bdickey058 Posted September 23, 2009 Share Posted September 23, 2009 took my car to a local tuner and he tried to reflash my ecu but coudlnt b/c under the pass side firewall where you hook the computer up to the car to reflash it wouldnt work. he said it would plug in but usually the fan will run when you plug the computer in to reflash it but the fan wasent running and he didnt know what the heck was going on. anyone else have this problem? Link to comment Share on other sites More sharing options...
rao Posted September 23, 2009 Share Posted September 23, 2009 Find another "tuner". Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bdickey058 Posted September 23, 2009 Author Share Posted September 23, 2009 i want infamous to do a tune but i cant get romraider or ecuflash to work on my computer. plus i'm dumb as hell with how to zip drives and all that. this guy has tuned a lot of cars but he said he has never had the problem that he had with mine. so idk what to do. Link to comment Share on other sites More sharing options...
Infamous1 Posted September 23, 2009 Share Posted September 23, 2009 Follow the wires, if they are still intact there is no reason it shouldn't go into test mode. Link to comment Share on other sites More sharing options...
John M Posted September 23, 2009 Share Posted September 23, 2009 1) You connect to the OBD port on the drivers side. 2) The green connectors are on the passenger side, near the console, above the trim piece. You connect them while flashing, disconnect them when done. He should have at least been able to connect with a logger or something to make sure communication was working. That doesn't require the green connectors. Link to comment Share on other sites More sharing options...
bdickey058 Posted September 23, 2009 Author Share Posted September 23, 2009 he was able to connec tto the obd port but could not find the connection tot he green connectors b/c it had a wire running from it to someplace that he couldnt find. anyone have a wiring diagram on a 05 legacy gt Link to comment Share on other sites More sharing options...
m sprank Posted September 23, 2009 Share Posted September 23, 2009 You plug the two green connectors into each other. Turn on the ignition. The fan will start to run. The car is ready to flash. Disconnect the two green connectors from each other when finished. Link to comment Share on other sites More sharing options...
bdickey058 Posted September 23, 2009 Author Share Posted September 23, 2009 thats what he did and the fan would not start. ahhhhhhhhhhhhhhhhhhh if i can just get romraider and eculogger to work then infamous can tune it but hell i'm dumb with computers Link to comment Share on other sites More sharing options...
m sprank Posted September 23, 2009 Share Posted September 23, 2009 Sorry, tough to diagnose without being there. Look for vacation pics of 2005. Should be able to trace wiring from those. Not sure how the connection got damaged. Kinda sounds like you have GREMLINS! I would bury the car and find a new one. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 23, 2009 Share Posted September 23, 2009 there are 2 white connectors under the driver side. They need to be unplugged. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
05LGT-Hank Posted September 24, 2009 Share Posted September 24, 2009 Since when? Link to comment Share on other sites More sharing options...
mwiener2 Posted September 24, 2009 Share Posted September 24, 2009 on 99.9% of cars they are unplugged as they leave the assembly line floor. Then they aren't ever used for anything. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
spec.B Dream Posted September 25, 2009 Share Posted September 25, 2009 Just a thought, the key must be in the "On" position to get the fan to turn on, right? Link to comment Share on other sites More sharing options...
mwiener2 Posted September 25, 2009 Share Posted September 25, 2009 yes My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
