subaruski Posted December 29, 2009 Share Posted December 29, 2009 Um, is the bushing on the a-arm supposed to look like this? Seems like it is tearing to me? http://i17.photobucket.com/albums/b77/Subaruski/My%20cars/photo.jpg Link to comment Share on other sites More sharing options...
subaruski Posted December 29, 2009 Author Share Posted December 29, 2009 nobody? Link to comment Share on other sites More sharing options...
slimjoe Posted December 29, 2009 Share Posted December 29, 2009 That looks like the rear bushing for the lower control arm (LCA) to me. I just find it funny that lots of people (including me) have been asking about the status of these bushings. Look around and you'll see a bunch of thread's about them. Short answer though is yes, they're torn and should probably be replaced. There are standard bushings and offset ones that increase caster by 0.5*. Link to comment Share on other sites More sharing options...
Underdog Posted December 29, 2009 Share Posted December 29, 2009 This is a very common problem with our 4th gens'. "LCA rear bushing" will turn up a bunch of hits... Most of the time Subaru will claim it is normal wear-and-tear. Many of the members, myself included, will recommend replacing them with a poly version such as the AVO units. They make a huge improvement in steering response and stability. The Crimson Dynamo Link to comment Share on other sites More sharing options...
subaruski Posted December 29, 2009 Author Share Posted December 29, 2009 This is a very common problem with our 4th gens'. "LCA rear bushing" will turn up a bunch of hits... Most of the time Subaru will claim it is normal wear-and-tear. Many of the members, myself included, will recommend replacing them with a poly version such as the AVO units. They make a huge improvement in steering response and stability. Who is a good vendor that would carry these? I'm assuming should replace the front bushing also if i do the rears. Link to comment Share on other sites More sharing options...
thebootyhouse Posted December 29, 2009 Share Posted December 29, 2009 Here's the poly kit if you aren't into any additional road noise. Cheaper and on sale(discontinued). http://www.rallitek.com/pofukitcoarm1.html Here's the Perrin kit if you don't care about noise and/or are tracking the car. I have these and they're great! http://www.perrinperformance.com/products/show/276/Anti-Lift-Kit-PSRS-ALK?category=8&model=10 and the new 0 degree http://www.perrinperformance.com/products/show/743/Anti-Lift-Kit-PSRS-ALK-Zero-Deg-?category=8&model=10 and a couple more - AVO parts 0 degree http://www.rallitek.com/avocaadbuca.html .5 degree http://www.rallitek.com/avocaadbusy.html Link to comment Share on other sites More sharing options...
SBT Posted December 29, 2009 Share Posted December 29, 2009 I got mine directly from Paul Hansen at AVO in Washington State. Info/link here for both the 0* and +.5* AVO LCA bushings. AVO calls it the "Caster Adjustment Bushing System" if that helps. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Underdog Posted December 29, 2009 Share Posted December 29, 2009 I believe there is a grpN variant for both the front and rear LCA bushing. Unclemat or rallispec can probably help you out with a P/N. To clarify for noobies, that is the front and rear bushings for the lower control arms in the front suspension. For the rear suspension, the main component is called the "trailing link". The Crimson Dynamo Link to comment Share on other sites More sharing options...
system60 Posted December 30, 2009 Share Posted December 30, 2009 I did the AVO rears and a set of 08 STi fronts in my wagon and didn't notice much of any increase in NVH. Only other thing I've done to the car are brakes and RCE Tarmac1's Link to comment Share on other sites More sharing options...
