SpawnGT Posted August 27, 2009 Share Posted August 27, 2009 Hey guys i need some ideas or a push in the right direction. Every morning (or at least every other morning) when i get to my car, my rear driver side tire is deflated (and i mean like anywhere between 7 and 13 Psi according to those Hess Automatic Electronic Air Pumps). Now i have taken it to my tire guy and he said that when he submerged it that there was no air leaking out anywhere from what he could see. Also its not some vengeful ex-gf becuase i park the car in a different town every other night (aka Mondays tuesdays and Fridays its at my house, wednesday thursday and saturday its at my Gf's house) any clues? Its not a broken rim becuase i just finished a whole heap of drama with my front driver side rim being cracked in 3 places and yes they were Rota's Link to comment Share on other sites More sharing options...
PhilT Posted August 27, 2009 Share Posted August 27, 2009 1. Take the wheel off the car 2. Inflate tyre to 35 psi 3. Take soapy water and spray it around tyre and wheel 4. The place you see bubbles coming from is the source of the leak Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
SpawnGT Posted August 27, 2009 Author Share Posted August 27, 2009 1. Take the wheel off the car 2. Inflate tyre to 35 psi 3. Take soapy water and spray it around tyre and wheel 4. The place you see bubbles coming from is the source of the leak The tire guy i use did that and it was a no go. Link to comment Share on other sites More sharing options...
PhilT Posted August 27, 2009 Share Posted August 27, 2009 How much do you trust your tyre guy ? The air is going somewhere, if someone isn't letting it out while you are sleeping, then you have a leak. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
pillboy Posted August 27, 2009 Share Posted August 27, 2009 I assume you can't find any objects embedded in the tire, right? I would have it demounted and the wheel checked for corrosion (cleaned if need be) and a new stem installed. If it is leaking that fast, I agree with PhilT, you should see bubbles. It is still ugly. Link to comment Share on other sites More sharing options...
spyguy Posted August 27, 2009 Share Posted August 27, 2009 did you forget about your paperboy's tip? Link to comment Share on other sites More sharing options...
KartRacerBoy Posted August 27, 2009 Share Posted August 27, 2009 Stalking vengeful ex-girlfriend. It explains all! Link to comment Share on other sites More sharing options...
pillboy Posted August 27, 2009 Share Posted August 27, 2009 Maybe someone stuck something inside the valve stem cap so that every time you put it on it pushes down ever so slightly on the pintle. No need to then waste gas and follow you around every night. It is still ugly. Link to comment Share on other sites More sharing options...
fonts Posted August 29, 2009 Share Posted August 29, 2009 You are losing a LOT of air in the situation you are describing. Finding leaks is not always easy. Using the procedure as Phil described it should uncover the leak. If your current tire guy can't find the leak find a new tire guy ..... Good luck. Link to comment Share on other sites More sharing options...
zag300zx Posted August 29, 2009 Share Posted August 29, 2009 ^^ Leaks are not hard for a tire shop to find. Get a new one. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted August 29, 2009 Share Posted August 29, 2009 Has the OP caught the stalking exgirlfriend in the act yet? Link to comment Share on other sites More sharing options...
SpawnGT Posted August 29, 2009 Author Share Posted August 29, 2009 hahaha...No i havnt caught the ex-gf in the act yet. but after much deliberating i took it back to my tire guy, took the rim off, and sprayed the hell out of it, only to find the smallest crack on the inside lip of the rim. now its time to figure what to do...buy another replacement rim for 225, or just change all of them out for some cheap drag rims. Link to comment Share on other sites More sharing options...
c-lo Posted August 29, 2009 Share Posted August 29, 2009 I"ve got a set of drag rims on mine. they are ok. look good, but I've got 1 bent rim that's preventing me from rotating my tires. have to get it fixed. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
whitetiger Posted August 29, 2009 Share Posted August 29, 2009 dont forget to vheck the valve stems too, not just the tire. Link to comment Share on other sites More sharing options...
Garandman Posted August 29, 2009 Share Posted August 29, 2009 dont forget to vheck the valve stems too, not just the tire.Yes, sometimes it leaks slowly through the valve insert but the champer is big enough no bubbles show. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
mwiener2 Posted August 29, 2009 Share Posted August 29, 2009 hairline crack on the wheel? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
enthusiast Posted August 29, 2009 Share Posted August 29, 2009 hairline crack on the wheel? +1. I had a similar issue and tracked it down to a small crack. My mod list Link to comment Share on other sites More sharing options...
SpawnGT Posted August 29, 2009 Author Share Posted August 29, 2009 yea, the crack is on the order of 3-4mm in length, and barly wide enough to really allow a visible air bubble from when soapy water is applied onto it. http://i87.photobucket.com/albums/k142/thepreludedude/DSC07744.jpg The following picture shows an example of where the crack is, although its not my rim (or my rim-crack either). My crack is pretty much the size of the little crack closest to the tire, but does not extend down into the middle of the rim like the picture shows. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 29, 2009 Share Posted August 29, 2009 wait.... you knew about that crack and you nor your mechanic could find the leak? Really? cause that's where the air is getting out and that's not a safe wheel to drive on. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
SpawnGT Posted August 29, 2009 Author Share Posted August 29, 2009 hahaha...No i havnt caught the ex-gf in the act yet. but after much deliberating i took it back to my tire guy, took the rim off, and sprayed the hell out of it, only to find the smallest crack on the inside lip of the rim. now its time to figure what to do...buy another replacement rim for 225, or just change all of them out for some cheap drag rims. No....i went back, and we did an even more meticulous investigation, and then found it. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 29, 2009 Share Posted August 29, 2009 Ah. You need a new rim, you can't fix that (safely) My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted August 30, 2009 Share Posted August 30, 2009 Weld it up, it'll be fine. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
pillboy Posted August 30, 2009 Share Posted August 30, 2009 Weld it up, it'll be fine. JB Weld It is still ugly. Link to comment Share on other sites More sharing options...
SpawnGT Posted August 30, 2009 Author Share Posted August 30, 2009 JB Weld will JB weld hold something under 35~40psi ? Link to comment Share on other sites More sharing options...
mwiener2 Posted August 30, 2009 Share Posted August 30, 2009 OMG!! No! You can't fix that wheel. It's trash. You could weld it, but the act of welding it could create stress fractures somewhere else. It probably already has other stress fractures in it.... it's already cracked! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
