McDowell Performance Tunin Posted November 13, 2009 Share Posted November 13, 2009 I noticed I'm hitting only about 200g's max during 3rd gear WOT pulls. It's seems other stage 2 setups are in the 220's at least. I also noticed I'm only hitting 4.3 volts, which matches my stock MAF scailling. So, I guess my question is, is there a reason I'm only hitting 4.3 volts? I'm all stock for my intake, with a fairly new OEM filter and have a gutted first cat DP with a map based off of mickeyd's stage 2 map, adjusted for my car. Airboy's spread sheet is showing 239hp(5830 RPM) and 230tq(3400RPM), which seems pretty good for crappy 91 gas, salt lake's altitude (close to 4000ft, i think) and just my first dp cat removed. (I'm installing an UP off an STI this weekend, if it's not too cold). Thoughts? Feedback appreciated as I am new to OS tuning. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
testes1010 Posted November 13, 2009 Share Posted November 13, 2009 on 91octane @ 4000ft, your numbers don't sound so bad. on 93octane @ <500ft my stock numbers(stock ECU, no mods) was 215-220g/sec, my STG1 map at just under 17psi peak was flowing 230g/sec. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted November 13, 2009 Author Share Posted November 13, 2009 cool, thanks Testes. My stock numbers on the spreadsheet were 170hp and 195tq, so I figured things were ok. I do a lot of logging and fine tunning on RR and everything looks good. Any suggestions, as far as tuning, after I install the sti UP? I was thinking of leaving things alone, do some logging and go from there. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted November 13, 2009 Author Share Posted November 13, 2009 +59hp and 35tq seems like a lot for just gutting the dp. but I used Airboys spreadsheet both times. anything to look for, as far safety, if those numbers are correct? here is the dyno, sorry for the 2 pagesdyno.pdf www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
Infamous1 Posted November 13, 2009 Share Posted November 13, 2009 +59hp and 35tq seems like a lot for just gutting the dp. but I used Airboys spreadsheet both times. anything to look for if those numbers are correct? Just the correct weight, tire diameter (measured) and a level road. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted November 13, 2009 Author Share Posted November 13, 2009 ^went up to 243hp and 233tq www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted November 13, 2009 Author Share Posted November 13, 2009 again, this is with my stock catted UP www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
NSFW Posted November 14, 2009 Share Posted November 14, 2009 on 91octane @ 4000ft, your numbers don't sound so bad. on 93octane @ <500ft my stock numbers(stock ECU, no mods) was 215-220g/sec, my STG1 map at just under 17psi peak was flowing 230g/sec. Seems reasonable to me too. I was hitting 250ish with aftermarket UP/DP at sea level, and 92 oct. I suspect that gutting the UP would help close the gap a bit. Link to comment Share on other sites More sharing options...
rtbrjason Posted November 16, 2009 Share Posted November 16, 2009 I was hitting 225-230 or so with a gutted first cat and stage 2 opensource tune. Replaced the stock dp with a catless and I'm hitting 240-245 with only minor changes to the map. This is at about 400ft in ~50 degree weather. Airboy's sheet varies a bit for me, but I've seen 250-260hp and 310-320tq pretty consistently in both 3rd and 4th gear. Link to comment Share on other sites More sharing options...
f1anatic Posted November 21, 2009 Share Posted November 21, 2009 Protuned 250 whp 300 wtq - gutted pipes. Link to comment Share on other sites More sharing options...
