rodan Posted July 17, 2009 Share Posted July 17, 2009 I'm trading the LGT in tomorrow morning and I would like to pull my stage two parts for resale, but I've run into a problem.... When I had it tuned, I installed a Perrin boost control solenoid, which at the time, had to be wired into the factory harness. Now I can't find the connector for the factory solenoid... Question: If I remove the DP, and unmarry the AP, flashing it back to stock, is it going to run (and not blow up on the next owner!) if I leave the Perring BCS on the car?? I hate to leave $1k worth of resellable parts on the car, but I'm not going to give someone a ticking time bomb.... Please help! Link to comment Share on other sites More sharing options...
Spec B Posted July 17, 2009 Share Posted July 17, 2009 If you leave the EBCS and flash to stock the car will likely overboost and hit boost cut anytime the next owner pins it. You should delay trading it in a couple of days until you sort it out. Another option is tring to splice the wires to the stock BCS...I can't imagine it being tha difficult to do. Link to comment Share on other sites More sharing options...
rodan Posted July 17, 2009 Author Share Posted July 17, 2009 I considered that, but I don't know which wire goes to which pin without the connector... If anyone can tell me which wire goes to the top pin, and which to the bottom pin, I would greatly appreciate it!! Link to comment Share on other sites More sharing options...
Spec B Posted July 17, 2009 Share Posted July 17, 2009 If there are only 2 wires..just use a trial and error method. Good luck. Sell me those wheels?! Link to comment Share on other sites More sharing options...
rao Posted July 17, 2009 Share Posted July 17, 2009 All of the tuners on here and no anwers It's a solenoid so it doesn't matter Since I'm a nice guy, here you go:Wastegate Wiring.pdf Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rodan Posted July 17, 2009 Author Share Posted July 17, 2009 Thanks, Rao... the solenoid will operate the same regardless of polarity? Also, IIRC, the stock line from the solenoid goes to a 'T' between the actuator and compressor housing, correct? And sorry, the wheels are going with the car, as I didn't keep the stockers. Link to comment Share on other sites More sharing options...
rao Posted July 17, 2009 Share Posted July 17, 2009 It will, but with the diagram you can get it right. The stock line from the solenoid goes to a T in between the actuator and compressor housing so you have that right also. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Spec B Posted July 17, 2009 Share Posted July 17, 2009 Also make sure you have the restrictor pill in (if you removed it when you went EBCS). Link to comment Share on other sites More sharing options...
rao Posted July 17, 2009 Share Posted July 17, 2009 Good point and it goes on the compressor side of the T. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rodan Posted July 18, 2009 Author Share Posted July 18, 2009 Thanks for the help, guys. Got it all sorted yesterday, and it's off to the dealer in a couple of hours. Boy is this thing slow! Link to comment Share on other sites More sharing options...
Th3Franz Posted July 19, 2009 Share Posted July 19, 2009 what car did you get instead? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
rodan Posted July 19, 2009 Author Share Posted July 19, 2009 http://i5.photobucket.com/albums/y185/RodanAZ/DSC_3770.jpg http://i5.photobucket.com/albums/y185/RodanAZ/DSC_3794.jpg http://i5.photobucket.com/albums/y185/RodanAZ/DSC_3771.jpg Link to comment Share on other sites More sharing options...
atc5 Posted July 19, 2009 Share Posted July 19, 2009 ^^^^ nice choice..hope you got a killer deal. Link to comment Share on other sites More sharing options...
rodan Posted July 19, 2009 Author Share Posted July 19, 2009 It's a 'used' '09 w/ 10k miles. Paid ~ $23k, including our trade equity. Looked at new, but locally the bottom line was going to be about $5k more, wasn't worth it to me on a car with 10k and a 100k powertrain warranty. Basically, we got the first year depreciation for free. I've seen them going as low as $26k on the 'net, but that's a PITA when a trade is involved. With exhaust, CAI and tune, these are putting mid 300s to the wheels... should be fun! Link to comment Share on other sites More sharing options...
TPLGT Posted July 19, 2009 Share Posted July 19, 2009 I really like those^^^ in black...very nice! Rehab is for quitters. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 19, 2009 Share Posted July 19, 2009 Interesting choice. That's a good deal. how's the traction? hehe -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Verwilderd Posted July 19, 2009 Share Posted July 19, 2009 It that car a fun to drive car? I like those better than the GTO's that were out but they just seem clumsy. What are your impressions of it? Link to comment Share on other sites More sharing options...
rodan Posted July 19, 2009 Author Share Posted July 19, 2009 Well, over the last few years, we've had maybe two days each year where snow would have been a challenge with a RWD... We don't get a lot, and usually by late morning the roads are easily passable. We'll see... General impressions, so far: It's MUCH bigger inside, especially rear seat room, than the LGT. That was a big reason we switched. It's nice to have torque EVERYWHERE... I think our LGT (stage 2 -dynoed 250/286) would stay ahead until ~70mph, but only if you launch the car. A regular street start wouldn't have a chance against the auto V8. Even at our altitude (5k feet), the G8 has more on top. At lower altitudes, I'm pretty sure the G8 will spank a stock turbo LGT, stock... As I noted above, G8's are picking up 30-50 hp with exhuast, CAI and tune. Add a cam swap for over 400whp. Suspension wise, it's much more compliant than our LGT (Tokicos/iOn springs/Cobb sways/18's), but it feels very composed. I have no doubt the LGT would run away on a twisty road, but I haven't had a chance to drive the G8 on our local 'track' yet... It's a much heavier car, and has a different purpose, and I'm leaning toward that at this point. I think I drove the LGT hard down our local road 3 times in the last year... Link to comment Share on other sites More sharing options...
