IwannaSportSedan Posted July 23, 2009 Share Posted July 23, 2009 http://www.autoblog.com/2009/07/23/subaru-hatches-hardcore-jdm-impreza-wrx-spec-c/ http://www.blogcdn.com/www.autoblog.com/media/2009/07/9436400.jpg Yet another item in the Subaru Japan gets good hardware. USA, not so much. 304hp, 311 ft.lbs, ball bearing turbo, IC water spray, and lightened panels, battery, air compressor instead of spare. Too bad it still looks like Quasimodo. Link to comment Share on other sites More sharing options...
camber Posted July 23, 2009 Share Posted July 23, 2009 http://www.blogcdn.com/www.autoblog.com/media/2009/07/1536837.jpg http://www.blogcdn.com/www.autoblog.com/media/2009/07/2459894.jpg http://www.blogcdn.com/www.autoblog.com/media/2009/07/6653491.jpg I wonder how the new spec. C turbo compares to the VF-36? Link to comment Share on other sites More sharing options...
camber Posted July 23, 2009 Share Posted July 23, 2009 http://www.blogcdn.com/www.autoblog.com/media/2009/07/7656047.jpg We can probably use the spec. C battery in the bl/bp as well. Link to comment Share on other sites More sharing options...
katalyst Posted July 23, 2009 Share Posted July 23, 2009 those parts are t3h sex i like the wheels and the recaro seats a lot too Link to comment Share on other sites More sharing options...
camber Posted July 24, 2009 Share Posted July 24, 2009 It's interesting that Subaru hasn't adopted some advancements from the 2010 LGT to its top of the line performance car. I guess its still good they are developing parts that will easily swap over to the bl/bp. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted July 24, 2009 Author Share Posted July 24, 2009 What could they adapt? The '10 Legacy GT doesn't have a track record yet. The front mounted turbo and revised engine subframe arrangement would require major structural changes. The GR Impreza is basically a BL Legacy, chassis wise, from the rear axle forward. Link to comment Share on other sites More sharing options...
camber Posted July 24, 2009 Share Posted July 24, 2009 The front mounted turbo setup has already been used on the bl/bp platform. It was on the diesel version of the car. Link to comment Share on other sites More sharing options...
nemo Posted July 24, 2009 Share Posted July 24, 2009 +1 on the wheels. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
Guest Posted July 24, 2009 Share Posted July 24, 2009 The front mounted turbo setup has already been used on the bl/bp platform. It was on the diesel version of the car. Not exactly, the turbo is on the side on the diesel engine. Link to comment Share on other sites More sharing options...
camber Posted July 25, 2009 Share Posted July 25, 2009 Not exactly, the turbo is on the side on the diesel engine. True enough... It's not exaclty the same setup as the 2010 LGT but the concept/idea is more or less the same. I guess you can say that 2010 LGT most interesting piece orginated from the bl/bp. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 27, 2009 Share Posted July 27, 2009 http://www.blogcdn.com/www.autoblog.com/media/2009/07/1536837.jpg http://www.blogcdn.com/www.autoblog.com/media/2009/07/2459894.jpg http://www.blogcdn.com/www.autoblog.com/media/2009/07/6653491.jpg I wonder how the new spec. C turbo compares to the VF-36? They dont use VF52's on the 2008-09 STi's? Link to comment Share on other sites More sharing options...
