasting your money buying Mobil 1 and do what do... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
fishbone Posted April 6, 2010 Share Posted April 6, 2010 Rolled 80K miles just yesterday. Literally the only mechanical problem I've ever had with this car was a speed sensor that died. Other than that, she's been Stage 1 at 38K miles/July 2007 and Stage 2 since 56K miles/June 2008 Link to comment Share on other sites More sharing options...
Ryandigi Posted April 6, 2010 Share Posted April 6, 2010 32,000 miles and OCI at 2000 or less miles (pretty much every 4-7 months) with dino oil...stage 2 since 15k. Zero problems thus far...I am currently banging on wood! Link to comment Share on other sites More sharing options...
dftank2 Posted April 6, 2010 Share Posted April 6, 2010 05 with 47k been stage 1 for a long time and stage 2 for about the last 10k no prob with the turbo or anything at all oil change every 2500. Link to comment Share on other sites More sharing options...
I 5EAT Turkey Clubs Posted April 6, 2010 Share Posted April 6, 2010 My turbo blew at 75k. I just wanted to chime in to say the OP has the best avatar evar! Cheers to 'altered' animals. Link to comment Share on other sites More sharing options...
dazzen Posted April 6, 2010 Share Posted April 6, 2010 My turbo blew at 75k. I just wanted to chime in to say the OP has the best avatar evar! Cheers to 'altered' animals. off topic....no doom and gloom in this thread! Link to comment Share on other sites More sharing options...
Slickvic Posted April 11, 2010 Author Share Posted April 11, 2010 off topic....no doom and gloom in this thread! {gets on Soap box} Yeah sorry about that. I was getting sick and tired of new members who know nothing about Subaru's posting questions like "I see all these threads about blown turbos....should I be afraid to buy a Legacy GT?" WTF? Do some research and due diligence. What you read here is a skewed representation of the total number of turbo charged Subaru owners. {Gets off Soap box} Carry on.... Link to comment Share on other sites More sharing options...
Crossing509 Posted April 11, 2010 Share Posted April 11, 2010 48k miles on my 2006 5EAT and the stock turbo is still going strong. Stage 2 running 18.75 psi with Perrin TMIC. No issues...yet...but I'm researching turbo upgrade options. I don't expect the stocker to last forever. I change my oil every 3,000 miles. ...Support your LGT community... Link to comment Share on other sites More sharing options...
BrooklynBoy Posted April 11, 2010 Share Posted April 11, 2010 Original owner.....52k miles.......change dino liquid every 3K.......original 5 arc turbo still going strong!(to the subie brothers that change their oil at intervals longer than 4000 miles------why? Our turbos cook oil much faster than NA engines....a fresh oil change is the cheapest insurance policy ! ) Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
