DEEPfrom1 Posted December 16, 2009 Share Posted December 16, 2009 Hey everyone, I am new to subies but not to cars. The front end of my car is very "loose" feeling when I drive, very disconnected feeling when I drive. It makes noises that sound like the top hats need to be replaced over bumps. However they were just replaced. I put the car on the lift and the only thing that moved and looked worn out where the control arm bushings. The ones that bolt to the "frame" then to the control arm (lower control arm). Anyone have similiar issues. I am driving a 99 LGT. Also I have been looking all over for these bushings and can't find anything! Any energy suspension master kits? I am having a hell of a time finding anything for this car! Thanks everyone Link to comment Share on other sites More sharing options...
WESTcoast Posted December 16, 2009 Share Posted December 16, 2009 make sure your front sway bar is still there:lol: What did you mean by energy master kits lol Link to comment Share on other sites More sharing options...
DN1911 Posted December 17, 2009 Share Posted December 17, 2009 once these cars get some miles under them, the steering rack bushing, control arm bushings, and sway bar bushings all get worn out and can cause a vague and loose feel. the older Subies were never very connected to begin with...... Link to comment Share on other sites More sharing options...
DEEPfrom1 Posted December 27, 2009 Author Share Posted December 27, 2009 Well energy suspension makes a "master bushing kit" for must vehicles, was wondering if anyone on here has found one? It comes with every bushing for the car. Can some one give me a good place to order the steering rack,control arm and sway bar bushings from? Link to comment Share on other sites More sharing options...
DEEPfrom1 Posted December 29, 2009 Author Share Posted December 29, 2009 BUMP! It now feels like something is going to fall off the car when I hit bumps? Driving down the highway it likes to pull left. The car was aligned a year ago, it has new tires, struts and top hats. Does this sound like it could be the front LCA bushings? I had it up on the lift and everything seemed tight and good, except those bushings had a little bit of give to them. I am stumped. Input would be lovely. Thanks all! Link to comment Share on other sites More sharing options...
amp27 Posted March 2, 2010 Share Posted March 2, 2010 i also have a pretty bid knock when i take 90s at 35mph. and when i hit bumps. that bushing thing makes perfect sense as to why that knock happens. i recomend measuring the part and looking for a part that would still fit Link to comment Share on other sites More sharing options...
Bassnectar Posted March 2, 2010 Share Posted March 2, 2010 check your grille clips man because thats what knock i get on bumpy roads and thats the only time i get it Link to comment Share on other sites More sharing options...
dease42 Posted March 3, 2010 Share Posted March 3, 2010 aftermarket bushings discussion: http://www.legacygt.com/forums/showthread.php?t=78091 I'v got an 05 and the lca bushings are going (verified, for sure), feels the same way (80K+miles). Link to comment Share on other sites More sharing options...
DN1911 Posted March 9, 2010 Share Posted March 9, 2010 look at the lower control arm rear bushing, is there any sort of sticky, oily substance coming out of it? if there is it is shot and needs to be replace with a Whiteline ALK Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 9, 2010 I Donated Share Posted March 9, 2010 BUMP! It now feels like something is going to fall off the car when I hit bumps? Driving down the highway it likes to pull left. The car was aligned a year ago, it has new tires, struts and top hats. Does this sound like it could be the front LCA bushings? I had it up on the lift and everything seemed tight and good, except those bushings had a little bit of give to them. I am stumped. Input would be lovely. Thanks all! check your tie rods and ball joints.....if those check out ok look and your strut mounts. There are only so many things that it can be....get your car up in the air and start shaking everything. If the lower control arm bushings have play in them like you said, thats likely the cause of the noise. Take care of those and then go from there. If it wasn't what was making noise, it won't hurt to replace them anyways since they are 10 years old and likely have a lot of miles on them -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
