agctr Posted March 9, 2005 Share Posted March 9, 2005 G'Day Everyone.... Just curious if anyone knows or if they can point me in the right direction regarding what FAULT CODE 66 is on a MY 96 and UP. Any information would be greatly appreciated. Thanks. Adam. Link to comment Share on other sites More sharing options...
rao Posted March 9, 2005 Share Posted March 9, 2005 Is the car OBD I or OBDII. In the US 1996 started OBDII and that code is air bag related. Pre-OBD Subaru it a turbo system fault. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
PGT Posted March 9, 2005 Share Posted March 9, 2005 Wouldn't that be a '99' for those not in Oz? I crack myself up. Link to comment Share on other sites More sharing options...
agctr Posted March 9, 2005 Author Share Posted March 9, 2005 G'Day Rob Yes it has something to do with the turbo system so you are right about the Pre-OBD statement. The car seems to cut out at around 3K RPM like its hitting some sort of limiter. Rob, can you provide any further information on this? If you can, it would be FANTASTIC and GREATLY APPRECIATED. Thanks again for your help in advance Rob. Adam. Link to comment Share on other sites More sharing options...
rao Posted March 9, 2005 Share Posted March 9, 2005 Start here: http://www.finleyweb.net/default.asp?id=142 and here http://www.legacygt.com/forums/showthread.php?t=3217 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
agctr Posted March 9, 2005 Author Share Posted March 9, 2005 Thanks for the info Rob, greatly appreciated. Adam. Link to comment Share on other sites More sharing options...
