hifonic Posted August 3, 2009 Share Posted August 3, 2009 Ok so my turbo isn't blown but am pretty sure it will go if I keep driving.Ok so my question is what turbo's would be a direct bolt on replacment for the VF-40? Am still running the stock tmic so which turbo's would bolt on If I can't find a VF-40. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 3, 2009 Share Posted August 3, 2009 They say you can sometimes find them in the classified forum here, for sale. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
executor485 Posted August 3, 2009 Share Posted August 3, 2009 direct replacements: VF40, VF46, VF52 Now, even thought they are direct replacement, you'll need a tune with anything other than a 40, and the 52 will be a good upgrade, but should have FP and injectors upgraded as well to get the most power. Good luck If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
JoeFromPA Posted August 3, 2009 Share Posted August 3, 2009 You need a re-tune with the VF46? Link to comment Share on other sites More sharing options...
executor485 Posted August 3, 2009 Share Posted August 3, 2009 You need a re-tune with the VF46? 1) I have read some stuff on here that has said it is best, advised, to get a re-tune. I believe its because of the wastegate actuator? 2) If he's pro-tuned for a 40, there are slight differences in the 46 that could cause small problems down the line. Just from what I've read is all... I could be way off, but I wouldnt want to take the chances. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
hifonic Posted August 3, 2009 Author Share Posted August 3, 2009 direct replacements: VF40, VF46, VF52 Now, even thought they are direct replacement, you'll need a tune with anything other than a 40, and the 52 will be a good upgrade, but should have FP and injectors upgraded as well to get the most power. Good luck VF-46 is from a Spec B right? but etheir way if I dont get a 40 I'll get retuned,but a 52 would be pretty nice lol.Thanks for the info btw. Link to comment Share on other sites More sharing options...
keysersoze Posted August 3, 2009 Share Posted August 3, 2009 VF-46 is from a Spec B right? but etheir way if I dont get a 40 I'll get retuned,but a 52 would be pretty nice lol.Thanks for the info btw. It's the same turbo you'll find in the GT as well. But, I'm sure that someone will chime in and tell you that the turbo in the Spec B is hand-selected and therefore better.... Link to comment Share on other sites More sharing options...
hifonic Posted August 4, 2009 Author Share Posted August 4, 2009 It's the same turbo you'll find in the GT as well. But, I'm sure that someone will chime in and tell you that the turbo in the Spec B is hand-selected and therefore better.... Haha lol. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 4, 2009 Share Posted August 4, 2009 VF46 is the oem turbo for all LGTs and spec B models from 2007-2009. I would definately retuned if a vf46 was installed, it also runs a different size restrictor pill. Link to comment Share on other sites More sharing options...
