OGG Posted August 10, 2009 Share Posted August 10, 2009 Use method #2 http://www.thesuicidaleggroll.com/gain.htm Link to comment Share on other sites More sharing options...
spect2k Posted August 11, 2009 Author Share Posted August 11, 2009 Alright, so I've got the gains fairly set (at least as best as I can). Here's my next and hopefully last question. I've done some searching but haven't found great results. With the volume on the moderate to loud side, when switching between songs or even during quiet parts of songs, I can hear some white noise or a 'hiss'. I figure it can be several things: 1) The need of a cleansweep or similar device 2) The amp 3) The line out converter 4) Some kind of interference I ran the speaker and power wire on opposite sides and there is a nice short ground for the amp. What do you guys think? Link to comment Share on other sites More sharing options...
jhig Posted August 24, 2009 Share Posted August 24, 2009 spect2k, did you ever find a solution for this? ^^^ Link to comment Share on other sites More sharing options...
spect2k Posted August 24, 2009 Author Share Posted August 24, 2009 I turned down the amp quite a bit and it seems to be less noticeable, but it is still there. Perhaps it is the sacrifice of getting a nice amp at a low price, maybe somewhat less filtering capability. Maybe the cleansweep or other similar device would help, but I dont want to pay the $200. I found that just playing with the settings enough can make it doable. Link to comment Share on other sites More sharing options...
CzarDestructo Posted August 24, 2009 Share Posted August 24, 2009 http://www.reqsound.com/ Not quite Cleansweet quality, but for the price well worth it. You can find these online for dirt cheap. I currently run the stock deck with stock speakers, a Re-Q hooked to an amp with a 10" sub in the trunk. I recently hooked up a high quality input to the line-in, RCA to 1/8" jack, just a nice CLEAN input. The difference was night and day between the MP3 CDs, even normal CD and especially satellite radio. The speakers sounded 2x better and got significantly louder without distortion. I'm absolutely thrilled with it and I'm looking into installing something more permanent to squeeze a little more life out of my cheap stock setup. Just a heads up! Something worth trying. edit: that hiss is almost certainly from the line out converter Link to comment Share on other sites More sharing options...
spect2k Posted August 25, 2009 Author Share Posted August 25, 2009 I'll have to look into it, I sure looks quite a bit more affordable and there are pretty good reviews for it. In the meantime, I am working to adjust the amp to be ideal. I feel like I've got the gains at a good place, but the one switch that I still dont know what to do with is the "filter" switch. There are three settings, "High Pass", "Low Pass", and "Off". From alpine's website: Alpine MRP-F300 a) Set to the “LP” position when the amplifier is used to drive a subwoofer. The frequencies above the crossover point will be attenuated at 12 dB/octave. b) Set to the “HP” position when the amplifier is used to drive a tweeter/ midrange system. The frequencies below the crossover point will be attenuated at 12 dB/octave. NOTE: In this case, the “Bass EQ” function is invalid. c) Set to the “OFF” position when the amplifier will be used for driving fullrange speakers. The full frequency bandwidth will be output to the speakers with no high Right now, I have it on HP. What do you recommend with my infinity reference 6020cs components up front and infinity reference 6022si coax in the rear? Thanks! Link to comment Share on other sites More sharing options...
jhig Posted August 25, 2009 Share Posted August 25, 2009 I'm pretty sure you're correct on the HP setting. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 25, 2009 Share Posted August 25, 2009 for speakers you want it set on HP so that it allows the higher frequency's above 125hz pass through the amp. If you turn it off it will let the full range through including the really low end which can damage the speakers if you have to much power going to them. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
spect2k Posted August 25, 2009 Author Share Posted August 25, 2009 Cool, so it sounds like I have it right. Thanks for the help. I am really enjoying the sound system! Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 25, 2009 Share Posted August 25, 2009 a proper 4 channel amp will not only have the crossovers but frequency adjustments per channel as well so that you can find that midrange between what the hp,mp,lp filters all skip through. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
