wsmith30132 Posted July 14, 2009 Share Posted July 14, 2009 I just bought a XO2 CBE. I already have Perrin cans with a Perrin long catless downpipe. I put in the XO2 mid and y-pipe and had some fitment issues with the downpipe flange. I finally got it to seal but i dont know how long that will last. I was looking at buying a flex section and welding it in so i wont have issues down the road. Does anyone have any suggestions on doing this on the mid pipe or down pipe? I was thinking about doing it on the cheap mid pipe right after the down pipe flange. Any thoughts would be appreciated, thanks Link to comment Share on other sites More sharing options...
rao Posted July 14, 2009 Share Posted July 14, 2009 Not a bad idea (although buying the Z02 exhaust was a bad idea ) put it anywhere and it should help the problem. I would put it where you suggested. It's welding time Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
tamtalizied Posted July 16, 2009 Share Posted July 16, 2009 I have a flex section on my magnaflow midpipe and also a resonator. The fitment is great, however, the only concern I had with it is since it does flex, my resonator hits my driveshaft at times. I am assuming it would not hit it if the resonator isn't there. I put on the extra long hanger bushings and it fixed the problem Link to comment Share on other sites More sharing options...
wsmith30132 Posted July 17, 2009 Author Share Posted July 17, 2009 Well i just got the flex welded in. I had it marked perfect and set up nice. Everything was cut and cleaned up, it just needed welded. I took it to a local muffler shop expecting a nice weld. My dad has a wire feed and stick welder but I thought it needed a tig. Well the shop welded it on with a stick and its crooked and looks like ass. It will still bolt on but the flex is bowed. He said he cant charge me anything for just a quick weld, but i would have rather paid and had it perfect. So if you are going to do this take it to a professional welding shop not an exhaust shop. LESSON LEARNED Link to comment Share on other sites More sharing options...
rao Posted July 17, 2009 Share Posted July 17, 2009 Bummer. No muffler shop is going to use a TIG. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
