jtmvt Posted September 14, 2009 Share Posted September 14, 2009 Anybody know how many miles would be recommended before changing coolant, brake, diff, and tranny fluids for a stage-3 2005 LGT MT driven as a year round daily driver...not raced? Link to comment Share on other sites More sharing options...
rao Posted September 14, 2009 Share Posted September 14, 2009 I thnk Subaru already thought of this Coolant - 36,000 Brake Fluid - 36,000 Transmission and Differential - 36,000 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
jtmvt Posted September 14, 2009 Author Share Posted September 14, 2009 I thnk Subaru already thought of this Coolant - 36,000 Brake Fluid - 36,000 Transmission and Differential - 36,000 Thanks...wasn't sure if it should be more frequent or not being stage-3. Link to comment Share on other sites More sharing options...
rao Posted September 14, 2009 Share Posted September 14, 2009 Oh, I am sure you can get someone to tell you to change all of the lfuids (with proper magical fluids) every month or so. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
jtmvt Posted September 14, 2009 Author Share Posted September 14, 2009 Oh, I am sure you can get someone to tell you to change all of the lfuids (with proper magical fluids) every month or so. Probably true....I hate the idea of draining perfectly good fluids though if its not necessary. Plus, I've spent enough $$ on the whip as of late....don't really want to spend any more for a while unless I really need to.... Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted September 14, 2009 Share Posted September 14, 2009 Brake fluid should be 36k miles or 30 months which ever comes first. Brake fluid absorbs moisture constantly so will need to be replaced every 2 years or so regardless of mileage. Link to comment Share on other sites More sharing options...
JoeFromPA Posted September 17, 2009 Share Posted September 17, 2009 I thnk Subaru already thought of this Coolant - 36,000 Brake Fluid - 36,000 Transmission and Differential - 36,000 Hey Rao, I thought the manual says 30k for each of those? I could be wrong, just preparing to do it at 30k myself and thought that's what they wanted for warranty etc. Also, do you know if the coolant drain&fill interval is extended using the new Subaru coolant? I really would prefer to do coolant once every 60-90k. Joe Link to comment Share on other sites More sharing options...
