joeleodee Posted December 19, 2009 Share Posted December 19, 2009 which clutch did you end up using to replace oem? I have not yet replaced it and still slipping under 3rd and 4th gear hard acceleration sometimes. I will be going with the ACT Street Disc and WRX flywheel. Check some of the threads in the 'Transmissions' section and you will find some more definitive answers of why I am choosing that. HERE is a good start. Link to comment Share on other sites More sharing options...
phuzaxeman Posted December 19, 2009 Share Posted December 19, 2009 I have not yet replaced it and still slipping under 3rd and 4th gear hard acceleration sometimes. I will be going with the ACT Street Disc and WRX flywheel. Check some of the threads in the 'Transmissions' section and you will find some more definitive answers of why I am choosing that. HERE is a good start. any link to order these parts? Link to comment Share on other sites More sharing options...
JoeFromPA Posted December 21, 2009 Share Posted December 21, 2009 Someone mentioned awhile not (not verifying the truth behind this) that Cobb had stated, clearly, that they'd be tweaking and releasing a new version of the LGT map sometime in the new year with some lessons learned in a few areas. It will still always be an OTS conservative tune focused on safely raising power in as many areas as possible. I hope they do release something with a bit better (i.e. more consistent) AFRs and knock avoidance. To me, a safe bet for a newbie or someone wanting plug, play, and walk away would be to use a Cobb 91 octane map and run 92-93 octane gas. And JB Weld the stock Intercooler endtanks. Link to comment Share on other sites More sharing options...
fishbone Posted December 21, 2009 Share Posted December 21, 2009 They need to incorporate the ability to log/view Knock Sum and FBKC with the AP. It is a bitch to interpret FBKC based on DA Link to comment Share on other sites More sharing options...
ohiotrojan Posted December 21, 2009 Share Posted December 21, 2009 been stage 2 for 30k and NO PROBLEMS..love it, its fast and gets great mpg... Link to comment Share on other sites More sharing options...
zeusdog34 Posted December 22, 2009 Author Share Posted December 22, 2009 ^^^ whats your peak boost,what DP,what other mods?. thanks Link to comment Share on other sites More sharing options...
dwolson2 Posted December 22, 2009 Share Posted December 22, 2009 Also look to infamous1 and open source. I am open sourced tuned, and I love it! Link to comment Share on other sites More sharing options...
ohiotrojan Posted December 22, 2009 Share Posted December 22, 2009 have no idea what peak boost is, but its the standard ots cobb stage 2 map.....have cobb dp and spt cat back.....no other power mods.... Link to comment Share on other sites More sharing options...
fishbone Posted December 22, 2009 Share Posted December 22, 2009 Then I think it is right around 16PSI or so. Link to comment Share on other sites More sharing options...
mustangendsley Posted December 22, 2009 Share Posted December 22, 2009 That can't be right. Im stage 1 at 16 psi on stock turbo, 750 dw injectors,walbro fp,stock dp and spt cb. turbo kicks in very fast with this os tune. Link to comment Share on other sites More sharing options...
fishbone Posted December 22, 2009 Share Posted December 22, 2009 See for yourself http://www.accessecu.com/accessport/subaru/new/08LGTMaps.html 05LGT maps are the same, boost targets are not transmission dependent either. 16PSI target boost +- 0.8PSI Link to comment Share on other sites More sharing options...
05lgt5spd Posted December 23, 2009 Share Posted December 23, 2009 I'm in p-town as well. If you need any help let me know. So am I. What you need to do is ride in a stage 2 car to see if its good enough for you. But like most people, you will go stage 1, it will feel fast, then slow. Then continue the process with each stage. I bought my car at stage 2 and told my gf, "this is great because Its fast enough, I don't have to mess with it!" Two months later im stg3+ and negative large amounts of cash Link to comment Share on other sites More sharing options...
05lgt5spd Posted December 23, 2009 Share Posted December 23, 2009 That can't be right. Im stage 1 at 16 psi on stock turbo, 750 dw injectors,walbro fp,stock dp and spt cb. turbo kicks in very fast with this os tune. what is the purpose of having 740's and pump on stage 1? Link to comment Share on other sites More sharing options...
fishbone Posted December 23, 2009 Share Posted December 23, 2009 Groundwork for future upgrades Link to comment Share on other sites More sharing options...
zeusdog34 Posted December 24, 2009 Author Share Posted December 24, 2009 well i received my Cobb a2(thanks Izzy) and now my car is at stage 1, def feels stronger,much smoother.I ordered my ERZ catted DP and as soon as it arrives will be going to stage 2..How accurate do you think Cobb is with the HP and TQ estimates they have listed on there website(305hp,345tq stage 2) and (285hp.305tq stage 1).. thanks for every ones input Link to comment Share on other sites More sharing options...
Strizzy Posted December 24, 2009 Share Posted December 24, 2009 well i received my Cobb a2(thanks Izzy) and now my car is at stage 1, def feels stronger,much smoother.I ordered my ERZ catted DP and as soon as it arrives will be going to stage 2..How accurate do you think Cobb is with the HP and TQ estimates they have listed on there website(305hp,345tq stage 2) and (285hp.305tq stage 1).. thanks for every ones input I'm pretty sure they are not measuring at the wheels. My stage 2 dyno tune got me to 238awhp and 290awtq My bad luck build Link to comment Share on other sites More sharing options...
zeusdog34 Posted December 25, 2009 Author Share Posted December 25, 2009 ^^^^ sorry should have been more clear(crank HP)..I think thats why on Cobb it "estimates".. Link to comment Share on other sites More sharing options...
