grimsleeper Posted July 28, 2009 Share Posted July 28, 2009 List which springs you have installed - Cobb Sport List any specs you have on the springs - Drop (advertised): 1.75" front / 1" rear : progressive rate List which struts you have - stock Add any other suspension mods you may have - AVO 20mm solid RSB w/ AVO reinforcement mounts - AVO LCA bushings - Whiteline ROCK Size/Type Wheel on car - stock wheels w/ 205/55/17 Dunlop Wintersport 3D - Rota Tarmac III 18x8 w/ 225/40/18 Good Year Eagle F1 Asymmetric Feel free to add comments on the springs you have Before installing the ROCK the suspension had a tendecy to induce terminal understeer pretty easily - I think the large drop from the springs was putting the LCAs into some funky angles during high speed cornering. Appearance wise it's close to perfect imo - 1 1/2 finger gap in the front and 2 in the back for an aggressive raked stance. Stock shocks are taking a beating but I went in knowing I'd be replacing them with coilovers in a year, so no surprises there. Ride is actually much less harsh then I thought it would be. Link to comment Share on other sites More sharing options...
johnboi85 Posted July 28, 2009 Share Posted July 28, 2009 So here are the rules to this thread: stech springs w/ stock shocks. car sitting on 17's. only suspension mod on car at time of picture was just the springs. springs have a rough ride. i'm on bc coilovers and loving it 10000000x better than stechs on stock shocks. Link to comment Share on other sites More sharing options...
ndmx52 Posted August 20, 2009 Author Share Posted August 20, 2009 So here are the rules to this thread: stech springs w/ stock shocks. car sitting on 17's. only suspension mod on car at time of picture was just the springs. springs have a rough ride. i'm on bc coilovers and loving it 10000000x better than stechs on stock shocks. Looking good! Link to comment Share on other sites More sharing options...
kneedragger Posted August 21, 2009 Share Posted August 21, 2009 Anyone running Bilstein HD with Eibach springs?? Link to comment Share on other sites More sharing options...
bjmsdrum00 Posted September 11, 2009 Share Posted September 11, 2009 bump for more pics! great thread, keep it going Link to comment Share on other sites More sharing options...
kuoman Posted September 29, 2009 Share Posted September 29, 2009 Post Pics of your car on lowering springs (before and after if you have them) Before: http://photos-b.ak.fbcdn.net/photos-ak-snc1/v369/222/81/39706490/n39706490_32194537_195.jpg After: Will post after everything sets List which springs you have installed Rallitek Reds List which struts you have Stock Struts Add any other suspension mods you may have Rallitek 22mm Front Sway Bar Rallitek 19mm Rear Sway Bar AVO Front Endlinks AVO Rear Endlinks Cusco Front Strut Brace Cusco Rear Strut Brace Size/Type Wheel on car Wheel: Tenzo Type M Version 1 - 17x7 42mm Tires: Yoko Advan S.4 205/50/R17 Feel free to add comments on the springs you have Just got everything finally installed, ride is great, much smoother and definitely more responsive than stock. Will update in a couple days after everything finally settles Just what I was looking for! Got question about your AVO front/rear endlinks. From Rallitek site, I noticed there are three different endlinks (50mm, 70mm and front sway bar endlink). Which ones did you get? How do you like the ride so far? I'm planning of getting - Rallitek Springs (with stock struts) - Rallitek Front / Rear Sway bars - AVO endlinks - (not sure) Cusco Strut Braces Front/Rear and with stock wheels and rims The only difference is that I have a 2005 2.5i Link to comment Share on other sites More sharing options...
N.sane Posted September 29, 2009 Share Posted September 29, 2009 ^I would suggest getting the Rallitek HD end links, front and rear are available if you look under the GT section, but it's the same stuff, doesnt seem like they updated the 2.5i page. Save your money from the strut braces, unless you want the bling, you wont feel much from them. Link to comment Share on other sites More sharing options...
kuoman Posted September 29, 2009 Share Posted September 29, 2009 ^I would suggest getting the Rallitek HD end links, front and rear are available if you look under the GT section, but it's the same stuff, doesnt seem like they updated the 2.5i page. Save your money from the strut braces, unless you want the bling, you wont feel much from them. Thanks for the tips I didn't know Rallitek HD end links works on 2.5i (that is $20 in saving ) I wasn't sure about strut braces, since I don't do any serious track runs, that save me another $300. Now i just need to find someone or some garage to install them for me. Link to comment Share on other sites More sharing options...
N.sane Posted September 30, 2009 Share Posted September 30, 2009 It's not just the savings, it's the way they're built. The AVO endlinks for some reason dont hold up well according to some consumer reviews, though I do love their products, I have their mufflers and air filter. The Rallitek HD is based off the OEM design but beefier, plus a 5 year warranty! Try the regional threads to see if someone if your area can do installs for you, there's some DIY guys around here.. Link to comment Share on other sites More sharing options...
Spoonwacker Posted September 30, 2009 Share Posted September 30, 2009 Post Pics of your car on lowering springs (before and after if you have them) Stock: http://i162.photobucket.com/albums/t265/Spoonwacker/LGT---New.jpg After springs/struts (and long after settling) on stock-sized ContiExtreme Contact winter tires: http://i162.photobucket.com/albums/t265/Spoonwacker/Untitled-1.jpg http://i162.photobucket.com/albums/t265/Spoonwacker/Untitled-1-1.jpg As she sits today on 225/40/18 Exclaim UHPs and 3/8" Paranoid Fabrications Saggy Butt Shims: [ame=http://www.flickr.com/photos/ztjackson/3591691532/in/set-72157622111988089/]DSC_0220 on Flickr - Photo Sharing!@@AMEPARAM@@http://farm3.static.flickr.com/2467/3591691532_2ee50e9465_m.jpg@@AMEPARAM@@3591691532@@AMEPARAM@@2ee50e9465[/ame] [ame=http://www.flickr.com/photos/ztjackson/3814444100/in/set-72157622111988089/]on Flickr - Photo Sharing!@@AMEPARAM@@http://farm3.static.flickr.com/2434/3814444100_3e10ab4218_m.jpg@@AMEPARAM@@3814444100@@AMEPARAM@@3e10ab4218[/ame] List which springs you have installed Swift Sport wagon springs List which struts you have Bilstein HD Add any other suspension mods you may have 3/8" Paranoid Fabrications Saggy Butt Shims Cobb f/r sway bars w/mount reinforcements Size/Type Wheel on car Winter: 17x7 bronze-painted (Duplicolor wheel paint) stockers, 215/45/17 Continental ContiExtreme Contact Summer: 18x8 Prodrive PFF7s, 225/40/18 General Exclaim UHP sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
Waxiboy Posted September 30, 2009 Share Posted September 30, 2009 I'll play Post Pics of your car on lowering springs (before and after if you have them) http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4371.jpg http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4680pp.jpg List which springs you have installed STi Pinks PN: ST 2033021010, ST2038021010 List which struts you have Bilstein HD Add any other suspension mods you may have JDM rear sway bar, PU bushings F&R Size/Type Wheel on car 18x7.5 +55 JDM STi Enkei Advan AD08 225/40/18 Feel free to add comments on the springs you have Link to comment Share on other sites More sharing options...
firepyro515 Posted October 2, 2009 Share Posted October 2, 2009 Just what I was looking for! Got question about your AVO front/rear endlinks. From Rallitek site, I noticed there are three different endlinks (50mm, 70mm and front sway bar endlink). Which ones did you get? How do you like the ride so far? I'm planning of getting - Rallitek Springs (with stock struts) - Rallitek Front / Rear Sway bars - AVO endlinks - (not sure) Cusco Strut Braces Front/Rear and with stock wheels and rims The only difference is that I have a 2005 2.5i I got the Front Sway bar endlinks and the rear sway bar endlinks (they are adjustable) So far the ride is better, a lot smoother than stock, plus steering is more responsive. There is a little more bounce in the springs, but you don't notice this as much. The other thing i like is that it is now lowered, but only about an inch in the front and rear. I didn't want a big drop so an inch is perfect Link to comment Share on other sites More sharing options...
mattg Posted October 2, 2009 Share Posted October 2, 2009 http://photos.imageevent.com/mattg/legacygt/large/0506080008.JPG Lowered on JDM STi Pinks http://photos.imageevent.com/mattg/legacygt/large/subaru%20011.jpg How she sits today. Pinks, Perrin F&R sways, more to come... http://photos.imageevent.com/mattg/legacygt/large/IMG_8296.JPG Link to comment Share on other sites More sharing options...
Spoonwacker Posted October 2, 2009 Share Posted October 2, 2009 ^ Love the rim color sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 2, 2009 Share Posted October 2, 2009 ^ Looks good! Are your pinks on the stock struts? Link to comment Share on other sites More sharing options...
kuoman Posted October 3, 2009 Share Posted October 3, 2009 It's not just the savings, it's the way they're built. The AVO endlinks for some reason dont hold up well according to some consumer reviews, though I do love their products, I have their mufflers and air filter. The Rallitek HD is based off the OEM design but beefier, plus a 5 year warranty! Try the regional threads to see if someone if your area can do installs for you, there's some DIY guys around here.. I think there is a guy in RI that can do install I'll have to PM him when I get all the stuffs. By the way, I assumed if the car is dropped by about 1 inch, I will (or not) have camber problem right? Link to comment Share on other sites More sharing options...
maddoc Posted October 19, 2009 Share Posted October 19, 2009 http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4680pp.jpg List which springs you have installed STi Pinks PN: ST 2033021010, ST2038021010 List which struts you have Bilstein HD Spec B tophats up front? Link to comment Share on other sites More sharing options...
NZGT Posted January 28, 2010 Share Posted January 28, 2010 Spec B tophats up front? I'd also like to know. I've just put Cobb springs in my wagon (JDM factory fitted Bilsteins) and mine doesn't sit that low Link to comment Share on other sites More sharing options...
N.sane Posted January 28, 2010 Share Posted January 28, 2010 Bilstein HD requires Spec.B tophats. Link to comment Share on other sites More sharing options...
LegacyDan Posted January 29, 2010 Share Posted January 29, 2010 List which springs you have installedTein S-tech springs List which struts you haveJDM Bilstein's Add any other suspension mods you may haven/a Size/Type Wheel on car17 x 7.5 Rot GRA's Goodyear eagle F1 AS Before on stockers: http://img383.imageshack.us/img383/5701/dscf0723largezd0.jpg after with stockers: http://img519.imageshack.us/img519/7646/dsc0193bh2.jpg and with Rota's after settling properly http://img291.imageshack.us/img291/8914/dsc0270x.jpg Link to comment Share on other sites More sharing options...
subaggie Posted February 6, 2011 Share Posted February 6, 2011 I'm having trouble deciding between the Tein H-Techs and the Eibach Pro-kit springs. I want to get my stance down a little bit without having issues going up driveways and whatnot. Any input or opinions on both would be much appreciated. Link to comment Share on other sites More sharing options...
king_j Posted February 6, 2011 Share Posted February 6, 2011 i had the h-techs and swapped them for the pro kit. the tiens seem to lower the front a bit more then the pro kit. the pro kit has a very even fender gap all around. driving wise, with the tiens i could tell the car was lowered with an aftermarket spring. with the pro kit, it felt more like a factory performance upgrade, this suited the car much better. the pro kit does not have a harsh ride, there really isnt any "bang/crash" over bumps. the tiens felt more harsh over bumps. the pro kit gives the car a good firm ride, not coilover quality, but great for the money. going up driveways and bumps is fine if you go at an angle, i have a front lip and have no problems. Link to comment Share on other sites More sharing options...
jojo2.5gt Posted February 7, 2011 Share Posted February 7, 2011 So for an 07 spec I'm just wondering, can lowering springs that fit on a gt also fit on the Bilsteins too or is it any different?? Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 7, 2011 Share Posted February 7, 2011 So for an 07 spec I'm just wondering, can lowering springs that fit on a gt also fit on the Bilsteins too or is it any different?? Springs will interchange, but may have ride height differences due to the different top hats. With Bilsteins, you'll likely want to stick with Pinks, Swifts, or other JDM springs. Link to comment Share on other sites More sharing options...
jojo2.5gt Posted February 7, 2011 Share Posted February 7, 2011 Ok good to know. Thanks so much! Link to comment Share on other sites More sharing options...
