Dr. Zevil Posted June 4, 2004 Share Posted June 4, 2004 I really need to start subscribing to magazines.. I am so out of the loop when it comes to that stuff. Link to comment Share on other sites More sharing options...
PPower Posted June 4, 2004 Share Posted June 4, 2004 [quote name='Drift Monkey'][quote name='SoldonSubie']When comparing apples to apples the Outback XT only weighs 80 pounds more than the GT. As a matter of fact, the Outback XT with 5MT weighs 20 pounds LESS than a Limited GT wagon with 5MT. Plus the XT has a 4.44:1 final drive vs. the GT's 4.11:1.0.[/quote] So the OBXT uses the same tranny as the FXT? Intresting...[/quote] No. The 5 gear ratios are different, but both the OBXT and FXT get a 4.44:1 final ratio. The OBXT has the same gearing as the JDM Spec B but with taller tires that exactly compensate to be equal to the GT's 4.111:1 gearing. The advantage could be that you could then put GT sized track tires on the OBXT and get the tires rotating as quickly as a Spec B but with the weight penalty. Also, gtguy has brought up that past OB have not been able to be lowered, so this new OB may not be able to be lowered either. Without the proper suspension, the tiny gearing benefit with smaller tires becomes moot. Link to comment Share on other sites More sharing options...
Drift Monkey Posted June 4, 2004 Share Posted June 4, 2004 Intresting, although as a counter point, I wouldn't see why smaller tires with upgraded suspension components and NOT being lowered would be a bad thing, other than perpahps looking asthetically unappealing. If the OBXT and FXT share only the 4.44 FD then which tranny actually has the shorter gearing despite the FD? This could get intresting with tranny swaps and what not...:twisted: Link to comment Share on other sites More sharing options...
SUBE555 Posted June 4, 2004 Share Posted June 4, 2004 [quote name='Drift Monkey']Intresting, although as a counter point, I wouldn't see why smaller tires with upgraded suspension components and NOT being lowered would be a bad thing, other than perpahps looking asthetically unappealing. If the OBXT and FXT share only the 4.44 FD then which tranny actually has the shorter gearing despite the FD? This could get intresting with tranny swaps and what not...:twisted:[/quote] The reason some thought of the OB XT as potential for more in that department (and they may be right, but not proven), is the OB XT has larger fender flare possibly able to accomodate seriously wide rubber (245 or 255 maybe), and the gearing being the two major factors. If you're looking at using the car for handling but with those characteristics, lowering the center of gravity and for a better look/stance is key. Link to comment Share on other sites More sharing options...
Drift Monkey Posted June 4, 2004 Share Posted June 4, 2004 Of course but What i'm trying to say is that it couls still be a good handler despite the ride height. Anything is possible with tuning. Link to comment Share on other sites More sharing options...
SUBE555 Posted June 4, 2004 Share Posted June 4, 2004 Anything is possible given X amount of money. ;) Link to comment Share on other sites More sharing options...
