Draco-REX Posted October 19, 2010 Share Posted October 19, 2010 So the general consensus is to change these every 60k miles I assume. I wouldn't want to take a chance of belts getting as bad as this. Anyone have any experience of Gates vs. OEM? They are a snap to inspect. Just look at the ribbed part of the belt. If you see any cracks in the rubber, replace it. It's a piece of cake to do. Just take a peek next time you're checking your oil. Link to comment Share on other sites More sharing options...
djkxgo0k Posted October 26, 2010 Share Posted October 26, 2010 are there two different belts? one for PS and one for a/c and alternator? or is it all just one belt? Link to comment Share on other sites More sharing options...
djkxgo0k Posted October 26, 2010 Share Posted October 26, 2010 looks like there are two belts. how would one replace the AC belt? Link to comment Share on other sites More sharing options...
Val Demar Posted October 26, 2010 Share Posted October 26, 2010 There are two belts. For the AC there is an adjustable tension pulley, loosen the belt with it, take the old one off/put the new one on, use the pulley to properly tension it. More or less so, it's been a while since I replaced mine and forgotten the details. This reminds me I need to adjust tension to stop that occasional belt slipping noise I get in the morning... PS: you need to loosen the bolt in the center of the tension pulley first to allow it to travel up and down when turning the adjustment bolt, and tighten it back to fix the pulley in place in the end, I think that's right... Link to comment Share on other sites More sharing options...
djkxgo0k Posted October 28, 2010 Share Posted October 28, 2010 would it be anything similar to this? it's on an impreza but it seems the general concept might be the same [ame=http://www.youtube.com/watch?v=adkvVaYOIoU]YouTube - Changing Air conditioning and Power steering Belts on a Impreza[/ame] Link to comment Share on other sites More sharing options...
Val Demar Posted October 28, 2010 Share Posted October 28, 2010 Yup, pretty much the same. Link to comment Share on other sites More sharing options...
outahere Posted November 10, 2010 Share Posted November 10, 2010 At 34,000 miles and 5 years, I removed the OEM (Mitsuboshi) Alt/PS belt and inspected it. Found zero cracks in it. Will keep it stored in my car as an emergency spare. I installed a Dayco PolyRib 'W" belt. Dayco says the W design reduces belt noise, but I have noticed no change in the noise level. The ribs on the Dayco are about half the depth of those on the OEM belt, but this has not resulted in any problems, so far. Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted November 22, 2010 Share Posted November 22, 2010 Hi, I'm looking at replacing the Alt/PS and the AC belts. Does anyone have a recommendation on which model to pick up from Autozone or some other major auto parts chain that I hopefully have in Vegas? Link to comment Share on other sites More sharing options...
morrisco Posted December 15, 2010 Share Posted December 15, 2010 Alright guys; I just had my belts replaced. After a couple days, they started squealing terribly. I'm sure my neighbors hate me every morning when I start my car at 5am. It's ridiculous!! After a few minutes of yelling at me, the belts go quiet. I imagine that it has something to do with the tension of one of the belts. Any suggestions on how to determine which belt? Can a belt be too tight? How can I tell if the belt is too loose? Link to comment Share on other sites More sharing options...
Val Demar Posted December 15, 2010 Share Posted December 15, 2010 Likely one or both belts are loose. W/o the proper belt tension gauge it may be difficult to tell, try to press on both belts with your finger, you may be able to tell which one is more loose, if so go for it. If not just tighten one, if it doesn't help then the other. Or just go to the place where you had the work done and complain, they should fix it for free as they didn't properly tension the belts in the first place. I get an occasional squeak in the morning too, but too lazy to fix it. The other unlikely reason may be the alternator or AC bearings are going bad, so if tightening doesn't help I'd look into that. Link to comment Share on other sites More sharing options...
2soon Posted December 23, 2010 Share Posted December 23, 2010 Well I just did this last night and now when i do to stop the belts sound like they are squealing, but only when i press the brakes. This morning the fat belt was loose I tightened it up. The squealing stopped, but as I pulled up to work it started again. Anybody ever had this happen? I guess I will be checking the bearings later. Link to comment Share on other sites More sharing options...
Val Demar Posted December 23, 2010 Share Posted December 23, 2010 Just tighten up a bit more, the fact it helped indicates there was not enough tension. The belts must be pretty tight after all to transfer all that torque needed. Link to comment Share on other sites More sharing options...
outahere Posted December 26, 2010 Share Posted December 26, 2010 ........I imagine that it has something to do with the tension of one of the belts. Any suggestions on how to determine which belt? Can a belt be too tight? How can I tell if the belt is too loose? http://legacygt.com/forums/showthread.php/drive-belt-tightness-148625.html?t=148625&highlight=belt+tension Link to comment Share on other sites More sharing options...
Richard T Posted December 11, 2011 Share Posted December 11, 2011 Thank you for the write-up and pictures, AndrewZ. I would have made this worlds more complicated than it needed to be had I not found this. After 71k miles on my '05, the belt looked similar to the photos already uploaded. I was experiencing the squeak and notchy steering before the fix. With the new belt in hand, the 10 minute fix made my wife think I'm a badass. Handiest how-to I found on the subject. Search FTW. Link to comment Share on other sites More sharing options...
fatesdeathak Posted June 1, 2013 Share Posted June 1, 2013 so i had this same problem around 180,000 miles. But upon removal of everything i found that the tensioner (bolt C) is also broken... i can't find this part ANYWHERE! i need some serious help finding this part. if anyone could help i would really appreciate it thanks! Link to comment Share on other sites More sharing options...
vet Posted August 9, 2013 Share Posted August 9, 2013 Please don't pay anyone to change this belt, it's the easiest repair I've ever done. Almost as easy as changing your air filter. Mine lasted 113k before it self destructed. Link to comment Share on other sites More sharing options...
starclassic Posted August 28, 2013 Share Posted August 28, 2013 Andrew, thanks for this walkthrough. It helped me out a bunch doing a drive belt change on my own '05 OBXT. After loosening the lock bolts for both belt assemblies, I had to back out the tension bolts almost the entire way to get enough slack to get the old belts off. Looking back on it, it's a pretty simple process changing these belts. Nice that they're so easy to access. Cheers and thanks again. Link to comment Share on other sites More sharing options...
zisforzachary Posted June 22, 2014 Share Posted June 22, 2014 any word on how much play exactly should be on this belt? mine broke today. then i found this thread Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2014 Share Posted June 24, 2014 1/4" to 3/8" or not much. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
